The Trustfire TR-001 is a remarkable charger, with some good properties for very little money. It has a true CC-CV charging algorythm for instance, and it accepts either line voltage or 12V DC from your car! It will charge virtually ANY Li-ion battery, and has spring-loaded bays so there's no need for spacers etc! All sizes from 16340 to 17670 and 18650 are charged without any problems.
It has, however, two major drawbacks:
1. charging voltage always is a little too high (4.22 - 4.24V)
2. it NEVER switches off, even when the LEDs go green, indicating full charge! You have to remove the batteries from the charger as soon as the LEDs turn green!
The first drawback can be overcome by a small mod! The second one is built into the design of the charger, you'll have to monitor it constantly. When the LEDs turn to green, remove the batteries from the charger and unplug it from the wall outlet.
What's needed for the mod?
1. a #1 Phillips screwdriver,
2. a soldering iron,
3. a multimeter, with a good, accurate 20V DC range,
4. a few resistors, ranging from 470k to 680k.
And here's what to do:
1. measure open voltage in one of the charging bays and remember it.
2. open the charger. Take care, one screw is UNDER the sticker! Just pierce it with the screwdriver.
3. locate R12, a tiny SMD-resistor (330k-ohms). Remove it by using the soldering iron, taking care not to damage anything!
4. now, put the charger together again, without the screws, and measure voltage on one of the charging bays. It should be about 4.15 Volts. This indicates you didn't ruin anything :thumbsup:
5. Was the initial voltage around 4.22V? Then try an extra resistor of 470k in the place of the resistor R12 you just removed, this can be any normal resistor. You can bend it in such a way, that you can solder it around the pins of the 1000uF/16V electrolytic capacitor on one side, and one of the pins of the TL431 on the other side. Just follow the PCB-tracks and it will become clear.
Did you measure more something like 4.24V? Then try a 680k resistor.
In all cases: close the charger after modding it, and measure voltage again. Not fully OK? Try a LOWER resistor to INCREASE voltage and vice versa. By using the right resistor (best buy a few in the range from 470k to 680k or 820k, with all values in between from the E24 series) you can adjust the voltage very accurately.
6. Want to upgrade your charger even more? Then, replace that low-quality electrolytic capacitor (1000uF/16V) by a good one. A 1000uF/10V(!) high quality, 8mm capacitor with a pitch of 3.5mm will fit the PCB! The one fitted now is too big...
Take one with the lowest ESR you can find, and is no higher than 15mm (0.6").
Farnell or Digikey or RS components or another electronics vendor will have them. For example Rubycon has some excellent capacitors for SMPS (Switch Mode Power Supply)-purposes.
7. After everything is OK, put the charger together, replace the screws, be sure NOT to overtighten them,
8. Be confident your batteries will from now on be charged to the brim, but NOT be overcharged by applying exactly the right voltage... I use this charger for any battery I have at hand, ranging from Ultrafire 16340s, to AW 18650-2600s and AW IMR 16340s. All charge very well :thumbsup:
Happy modding!
Timmo.
Happy modding!
Timmo.
