Well ok not just advice but lots of it if possible guys.
Firstly is there any of the modders on here that actully build packs for people?
If not I don't know what I'm doing but i'm more than willing to give it a try.
I'm trying find out what I would need to put together a lithium ion pack to power a 12v 35w bulb for as long as possible,its basically to power my lamp for night shooting all on footand i'd like it all to fit in a box with internal dimensions of L130 W68 H46, any suggestions as to what sort of power rating I could squeeze into this with all the electronic trickery. I don't know what all the pcb/pcm/cmb do or even if they are all needed but hope someone can help me out there. I know using 18650 maybe the way to go and they arn't that expensive so its down to know how and then the electronic parts and so on.
I've looked at some of the battery space ones and either they are cost prohibative or mostly size issue and also the discharge I'd like a connector that deben use as I can then just plug and play with he lamp. Any and ALL advice greatly appreciated as always.
Lastly if the box size is a real issue to fit things in then I guess I could go very slightly bigger if it made things easier.
Many many thanks all
