BruiseLee
I bought a Creative Nomad Jukebox 3 MP3 player. It's a 20 gb hard drive based MP3 player. I paid over $300 for it.
I want to return it.
It has the absolutely worst interface of ANYTHING I've ever used. Some of the most basic functions are virtually impossible to perform.
Want to just turn it on and hear some mp3's? You can't. You can play one song. Then you have to go thru multiple keypresses to select another song. Try that while driving your car. Sure, you can use the shuffle function. Problem is, it picks like 12 songs and plays em over and over. Even though I have thousands of mp3's on the drive.
I've had to reboot mine like 200 times? And I've only had it 2 months? Sometime, I can't even turn it on without removing and replacing the battery. Don't ask.
There are multiple levels of the interface that look the same. But you can only perform certain functions at certain levels. Confusing as hell.
The buttons to fast forward, reverse, and skip forward and back are the same. So, if you want to fast forward a bit, and you don't hold the button down long enough, you will go to another track. At least, I think you will. The thing is so damm confusing, and I have a Masters Degree and worked with computers for a major university....
It's very difficult to delete recordings. The reason for that is on recordings, you cant name a song. You just get a time stamp like a dos file. Useless since you can't set a real time clock like on a PC, and your system crashes daily. So, it's easy to delete, you just don't know what the hell you are deleting. Retarded interface asks you if you want to delete a song, where it should say "Delete Dixie Chicks?" or something to that effect.
The thing has actually duplicated files for no reason. That's right, it copied 'em for no reason.
The moronic software likes to double the subdirectories you make. For example, I made a subdirectory or folder for my Beatles mp3's named "The Beatles." Ok, I use the scroll wheel to go to music library, click, then artists, then Beatles. Ok if I click on Beatles, then open, do I see my Beatles mp3's? No! I see another subdirectory called Beatles. It's like using Windows Explorer to click on the Windows subdirectory, have no files in that folder, then have to click down another level to another subdirectory called Windows. It's totally stupid, a waste, inefficient, maddening,....
Using the car power adapter causes the player to lock up. Not everytime, not immediately. But enough that I don't use it, I just rely on charging my player at home and running off the batteries. I find if I try to use the power adapter, the player will crash in about 30 minutes. Scratch that last, tonight the power died so I used the cigarette lighter adapter. After about 3 minutes, the player locked up. I reset with the paper clip, same thing. Reset a third time, same thing. Who ever heard of a device that crashes when you take it off battery power!?! POS!!!
Oh, some songs I want to delete I can't, because the player crashes. I'm screwed there, no solution.
It does have good points, however. Sound quality is excellent. It's easy to record with the player from any audio source. And battery life is excellent. I think I can run the thing for 7 hours on 1 battery, and it can take two. Well, now the battery life has fallen down to about 5 hours after some use, sigh....
I wouldn't recommend this thing to Sadaam Hussein. Did I mention I was supposed to get a $50 rebate, too, which was never sent! That for over $300 dollars Creative was so cheap you get NO printed manual of any kind - just a PDF file on the CD. And that it come with NOTHING to carry it in at all?
Absolutely the worst interface of anything I have ever seen. I'm amazed any company could release a product this bad.
I just discovered another major flaw with the Nomad 3. Summer has finally come to Los Angeles, and it's hot outside! Yesterday it was in the high 90's where I live. The point is, it got so hot in my car that the Jukebox would boot up, maybe run for 5 seconds, then turn itself off again! This has happened again and again. Once the car cools down, the Junkbox, er, Jukebox will work normally. If you live in a place where it really gets hot, like Las Vegas or Arizona, this high tech wonder would be virtually worthless.
Bruise
Bruise
