Sold/Expired *SOLD* : 15W Ostar Surefire L6
Britelumens
SINGAPORE
Hi Guys,
Up for sale are 2 unit of brand new SUREFIRE L6, custom build with an Ostar emitter in each host. One of them has a twist tailcap for constant on, press for momentary on, while the other (on the right) feature a clicky ON/OFF switch .
While utilizing these high powered led, it is recommended to run the highest setting on momentary only / short burst (less than 2 mins) to keep the driver cool and maintain battery longevity. As the current drain on 3 x RCR123 at highest setting can be high as voltage sag. But at medium output, its not an issue.
Please note that there is a very small nick of anodized discolored on (left picture unit) between the head and the finned. This is exactly how it was received brand new. However, its not a nick or dent.
SPECIFICATIONS:
- Brand new SUREFIRE L6
- Blue Shark with Remora
- Custom anodized aluminum heat-sink
- 15W Osram Ostar (QY bin)
- run on 3 x RCR123
- ( 3 mode at Low , Medium , High (Momentary / Burst mode)
- Come with original box / lanyard / 3 x SF battery
(Pictured lanyard not included) :D
- *** ALL SOLD ***
Here is the outdoor beamshot
Price is $580 each , Please add $18 for shipping WORLDWIDE.
Registered mail please add $2.00. I'll be responsible for lost or undelivered mail should you decided to choose this option.
I'll not be responsible for lost mail shipping via regular airmail. Please allow 9 - 11 working days for it to arrive.
First to post " I'll take it, get it" follow by PP to info (at) britelumens. com get it. Thanks.
With regards,
Jo @ Britelumens
paulsl
NJ
Re: FS: 15W Ostar Surefire L6
Very nice! What's the run time and output at the different modes please?
openbolt1
Impressive. I really wish I could afford one of these Jo.
MSaxatilus
New Jersey
Yes, I'd be interested in this information as well.
Also, can the light also be powered by 2xLiON cells?
Thanks and great job!:thumbsup:
MSax
Britelumens
SINGAPORE
Hi pauls,
Since I do not have a lux meter, I would not be able to measure the output in term of lumens. However, at the highest mode, the Ostar is putting out 15W of power which is more than a 1000 lumens from this reasonable small light. That is also why momentary use is recommended when running at the highest setting. Partly because running on 3 x RCR123 yield massive heat
from the driver while it is boosting up the voltage different to power up the Ostar. And significantly, 4 li-ions would be better while 5 even best.
For medium mode and below, its a breeze. While running a setup of 3 x RCR123 of 1000mAh capacity per cell. Run time was 40 min and more with the host warm and still comfortable to hold that is when I turn it off. So at the lowest setting, its not worth mentioning. Current draw from the battery were between 0.52A ~ 0.67A on medium as the 3 x li-ions sag along the way.( just in case you wondering )
On this mod, the entire light engine was rebuild from 6061 aluminium, and the Shark Driver is properly sink with an additional copper heat-sink with in this light engine itself. Being robust, it still maintain the functionality of your favorite SUREFIRE lego ;)
Here is just an example on one of the many small detail work on similar driver.
Many hours were put into making this light. I'm sure it would pleased.
With regards,
Jo @ Britelumens
p/s: MSaxatilus, hoped I answer your question too? Cheers!
aussiebob
Hobart Tasmania
Impressive light, wish i could afford one.:)
Cool pics BTW, very bright looking.
Good luck with the sale.
roadie
Singapore
$580 sing dollar? :)
what if i only need the head not the body ....
can bo ?
JohnTz
chicago
I would be interested in the head only as well if you sell them that way. I have 3x18650 tubes from leef that would work real cool with these.
Britelumens
SINGAPORE
Hi Guys,
Thanks for the kind words. This light would be sold as a complete unit.
No individual sale of parts :eek:.
With regards,
Jo @ Britelumens
cy
USA
does this use the stock surefire reflector?
how's the beam pattern with ostar vs stock 5watt?
