Imalent
Page 1 of 15 1234567811 ... LastLast
Results 1 to 30 of 426
Thread: Custom built triple CREE XP-E <> P60 drop-ins - SALES CLOSED FOR NOW
    Flashaholic* Moddoo's Avatar
    Nov 2008
    Minnesota
    Default Custom built triple CREE XP-E <> P60 drop-ins - discussion thread
    New sales thread is now open
    http://www.candlepowerforums.com/vb/...d.php?t=243322
    Use this thread for discussion of performance, drivers, batteries, runtimes, etc.
    To help you all keep the night brighter than the day...
    First ever, triple CREE XP_E P-60 drop ins for sale.
    These R2 models should be around 600 lumens.
    Prototype pics are here http://www.candlepowerforums.com/vb/...d.php?t=233089
    -->>Custom built aluminum heat sink.
    NOTE: these are built for a slip fit into surefire c-series lights for optimum heat transfer
    -->>Carclo 20mm Triple optics
    <>10507 Narrow lens front
    <>10511 Frosted narrow
    -->>20mm board with 3 CREE XP-E R2 WH
    >>Potted 8x7135 Driver with LOW - MEDIUM - HIGH (sorry, no strobe available at this time )
    Designed to work with a single rechargeable cell. 3.6V to 6V max DO NOT USE 2 RECHARGEABLES WITH THIS DRIVER
    18650 recommended
    Current draw at the tail:
    Low= 150mA
    Med= 900mA
    High= 2.5A
    NEW COMPLETE SUREFIRE HOSTS BORED FOR 18MM CELLS AVAILABLE HERE
    Nov 2008
    Minnesota
    Default Re: Custom built triple CREE XP-E <> P-60 drop-ins. PRE-PAY SALE
    HERE ARE SOME PICS OF THE DIFFERENT BEAMS FROM THE OPTICS.
    NOTE, color looks incorrect in the first pic
    10507 Narrow lens front............... >>>>.............10508 Frosted medium
    10509 Frosted wide ................. >>> .................. Malkoff M60F
    Here are some (poorly photographed) tint comparisons
    left=Malkoff M60WF right=XP-E P4 7A .................. >>>> .................... left=Malkoff M60WF right=XP-E R2 WG
    left=Malkoff M60F right=XP-E R2 WG
    Nov 2008
    Minnesota
    Some outdoor beam shots
    Malkoff M60F................................>>>>.......... ....................ADDED R2 on HIGH with frosted wide optics
    R2 triple on LOW with the narrow optics..............................>>>>.......... ..................R2 triple on MEDIUM with the narrow optics
    R2 triple on HIGH with the narrow optics.............................>>>>........... ..................ADDED R2 triple on HIGH with frosted medium optics
    Flashaholic russthetoolman's Avatar
    Dec 2007
    Vancouver, Washington, West Coast
    Are the optics able to be changed by us, the users? Or is the one we order the one we are stuck with?
    I like the spot and then medium frosted if I can interchange.
    If interchangable, what is the cost of an additional optic?
    Thanks
    Russ
    Nov 2008
    Minnesota
    The optics will be assembled with 3 drops of silicone glue on the legs.
    this could be removed and replaced by you.
    (Driver will be potted with a thermal silicone, Arctic Silver beneath leds, This will allow easier disassembly than an epoxy.)
    modify at your own risk
    I do not have a quick change system set up yet.
    You would need to see which one you like best and glue it in.
    If you would like, I will sell you one with the optics loose.
    I will supply extra optics for $8 each
    Beamshots added 8-18:
    Distance = 50 feet
    R2 triple @ 2.8A with:
    Narrow Clear<<<<<<<<>>>>>>>>>>Narrow Frosted
    Medium Frosted<<<<<<<<<<>>>>>>>>>>>Malkoff M30
    Flashaholic FRANKVZ's Avatar
    Jul 2004
    Western PA
    In your outdoor beam shots, which led is used in the triple high shot?
    Dec 2007
    PAYPAL SENT Payment Sent (Unique Transaction ID #9NJ4903221801451M)
    I'll take one, I'm working on the order and Paypal. I will edit here when I am done. It looks about 5-6 weeks to ship out? 7-20?
    Russ
    PS
    could you put the amp draw in the sales thread and battery configuration. I gotta go back and find it
    <>10508 Frosted medium
    20mm board with 3 CREE XP-E <>R2 WG
    Pre-Pay price is $75
    ADD $3 SHIPPING PER ORDER
    extra optic for $8 each
    $86.00
    Please leave optic loose, I will devise a system, thanks.
    Low= 150mA
    Med= 900mA
    High= 2.5A
    Last edited by russthetoolman; 06-05-2009 at 07:45 PM. Reason: Order info and paypal sent
    Nov 2008
    Minnesota
    Quote Originally Posted by FRANKVZ View Post
    The outdoor shots are the R2 LEDs
    Quote Originally Posted by russthetoolman View Post
    Russ
    Yes, I will get them out ASAP. But Cutters parts take a while to get to my door.
    7-20 is a latest estimate.
    PS
    Low= 150mA
    Med= 900mA
    High= 2.5A
    ThankYou
    Jul 2004
    Western PA
    I'll take one with narrow optic and the R2 leds.
    Thanks
    Will this fit and work in an old aluminum Surefire P6? The 16850 does not fit in the light are there other options?
    Nov 2008
    Minnesota
    Quote Originally Posted by crestgel View Post
    I will bore your light to fit 18650 for $10 with your order.
    Yes the drop in will fit your light.
    New bored Surefire bodies are available also
    nfetterly's Avatar
    Oct 2008
    Cincinnati area, but lots of travel
    Very nice!
    Mine is for a FM 1x18650 body - presumably same fit a 6P?
    <>P2 7A WARM
    Payment Sent (Unique Transaction ID #8A958391B7422072P)
    2nd PP payment sent for a bored 6P body (to be included with drop in shipment)
    Nov 2008
    Minnesota
    Quote Originally Posted by nfetterly View Post
    Very nice!
    <>P2 7A WARM
    Yes, th FM body will be fine.
    Thank You
    Feb 2009
    Birmingham, AL
    Can you bore SureFire Weapon Lights? I got a 951 that might could use a new dropin.
    Nov 2008
    Minnesota
    It looks like it would bore just fine, send it over.
    The "neck" for SF weaponlights has a different interior profile vs. SF Classic handheld tubes. That's why the solid body Malkoffs often need a fitting ring to make electrical ground contact. Can you verify that your heat sink shape works reliably with weaponlight tubes? Does the driver cavity have a little ledge or stop where the board can sit so that it doesn't get pushed in any farther under pressure from the battery stack?
    Nov 2008
    Minnesota
    Quote Originally Posted by Justin Case View Post
    Thanks for the info man.
    I will verify the fit when it is received.
    If needed, I can have some customized to fit.
    The driver does sit on a ledge, and it is fully potted.
    Flashaholic* tx101's Avatar
    May 2008
    London UK
    Im very interested but do you ship Internationally ?
    Nov 2008
    Minnesota
    Quote Originally Posted by tx101 View Post
    Of course, $3 extra should cover it.
    I'll take an R2 with the narrow optic. + a Defender body.
    Flashaholic USM0083's Avatar
    Oct 2007
    Frisco
    Hello!
    Can you build one with a single mode driver (high)?
    Quote Originally Posted by Moddoo View Post
    This is good news.
    Can we get it to fit this?
    Surefire 617FGA Forend
    http://www.surefire.com/617FGA-Shotgun-Forend
    It uses a P60.
    Flashaholic Policetacteam's Avatar
    Jun 2006
    Iowa
    I'm also interested in this idea.
    Can you explain how the 3 modes work. Example. Tap once for low...tap again for medium, etc...
    Superior gear will never make up for lack of training or attitude
    Surefire M2 w/ Malkoff M60 & Z48, 8AX Commander, Surefire M952XM07 Millennium Universal WeaponLight System w/ M60, X200B, G2 LED w/ M60, G2 w/ M60W, SL-60, EagleTac T10LC2, Fenix TK10, Fenix T1, Microstream
    Jun 2006
    Iowa
    Moddoo,
    Unless I missed it I did not see a beam shot for the frosted narrow (10511). Also can you provide any pics of what the frosted lenses look like (either out of the light or in it). Thanks!
    Nov 2008
    Minnesota
    Quote Originally Posted by USM0083 View Post
    Hello!
    Yes, I will look into getting some single mode boards
    It CAN be done
    It uses a P60.
    Yes, the drop in can fit it. I may need to make a custom diameter for it.
    Either give me a good measurement, or send it to me for inspection.
    Quote Originally Posted by Policetacteam View Post
    Yes, it is a on/off type of mode change. It has memory of the last mode used.
    Moddoo,
    I am sorry, I do not have a frosted narrow. I will order some tonight. They will not arrive for about 2 weeks though. I would guess the beam will be the same as the narrow 10507, but with a softer rounder shape.
    here you go
    10507 narrow, 10508 frosted medium, 10509 frosted wide
    Hello!
    You could make a 2-board parallel sandwich using a DX1885 3xAMC7135 board, for example. The trick is if the driver cavity of the heat sink is deep enough to fit a 2-board AMC sandwich and if the ledge/stop can be machined taller for the sandwich.
    Another alternative, though expensive, is to use a 2-board GD1000 parallel boost-buck sandwich to give you a GD2000 (I'm assuming 1x18650 operation here). If you wanted more juice, you could use a 2xGD1500 sandwich. These boards are only 14mm in diameter so they will fit inside of the driver cavity. The trick again is if the driver cavity depth can accept the sandwich. Then you have to use some technique, such as filling the cavity with thermal epoxy to get the sandwich flush with the bottom face of the sink. Then solder on a conical spring. The end result probably would look somewhat like a Malkoff drop-in.
    A third method is to disable the PWM controller on the supplied AMC7135-based driver board to get single mode operation.
    Moddoo, how deep is the driver cavity? I assume that the ledge/stop is also set up for a single driver board PCB thickness, not a 2-board 17mm sandwich?
    Nov 2008
    Minnesota
    Hey man,
    I have TONS of room for drivers. I could fit a stack of 10 in there.
    Anyway, I will consider you thoughts on drive current and regulation.
    From what I have heard, the XP-E R2s typically have a nice low Vf.
    I do not have the correct power supply to take accurate measurements. But I could find one.
    They are really bright on a cr123 DD.
    I'll spend some time experimenting.
    on the single mode,
    Yes, I could easily run 2 boards sandwiched.
    supply is a factor.
    the cost of shoppe boards is pretty high.
    I am more than happy to install them at the customers cost.
    We have a few weeks until the solder hits the boards.
    I am open to suggestions on this project.
    Jun 2006
    Iowa
    Moddoo,
    Thanks for the pics. With the 10508 (medium) in place do you still need to have the flashlights glass lense replaced or does the 10508 serve as the new lens for the light. If I'm not making much sense...does my stock glass lense go on top of the 10508?
    Flashaholic* ANDREAS FERRARI's Avatar
    Aug 2008
    The Great White North
    I have to tell you Moddoo those are great prices for an item of this quality-I'm guessing your not making any money off this rather providing a needed service(and an unique droppin')to your fellow CPF members.
    My girlfriend said if I bought one more light she would leave me...........I'm sure gonna miss her.
