Mr. Bulk made me one of (edit a very limited number of) LGI Shorties. This has a very bright 1W HD in a Legend LX body.
Charlie made so few of these direct drive beauties because:
(a) it is unsustainably overdriven on a pair of 123's and
(b) the head is unnecessarily large for an NX-05 collimator.
On the other hand, it is spectacular with a single 68 mm long 16.5mm diameter Li-Ion battery. It did look strange with a little NX-05 in the big head pressed against an O-ring suspended in the middle of the lens.
Using Charlie's advice I trimmed an Electrolumens 30 mm collimator (trim off the rim with "nippers" and file down rough edges and farkle so that it fits.) The trimmed active lens portion 30 mm fills the Legend LX head as if it were designed for it.
This is a very nice light that looks stock (except for the absence of the rubber band around the head that I removed for heat transfer purposes.)
