Usually, incandescent are not regulated because an incandescent bulb, if dimmed, becomes yellowish and the overall bulb efficiency, that is already low, gets even lower.
From the other end, you can power an incandescent lamp with a regulated power converter, so the luminosity stays constant while the batteries discharges. This is not very effective with rechargeables, since this kind of battery has a very sharp voltage falloff at end of charge.
In addition, the efficiency of a regulator is always lower than 70%, it means that the 30% of battery power is lost.
The Surefire A2 regulator is designed so that the bulb, that runs at overall reduced power (but not color temperature), keeps it constant over the entire discharge curve of the batteries.
Anthony
