Klarus
Page 5 of 6 FirstFirst 123456 LastLast
Results 121 to 150 of 180
Thread: Simple guide to using a DMM for measurements
  1. #121
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Re: Simple guide to using a DMM for measurements
    Quote Originally Posted by njet212 View Post
    I did things just like on your picture. I'm bit confused, if i'm doing thing just like your pic, I'm I measuring volt battery or current draw?
    That way you measure the current draw only, but not at a specific voltage. The voltage you measure before or after, on the battery, is without load and will be considerable higher than when you measured the current draw (especially when we are talking about the Preon ReVo at high).
    When doing this kind of current measurement it is best to use a fresh (or freshly charged) battery and then only specify battery type, not voltage.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
  2. #122
    Flashaholic njet212's Avatar
    Jul 2009
    Indonesia
    Thanks for the answer HKJ, appreciate that!
  3. #123
    Flashaholic* fisk-king's Avatar
    Apr 2009
    close to U.N.A.
    Great work & thread
    "Now they will know why they are afraid of the dark. Now they learn why they fear the night."-Thulsa Doom PAYPAL FEE CALCULATOR; list of lights.
  4. #124
    Jul 2009
    Indonesia
    HKJ, last time was asking about how do you measure standby current on a flashlight and you did answer it already. But today i tried to look at it again but i realized your post was missing.
    Would you mind to explain it again ? the flashlight i'm going to measure is New Jetbeam RRT-0 Infinite Variable Brightness version. I was wondering how much is the standby current because it's suck all the juice on my AW RCR123 just only in a week !!
    Thanks
  5. #125
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    That light is supposed to have a real on/off switch, i.e. no current draw when switched off on the tail switch. If you want to measure the current draw with the ring in off position, you can just use the "Current consumption" chapter, but you will need to use the "mA" socket, not the "A" socket.
  6. #126
    Jul 2009
    Indonesia
    Thanks for your answer HKJ
  7. #127
    HKJ,
    Many thanks for posting this. It is extremely helpul and beautifully illustrated and explained.
    Brightnorm
  8. #128
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Added a "High current measurement" showing how to use a clamp meter.
  9. #129
    Flashaholic* Walterk's Avatar
    Jan 2010
    Netherlands
    Very nice ! And clearly illustrated, thx for this thread.
  10. #130
    Flashaholic* Viking's Avatar
    Jul 2010
    Denmark
    I have a cheap Velleman DVM92 multimeter.
    Specs are:
    3 ˝ digit ( maximum display 1999 )
    Accuracy DC voltage +/- 0,5% of rgd +/- 1 digit
    Accuracy DC current 20mA +/- 0,8% of rgd +/- 1 digit
    Accuracy DC current 200mA +/- 1,2% of rgd +/- 1 digit
    Accuracy DC current 20A +/- 2% of rgd +/- 5 digits
    Is the DMM accurate enough for measuring flashlight batteries , or will you recomend me buying a better one.
  11. #131
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Viking View Post
    For LiIon batteries the charge voltage is usual 4.2 volt +/- 0.05 volt, as long as you batteries does not read above 4.2 volt on you DMM they are below 4.25 volt (According to the DMM specification below 4.23 volt).
    Most chargers will be more than good enough and you do not need to check the batteries each time you take them off the charger.
    Where it is important to check batteries is when you run them down, many LiIon batteries can get dangerous if you discharge them to low, to check this does not require much precision from the meter. If the battery measures below 2.5 to 3 volt (After they have rested some time), there is a risk they may explode when charged. This is a cumulative effect, each time they get discharged to much the risk for explosion during any subsequent charge will increase slightly.
    Batteries that show 0 volt on the meter might not be discharged to much, it is probably the protection that is tripped. If you charger can reset a protection (See my charger reviews), give the cell a second in the charger, then take it out and check the voltage again. If the charger cannot reset protection you need to wire it parallel with another LiIon cell for a second.
    And if you DMM's reading suddenly are a bit beside the expected values, you probably need to replace the battery in the meter.
  12. #132
    Jul 2010
    Denmark
    Thumbs up Re: Simple guide to using a DMM for measurements
  13. #133
    Flashaholic Tohuwabohu's Avatar
    May 2008
    Germany
    The tailcap is removed from the flashlight and the meter is substituted for that connection, i.e. one probe pin is placed on the battery and the other probe pin is placed on the battery tube, where there is some bare metal. Placing the probe pin on anodized metal will not work.
    As can be seen, the two meters do not agree on the value. That is because the current draw is not really DC, but drawn in very fast pulses, the meters does not sum this the same way. This is only a problem on some flashlights.
    Hello HKJ,
    have you ever tested the resistance of the probe leads of the cheap DMM?
    I got a Best DT9205A today to compare it too a good multimeter. The DT9205A is not very accurate but usable but the probe leads are crap, their resistance is far too high. I measured 0.46 ohms - ten times the value of some probe leads from another meter and more than 50 times the value of a pair of short leads with banana plugs on both ends.
    I don't think that fast pulses cause the wrong reading but the voltage drop across the probe leads makes the regulated light draw a higher current.
    Of course the effect of the high probe lead resistance gets worse with pulsed currents.
  14. #134
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Tohuwabohu View Post
    Hello HKJ,
    The test leads is probable part of the reason.
    I have been testing some leads, switches and dmm's:
    JetBeam M2S Tailcap 70 mohm
    ThruNite TN11 Tailcap 85 mohm
    4Sevens Quark X AA2 Tailcap 82 mohm
    Fluke 289 10A range 33 mohm
    Fluke 189 10A range 55 mohm
    Fluke 179 10A range 35 mohm
    Vichy VC99 20A range 48 mohm
    Best DT9205A 20A range 18 mohm
    Fluke test lead (x1) 38 mohm
    Fluke test lead (x1) 51 mohm
    No name test lead (x1) 257 mohm
    No name 10A test lead (x1) 22 mohm
    Doing a test with 10A current and measuring the voltage from test probe tip to test probe tip:
    10A Tot. Res
    Fluke 289 + Fluke test lead 1.02 volt 102 mohm
    Fluke 189 + Fluke test lead 1.16 volt 116 mohm
    Fluke 179 + Fluke test lead 0.97 volt 97 mohm
    Best DT9205A + No name 10A test lead 0.59 volt 59 mohm
    The connection resistance from test probe tip to current source is not included.
  15. #135
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    so the ZTS battery tester (the one that supports 3.7V li-ions) can do protected cells fine?
  16. #136
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Yes, there is no difference between a protected and unprotected cell in this regards.
  17. #137
    Dec 2005
    Georgia Highway 441
    oh okay, thank you! I had been misinformed in the past that the protection circuits kept those cells from being accurately tested by the pulse load.
  18. #138
    Apr 2011
    Bucharest, Romania
    I see that many of you ask why some multimeters do not display zero.
    For TrueRMS meters this is normal. They will not display zero, it's about how the processor makes the measurement.
    On Flukes seen here: 87, 179, 189, etc, calibration manual tells you which value is the calibration check on each scale. Eg: a Fluke 189 that has 5.0000 on it's input and reads between 4.9997 and 5.0023 then it's in spec. Next value is ten times the first one, in this case 50V and 500V DC.
    Good probes are below 0.1ohms each. Cheap chinese one are higher than that.
    Measurement of very low resistance can be done conveniently with an AC ohmmeter, or ESR meter.
  19. #139
    Jan 2012
    Ontario Canada
    I want to check the open voltage of my battery charger, and I think this is what you call it when its plugged in and no battery installed. [Sorry, not much electrical knowledge]
    My charger is labled at 4.2V output. Do I simply plug it in and attach each DMM probe [auto range set to AC V?] to the pos. and neg. sides of one channel?
    When I did the above I get a reading of .027V?? on the auto range setting.
    Does this make sence?
  20. #140
    Nov 2011
    Kapolei, HI
    My DMM set on DC reads 4.87v off my WF-139 charger.
  21. #141
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by loquutis79 View Post
    Evert thing except the AC V part makes sense, try using DC V.
    But the open voltage does not say much about anything, the charger is electronically controlled and the open voltage might be above or below 4.2 volt, depending on how the electronic does the controlling.
  22. #142
    Jan 2012
    Ontario Canada
    That makes more sence now. Told you I know little about electrical stuff :], but willing to learn.
    OK, now I get 4.2 from both channels.
    Just trying to learn as much as I can, and like to re produce some of the tests I see here on the site. While waiting for a Pila charger for my 18650's I am using an Ultrafire WF139 [don't throw anything at me!], and as there are so many negitive posts I want to check things out where I can.
    Thanks for the supper fast replies from you both. Now I can tell the wife that its not just me who spends weekend mornings reading about flashlight stuff.
  23. #143
    Jan 2012
    Ontario Canada
    So what I did next was to check voltage during testing. I did the tin foil at both ends of the 18650 while in the charger and attached the DMM leads to each side.
    As I knew the batteries were fully charged just last night, minus a bit of playing on turbo after that, I knew that it should not take long to light up the green lights on the WF139.
    So I watched for the few minutes until the light changed and what I saw was the following:
    1st -red light = charging. 4.21V-4.24V during this stage.
    2nd-green light = full charge. DMM jumped right to 4.59V
    I left it on only for a couple of minutes and then pulled the plug.
    Results = hurry up with the Pila charger order??
    Or did I miss something here also. It that an viable test?
  24. #144
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Do not worry to much about the voltage, that was because the over charge protection in the battery tripped. The charger would have stopped soon enough if it had not tripped. The "problem" with the WF-139 is that it measures the voltage with the current turned off and that means it goes above 4.2 volt with the current on (The current on/off is to fast to reliable measure with a DMM).
    I had the same happen when I tested the WF-139.
  25. #145
    Hi HKJ, can you recommend a Fluke DMM mainly to test and check batterries voltages and Mah?
  26. #146
    Flashaholic* uk_caver's Avatar
    Feb 2007
    Central UK
    A DMM isn't any use for measuring mAh (battery capacity), unless you use it to make repeated measurements of cell voltage as a cell or battery is discharged at a known current.
  27. #147
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by rjking View Post
    Measuring mAh is not something you can just do with a DMM, a hobby charger is much better for it.
    I often use a Fluke 179 DMM for various tasks, but for just checking batteries it is way to expensive, a Fluke 115 would do for that.
    The 115 has a 6000 scale, i.e. you will get battery voltage with 3 decimal digits, but the DMM is missing the low current ranges and cannot be used to measure low modes current draw and standby current with.
  28. #148
    Quote Originally Posted by uk_caver View Post
    Oh okay. So the only way I can make sure that i'm putting 2 x CR 123 or 2 x 18650 with similar capacity level is by checking on their voltage then, is that correct? Man, that Fluke 115 is way too expensive. Thought, there's something half the cost.
  29. #149
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Yes.
    Fluke is rather expensive.
    For checking batteries just about any cheap DMM can be used, but many cheap DMM's shows a wrong value when the batteries are running low.
    If you want something more than a cheap DMM, then a good DMM for the price is UNI-T UT61E.
    You can also get a "cheap" Fluke (17B), but it is only sold in China (You can find it on Ebay). It looks like a decent DMM.
  30. #150
    Unenlightened staffyman's Avatar
    Apr 2013
    Great Britain
    So, I've read your guide, but I'm none the wiser.
    Nothing at all to do with the guide, it's me - I need to read things over and over again before it sinks in.
    I'm not very savvy with electronics either but if I read it a few times and keep referring back to it when needed then I'm sure I'll be ok.
    My multimeter came with a little booklet but only gives specs and isn't a guide to how to use it.
    I've only ever used it to measure that voltage is present but now I can refer to your guide, I'll be able to use it correctly.
    Many thanks.
