Angryfox
Page 1 of 5 12345 LastLast
Results 1 to 30 of 133
Thread: Handheld 500W LED Power .... finally finished (Beamshots added)
    Enlightened Holzleim's Avatar
    Feb 2008
    Germany, Cologne
    Evilgrin07 Handheld 500W LED Power .... finally finished (Beamshots added)
    Hi,
    want to introduce you to my new >500W peak power LED light:
    After many hours of work it is nearly finished.
    Now some details:
    - 20x CREE MC-E 4B K-bin and one XR-E WG Q5
    - 8 MC-E with CARCLO 26,5mm plain tight optics
    - 12 MC-E without optics for flood
    - XR-E behind 110mm aspherical fresnel lens
    - 4 5350mAh LiPo cells in 2p2s configuration
    - custom made PCB holding 20 MC-E boost drivers each capable of driving upto 1,8A through each series-wired MC-E; one 4A buck driver for the single XR-E (driven to 2,2A); Atmel Mega16 µC
    - 3 tumbler push-button offering 6 contacts
    - each LED group individually controllable (push tumbler from below)
    - 3 special functions when tumbler pushed from above: 8Hz Strobe with peak power; "far-sight" with asperical and 26,5mm group temporaraliy at full power and flood at zero; all LED at full power
    - 5 temperature sensors leading to stepmise current foldback if overheating
    - Mini-USB connector to charge lamp via integrated charging electronics (both 2p cells are charged with individual charging electronic to prevent imbalancing of the battery)
    - XLR connector for external 10A charger and for main or 12V operation of the lamp
    - 5 LED (2xgreen, orange, red, blue) for status display
    - calibration mechanism for battery gauge display
    - all LED soldered directly to 10mm thick copper
    - wheight about 2,5kg
    - total peak output (emitter output, not of-the-front) should be somewhere just over 20000 Lumen
    - BRIGHT.....
    some more pics:
    at low power:
    Added some more fotos of the copper parts holding the LEDs and the very professional soldering process.....
    Beamshots will follow in the next days. I plan to do some comparison shot with our cars xenon and halogen far light...
    Ok, I did some beamshots....
    All shots ISO100 F4.0 1sec
    below: our car's xenon down-light:
    below: our car's halogen far light
    below: our car's halogen far light + xenon down-light
    below: Mr Beambastic spot + mid
    below: Mr. Beambastic spot + mid
    below: Mr. Beambastic all full
    Below: M@dCharger
    Below: Mr. Beambastic spot + mid 50m
    Below: Other Location; our car's xenon down-light + halogen far light
    Below: Mr. Beambastic all full
    Below: M@gCharger
    Below: my 17mm asperic light "David"
    Below: Mr. Beambastic spot only at 112m (ISO 100, F4.0 1,6sec)
    Below: Mr. Beambastic at 112m spot + mid (ISO 100, F4.0 1,6sec)
    More Beamshots will follow later, it began to snow rather hard......
    Will show comparison with 2x 500W halogen floodlights and some more shots at higher distance (400m) with the 110mm aspheric.
    David (10000LUX at 18x55mm size):
    Or something slightly bigger: Mr.Beambastic ... 500W LED power
    Super Moderator
    DM51's Avatar
    Oct 2006
    Borg cube #51
    Default Re: Handheld 500W LED Power .... finally finished
    WOW!!! Looking forward to the beamshots!
    Resistance is futile...
    Flashaholic ktafil's Avatar
    Dec 2008
    Elsloo Netherlands
    oh my god!
    whats that!
    MiniM@g Cree-Q5 | M@g 4D-ROP-Lo | M@g 2D-P7 | M@g charger 22-Watt bulb 5000mAh NiMh | What is next?
    Flashaholic* Alan B's Avatar
    Nov 2007
    San Francisco Bay Area
    Pretty amazing light, great construction.
    What is the application?
    Endurer 4x18650 4xCree MCE M-bin WH 3000+ lumen, Police Maglite 2D SSR-90 with KD 52mm aspheric and 10A current with LDO10C driver and Red Maglite 5D@Luminus CBM-360 4500K neutral white 5000 lumen aspheric
    Flashaholic* 1 what's Avatar
    Jul 2007
    Australia
    Holy cr**!
    Yikes!
    It's beautiful. Nothing succeeds like excess.
    Oct 2004
    Singapore
    the last photo reminds me when i was looking up to the sky and got abducted by alien UFO
    seriously, good job and waiting for beamshots
    anybody remember the runtime and lumens value of databank?
    Flashaholic* Erasmus's Avatar
    Dec 2004
    Belgium
    You are crazy! I'm passing through Cologne tomorrow on my way to a friend in Slovakia, are you in for a meeting? I will send you a PM straight away
    Yeehaw!
    Enlightened Sandman_Bravo's Avatar
    Jan 2009
    West Bum**** USA
    While I'm astounded at the mere construction and array of lighting, I must ask the question; why?
    To be clear- I mean no offence and I'm not flaming. What is the usage purpose? Was this a project just for fun or do you have some specific application for this? Either way, illumination shouldn't be a problem!
    * BTDT-GTTS-WIO * ~ Adversity Builds Character! ~
    Feb 2008
    Germany, Cologne
    @Sandman_Bravo and Alan_B:
    Main purpose and application of the light was building it...
    Original my intention was to use it for walking and running in the woods, but at this time I thought I could build it with a weight of less than 1,5kg.
    But the more the project proceeded the LEDs I wanted to inegrate and the heavier the thing got....
    I'll try it for a short run in the next days. It might work despite the 2,5kg cause I'm not the weakest....
    I can summarize: I built this light as a versatile hand-light, not an EDC, that is highly usefull (runtime can be for hours if you only use a few thousand lumes ;-)) and a funlight at the same time.
    The 110mm aspherical is a presision tool which offers throw nice throw capabilities for a LED powered light. It certainly can't compete with a 35W or more HID spotlight, but within the LED world it offers more throw than any other light known to me. Will take measurements in the next days, but a first quick luxmeter test over 10m distance showed more than 200000 lux/1m. But I have to measure at farer distances to get accurate value at this large lens diameter (ask Ra for the theory...).
    The 26,5mm ME-Cs offer a ver usable medium beam, would also be a nice setup when used as bike light.
    The 12 MC-E without optics can produce a nice amount of flood light and can serve for application where you might usually use thos 500W halogen floodlights.
    You could use it during camping when powered by the 12V chahrger (not finished yet) or perhaps on my parents small boat, .....
    It's just finished, so time will show what situation this portable sun will be used in......
    Rant Re: Handheld 500W LED Power .... finally finished
    u are mad !
    but i like yr works!
    Flashaholic* Zeruel's Avatar
    Jan 2009
    SIN
    WOW!
    Impressive
    Now if only we can edc it...
    Flashaholic supawabb's Avatar
    Jan 2008
    By far the most impressive light build that I have ever seen! Absolutely AWESOME!
    *Dereelight DBS 3SD *Mag 3D - Malkoff *Pelican 7060 *2 x Lego Surefires (M60 & MC-E)
    The Data Bank is finally BEATEN!!!
    Super Moderator
    DM51's Avatar
    Oct 2006
    Borg cube #51
    Quote Originally Posted by Der Wichtel View Post
    Hmmm... I think it could be a close contest for total output, but the Data Bank 70 should easily beat this for throw.
    Jan 2008
    Saskatoon, Canada
    I needs a name.
    This thing is INSANE though. Very nice work.
    Feb 2008
    Germany, Cologne
    I would not say the Databank is beaten. It is a total different light. It is a true fun light with one impressive type of beam: 70x XR-E behing 30mm aspherics, which results in lot more throw than my creation.
    And it is an mechanical artwork, my light is mechanical functional, but you can see that it is made by an electronics engineer with no professional mechanical equipment nor skills.
    Like I wrote before: I tried to combine useful and fun light, and I thing I managed to do so. Main thing I'm not satisfied with is the 2,5kg weight.
    But regarding total output, it might be true that for half a minute I can beat the databank
    you could have used heatpipes and connect them to cpu cooler. If a cpu cooler can cool down a cpu with more than 150W then you need only 4 of them but then have to use fans.....
    I think 2.5kg is a good weight for passive heatsinking.
    Jan 2008
    Chicago area.
    Holy COW!!!!!!
    Cant wait for the beam shots.
    Flashaholic* DaFABRICATA's Avatar
    Jan 2007
    Michigan
    THATS JUST FLAT OUT COOL!!!
    Nice Job!
    Can't wait for the beamshots!!!
    Flashlight Modifications available upon request
    "I have to go return some video tapes." -Patrick Bateman
    Flashaholic* BSBG's Avatar
    May 2007
    USA
    Amazing piece of work .
    You could attach it to a chest harness for running, with multi levels for woods, roads and airport runways.
    Will work for lights.
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    Bay Area, CA
    WOW, really impressive!
    Looking forward to those beamshots!
    Pure flood mode probably throws more then the average light.
    You can try active cooling. It should cut down the weight but then you'll have to power the fans.
    *Flashaholic* Illum's Avatar
    Apr 2006
    Central Florida, USA
    Drool Re: Handheld 500W LED Power .... finally finished
    I think this might blow the databank out of the water...not sure
    thats a tremendous about of designing that went into it, not to mention capital...holy cow, 20 MCEs and a dedicated driver for each one
    Flashaholic* Juggernaut's Avatar
    Feb 2008
    A place in need of light.
    Faint Re: Handheld 500W LED Power .... finally finished
    I….Can……..Not…….Comprehend…what this would look like running……. this makes me sad inside.
    “What do you mean LEDs are more efficient then Incans?”, that’s just what they want you to think! It’s a Conspiracy, Man!
    Flashaholic* Nitroz's Avatar
    Jul 2004
    Monroe
    I love it when people create these types of Frankenlights! That is quite a chunk of change tied up in one light.
    Aug 2007
    North Texas
    Thats frickin awesome!!!!!!!!!! Can I have it ?
    Feb 2008
    Germany, Cologne
    It wasn't a cheap toy.....
    Flashaholic* TONY M's Avatar
    Jan 2008
    Belfast, NI
    Good lord thats awesome!
    Jan 2008
    Belfast, NI
    Quote Originally Posted by Holzleim View Post
    I'm sure it wasn't but it was worth it.
    Jan 2009
    West Bum**** USA
    I might have a name...
    Die beleuchtete Herzen
    (The illuminated heart)
    What do you think?!
