EAGTAC
Results 1 to 4 of 4
Thread: Conversion Program for Lumens/Lux/Candle Power ?
    *Flashaholic* jtice's Avatar
    May 2003
    West Virginia
    Default Conversion Program for Lumens/Lux/Candle Power ?
    I really wish that all the companies out there would pick a unit of measurment! [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Is there a small program for converting lumens, lux, and candle power?
    Or at the very least, what are the equations for doing so, and I'll make one in Visial Basic.
    Default Re: Conversion Program for Lumens/Lux/Candle Power
    Lumens and Mean Spherical Candlepower (measurements of quantity of light output) are interchangeable. Multiply MSCP by 4pi to get the lumens.
    Lux is a measurement of luminous intensity. There is no meaningful general interconversion to Lumens because of the contribution of reflector, focus, etc.
    Wilkey
    *Flashaholic* Size15's's Avatar
    Aug 2000
    Kettering, England
    Default Re: Conversion Program for Lumens/Lux/Candle Power ?
    There is not.
    Comparing the Lumen ratings to Candlepower ratings is not possible. Even comparing ratings from within some brand's own model range is misleading - especially where CP is concerned.
    SureFire is the only brand that is open and consistant about their Lumen ratings.
    The trouble is that unless you have a SureFire, the other SureFires Lumens are hard to judge until you know the type of beam distribution that SureFire usually go for.
    Therefore Lumen rating are difficult to use alone - some form of light distribution rating (beam angles?) and colour temperature ratings are needed to find out more about the beam (as well as how it changes over the runtime of the batteries.)
    Al
    Flashaholic* shankus's Avatar
    Feb 2003
    Mojave, CA
    Calc98 is a free, scientific calculator for Windows 95 - XP, and has an extensive conversion utility in it, including luminance & illuminace.
    After installation, enter number to convert, and click the "unit" button.
    Units of illuminance:
    candela/sq. in.
    candela/sq. m
    foot-lambert
    lambert
    stilb
    Units of Illuminance:
    foot-candle
    lumens/sq. cm
    lumens/sq. ft
    lumens/sq. m
    lux
    meter-candle
    phot
    You can convert between units of illuminance, or units of luminance, but not from illuminance to luminance.
