Smaug
Beam: 10
If you could only choose one beam shape, let this be it. The beam is a flood, but with a hotspot in the middle, which gives it a good throw. The flood of light illuminates the ground at your feet, and also the smaller branches and spiderwebs you might otherwise walk into. Meanwhile, the hotspot is lighting the trail ahead nicely. I would suspect this beam is good for at least 80% of all lighting tasks.
Construction: 9 Solid. I think I would barely flinch at all if I dropped this onto concrete. The shape is less thin that I would have thought from looking at online pix. It fills the palm of your hand nicely, without sticking out far enough to screw up the excellent balance. Also hard to see in internet pix is the crinkle finish on the polymer, which is very nice. I deducted one point for the slight battery rattle. On a lesser flashlight, I wouldn't have bothered, but it is really the only flaw in this light. Streamlight probably did it to make sure that any AA battery would fit, no matter how cheezy and out of tolerance.
-Polymer vs. Aluminum-
A polymer light like this won't quite give you the same fuzzy feeling inside as a finely finished aluminum light. It gives you a different feeling, one that is just as good: Invincibility. If you bang the hell out of this one, it won't bother you to notice gouges and such. It never needs to have aluminum powder cleaned out of its threads. It doesn't feel as cold to your skin when it's cold out. It is just super rugged and super low maintenance. You can throw it in your toolbox without a care in the world. Although aluminum is rugged too, most people wouldn't do that.
Overall: 9.8
Without being too wordy, I will just say that I don't believe there is a better all around flashlight to be found for $24. It is solid, rugged, and the perfect size and weight. Back pocket, glovebox, toolbox... whatever.
Overall: 9.8
