ElectronGuru
Here's a subject right at home in the Cafe, coffee making.
Drip makers send hot water through a paper filter holding coffee grounds into a separate pitcher (carafe). Once through, the finished coffee sits in the carafe (metal or glass), which itself is sitting on a hot plate.
Percolators send hot water, through a metal basket holding coffee grounds. Once through, it reenters the heated lift system and again travels through the metal basket and again through the coffee grounds, increasing the saturation with each trip. When done cycling, the finished coffee sits in the same (metal) chamber used to heat the original water.
What do you prefer and why?
