poormanq45
- Joined
- Nov 13, 2009
- Messages
- 81
I have a Mag85 using 9AA cells.
I don't currently have a good battery charger that can charge individual batteries. This obviously leads to a problem of an odd battery.
I was thinking about all the things that I have for cars and my four wheeler.
I first measured the voltage on a regular car battery charger. That reads 16.5V. A little too high.
I then measured my battery maintainer. It read 13.8v. I think this is perfect.
The battery pack measures 13.05V, 1.45 per cell, hot off the charger. I know that you need more input voltage to overcome the internal resistance on the battery.
The charger is rated at 1.5amps normal charge. I don't know the trickle charge rate.
Is it ok to use this charger?
Is the voltage put out enough to top off the batteries?
Am I going to blow something up?
Is the 1.5amps too much?
Thank you for your help.
