Smaug
Construction: 8.5
This thing feels very solid, more so even than my Streamlights. I think you would have to go to work with a hammer to harm this thing. That is what you have to do to offer an unconditional lifetime warranty, eh? The thing that gets me though is how a company that makes dive lights can not make this one model watertight? It has an O-ring where you screw the head out, but it doesn't have one between the lens and the bezel. The body of the light is made of polycarbonate, which seems stiffer than the polymer on the Streamlights. It seems to have very thick walls. The clip is outstanding, as long as you realize that it has limitations. It has a little notch on the body of the flashlight which makes sure that it will NOT slip off, once clipped onto something. The tail switch is nice. The keyring is a joke. It's not that the L1 is too big, it's just that it's shaped such that if you carry it into your pocket, the clip or gripping nubs will dig into your leg. You're better off removing the keyring and just clipping it somewhere or putting it in a pocket that isn't against your skin. Mine is clipped securely underneath the passenger seat of my motorcycle.
Beam: 10
I don't think you can get a better beam out of such a small flashlight. It is a bit stronger than the ARC AAA's beam, at the cost of constant brightness and more expensive batteries. I replaced one of the LR44 button cells with a nut and the brightness hardly went down at all. Now it draws about half the current and I think that will extend the battery life a good bit. The beam shape is a strong spot, probably about 25 degrees with lots of dimmer light spilling at a wider angle.
Overall: 9
This isn't a light that you will want to use for long periods at a time because of the battery expense. If you recognize that it was built as a backup light, always waiting, always ready, but never in the way, it is just the thing. I bought this light as a glovebox light for my car, but have since switched it as the 'glovebox' light for my motorcycle. (In the car, I now have a PrincetonTec Attitude for the longer run time) Many people have said the L1 it makes an excellent everyday carry light if you grind off the clip. I think I would also grind off the nubs behind the finger dents, as those dig into your leg too. it would be a shame though to get rid of that nice clip.
-Miscellaneous Dig-
What is taking Pelican so long to get into the LED game? They make such nice stuff, it is a shame to see them missing the boat...
Beam: 10
Overall: 9
-Miscellaneous Dig-
