Isthereanybodyoutthere
- Joined
- Jan 30, 2008
- Messages
- 170
What reflector /lens and batterie for a HID
I bought a Hid set ,and plan to mod /build a HID spot/flash light
The small spotlights most often has a 6volt 4ah lead battery inside
But no room for the hid ballast
been thinking about using some 18650 and make a removable pack
should i use protected (might give start problems )
Will charge them on my standard 139 charger from XX store (two at the time
the ballast can handle 16 volt ,and is suposed to work down to 9 volt
4x4,2=16,8,but will sag under load so no problem
i have tested 4x18650protected ,and they start up and stops
Most likely the protection kicks in
using 4x 4,2 volt will draw less amp than 3x4,2 volt
i would use 4x 2paralel(or 3paralel) =16,8volt
Or 3x3paralel (or 4paralel)=12,6volt
but if i use unprotected and 4x4,2volt ,i can run the cells down to 2,25volt and still have the 9 volt
That would NOT be good for the cells
using 3x4,2=12,6,the light would stop working at 3,3volt pr cell
modding a existing spotlight will be done
but would like to try to build one up from scratch
the reflector in most HIDS i have seen is BIG to give a good throw
but is there a reflector lens combo that is around 3,5 inches that gives good throw ,spill is not needed,but the spill should not just be wasted
