Vynce
I'm looking for a boost converter to power an LED strip from a set of batteries. The LED strip consists of 30 blue (3mm or 5mm) LEDs in some kind of mixed series/parallel configuration. It is designed to run on 12V. I want to power it with four AA NiMH batteries in series (4~6 V).
Here's the measured current draw at various voltages:
80 mA @ 10 V
180 mA @ 12 V
285 mA @ 14 V
I think that either a constant voltage source at 12V or a constant current source at ~180mA would be ideal. Adjustable brightness is not required. I would also like to be able to optionally power two of these strips at the same time (I assume that wiring them in parallel at double the current would be ok).
Any suggestions on which Sandwich Shoppe product would suit my needs best? I'm comfortable with SMD soldering if any modifications need to be made.
80 mA @ 10 V
180 mA @ 12 V
285 mA @ 14 V
