kosPap
Hi all!
With the delivery of my 18mm bored Solarforce L2M a new plan started formulating…
Why run primaries when there is space left to be used. So I ordered some Ultrafire 18350 unprotected rechargeables from KD. Then I had 2 off them and could not resist trying them with a high output Xenon.
So I run a comparison runtime test with two AW 17500s also….Both batts are rated in 1100mAh BTW…
Data is:
- Solarforce L2M with extenders to match
- Chinese Xenon 7.4V 15W Bulb
- My Lightbox and my DX meter
Here is the graph:
Notes:
- Jumps on the AW runtime were created when I shook the flashlight while facing down…Maybe we need a more affirmative bulb contact setup?
- I stopped the Ultrafire measurements at 34 lux, then I measured the batt voltage. 3.28 and 3.17…
- in the AW case the cell protection cut-off but cell voltage was 3.5 and 3.18! these were also matched in a Ho-9 setup form the start….
- Previous measurements of known combinations were inserted in the graph for good reference…
Now can anyone be helpful in making an estimation of both batts real capacity?
Data is:
Here is the graph:
Notes:
