I work for the UK border agency and spend part of my time on ships and in evironments that require an intrinsically safe flashlight. We are issued with an assortment of Bright Stars and Ever Readys but I am looking for alternatives-any suggestions?
Welcome to CPF!
You should not act unilaterally and use your own torch/flashlight for the application you mention.
Use of any equipment other than that supplied by your employer in classified hazardous areas is likely to be 'in breach' of the Dangerous Substances and Explosive Atmosphere Regulations 2002 (DSEAR) (UK implementation of the ATEX Safety Directive), the Provision and Use of Work Equipment Regulations 1998 (PUWER98), the Equipment and Protective Systems Intended for use in Potentially Explosive Atmospheres Regulations 1996 (EPS) and/or the Health and Safety at Work etc. Act 1974 (HSW).
I'm not sure that the Merchant Shipping and Fishing Vessels (Provision and use of work equipment) Regulations 2006 applies to those boarding 'ships' to perform inspections unless operating from another vessel but it appears to enshrine the same safety requirements.
Work equipment (such as illumination tools 'torches/flashlights') must only be brought into service if the explosion protection document indicates that they can be safely used in an explosive atmosphere.
Whilst it may be that the equipment you want to use is actually suitable, perhaps even rated for a more hazardous area than the Zone(s) you will be working in but it is the legal duty and responsibility of your employer to ensure the equipment is suitable - it is safe and all those who could use it have been trained in its safe operation & maintenance etc.
There is likely a process to get a new item of work equipment into the Explosion Protection Document, perhaps made easier if you provide copies of the ATEX safety test certificates, operating manuals and other materials such a risk assessments. However, I doubt the UK Border Agency are comfortable with the use of personally purchased work equipment, especially for use in potentially explosive atmospheres. Health and Safety Representatives and/or Representatives of Employee Safety would likely need to be consulted about any changes or additions of non-standard work equipment. What is 'okay' for one individual employee may not be appropriate for 'all'.
You may not realise all the safety consequences of adding a new item of work equipment to the mix. This may seem like a lot of fuss but the bottom line is that you, your co-workers and your customers go home every day safe and healthy able to live your lives beyond work as well as return to work and perform your jobs.
