Would like to know how to convert C/P to Lumens or vise-versa. I have a one million C/P hunting lamp and would like to know what it is in lumens.
Method 1: Use the candela (millicandela) to lumen
conversion wizard. You need to know the beam angle. I'm not convinced the CP figure is anywhere close to accurate, though, so use with caution.
Method 2: Calculate as Josey said. In these parts, 500,000 CP is typically used for 25 W halogen spotlights, 1,000,000 CP for 55 W spotlights, and 2,000,000 CP for 100 W spotlights. So a 1,000,000 CP spotlight
here would be around 55 W x 20 lm/W = 1,100 lumens. Your Lightforce spotlight would presumably throw better and might well have a more efficient bulb, so 100 W x 22 lm/W = 2,200 lm.
That doesn't necessarily mean you need 2,200 lumens of LED-sourced light - John_Galt wasn't just being smart. I have a 2,000,000 CP, 100 W, 6 V SLA rechargeable spotlight. I'm sure it doesn't perform as well as your spotlights do but I stopped using it after I bought a 3xAAA zoom head torch for $9.90 from DX and was surprised to find it a whole lot more impressive than I thought it was going to be. I figure it produces somewhere around 200 lumens with fresh batteries but in spot mode has similar performance to the SLA spotlight, and it's
much smaller, lighter, more versatile (zoom head), and has a
much longer run time, while running on rechargeable batteries.
So a direct lumen comparison isn't always going to give an accurate result. There are other things to consider, like how the light is being thrown, and how tightly.
Sorry, I have no idea of an LED light that might be ideal for you.
