addictedmatt
As seen here: https://www.candlepowerforums.com/threads/223571 This light is amazing! In fact, it's too amazing. I just can't use it in my tight packed neighborhood. It puts out too much light, but I did enjoy it very much until people started to take notice.:thumbsup: Comes with charger. A note/disclaimer from the builder: "As far as the HID, with the igniter in the body of the light, that means that there's 23,000 volts running from the ignitor, to the bulb and on start up about 5 amps, with running about 3 amps. The fuse is a 10A fuse, in the switch circuit (positive terminal). You may want to take it to an 8A or even a 5A fuse, if you feel it would be better.Also it's an exotic, highly modified light and it does need treatment with some respect. A normal light would only put out a few volts and very few amps. 23kv would kill. That's a fact that must be taken into consideration. Never play with the bulb or wiring while the light is on. Absolutely never....." This is a serious light and should be treated like one. Price is $275 , now $235 now $205 shipped conus. First I'll take it, gets it. Thanks for looking!
