I think what the OP has in mind is not to focus the light through the eyepiece, but to replace the entire eyepiece assembly by placing the light source at the reflector's focal point, and thereby using the reflector to send the light out into space (or whatever target he points it at).
It's actually a pretty good idea, and I think there are some fairly large astonomical-size telescopes with good optical-quality reflectors that can be picked up quite cheaply.
The main problem is that these reflectors are all quite shallow in profile, so only a small proportion of a light source will actually strike the reflector unless it is focussed towards the reflector. Unfortunately in doing that, the point-source of light becomes much larger unless a complicated elliptical focussing system is used, so collimation is difficult.
There's a
very good thread here that should interest you, if you haven't seen it, where a relatively shallow-profile reflector is being used.
