I used numbers those numbers for simplicity. I think we need to have OP provide us with the desired LED/Vf and we can go on calculating from there. I won't speculate any more until then
I can see how there can be a considerable improvement in total system efficiency with a particular setup, but that does not necessarily translate into longer run time either. Anyhoo, waiting!
... I've created a monster.
What I have is a
Groovy with an AWR LDO sandwich and a Luxeon 3. (Note, this is older technology than what was originally included with the Groovy when it was in the concept stage!) While pursuing the expensive options, (a new light engine starts at around $60, and my awesome custom idea is also hella expensive) I'm also looking into cheaper ways of powering the little bugger, as while it'll run on primaries, it'll sit up and shout on 3.7v IMRs. I like that, but runtime is short and it runs hot... and the driver has no low mode, making
any use with 3.7v run hot and short.
I'm not ruling out the idea of an emitter swap, if I don't have to find a compatible 17mm Fraen reflector/optic... or matching the two is easy. What I'd really like is a cooler, longer-running, but very nearly as bright light... by swapping my red-label AWs for blue-labels.
I suppose it's possible to try and get better efficiency by switching to a slightly lower voltage battery chemistry, but if efficiency was the only reason for making that switch, that seems a strange thing to do if the other consequences (capacity, runtime) are negative.
Well, having only played with IMR batteries, the LiFe batteries are about the same capacity and better efficiency, it should run cooler (and thus, more efficiently).
Quoting Wikipedia again, LiFe has very nearly the same energy/gram that LiCo has, in theory, just at a lower voltage.
Code:
Cathode Material Average Voltage Gravimetric Capacity Gravimetric Energy
LiCoO2 3.7 V 140 mAh/g [B]0.518[/B] kW·h/kg
LiMn2O4 4.0 V 100 mAh/g 0.400 kW·h/kg
LiFePO4 3.3 V 150 mAh/g [B]0.495[/B] kW·h/kg
Li2FePO4F 3.6 V 115 mAh/g 0.414 kW·h/kg
