csshih
Greetings Everyone,
Up for review is the Quark RGB Cool White, the first full production flashlight to use the Cree MC-E in RGB.
Here are some of the specs from 4sevens.com
Note: the light was provided by 4Sevens for evaluation.
Onward, shall we?
I've been neglecting packaging and acessories on some of my reviews lately soley because they were pretty much lacking. 4Sevens lights all have pretty good packaging, and I wanted to bring this to attention.
lanyard, batteries, orings, holster, and even a hand grip are included
the 4Sevens quark line of lights use square threading, this threading is more expensive, but stronger. It prevents cross threading and increases lifetime.
quark RGB head pictured next to a mini123 head. the driver is huge!
Size Comparisons:
Comparison Beamshots:
this light is in a class of it's own! comparison beamshots wouldn't work very well.
White Wall Shots:
Shutter Speed is not specified -- the white wall shots are meant to show artifacts, rings, etc in the beam, not for brightness comparison.
Outdoor Beamshots:
lots of fun here.
4Sevens Quark RGB WHITE 2xCR123A
4Sevens Quark RGB RED 2xCR123A
4Sevens Quark RGB GREEN 2xCR123A
4Sevens Quark RGB BLUE 2xCR123A
Impressions
The Quark RGB is one of the latest developments by 4Sevens, implementing a multi color MC-E LED.
Standard MC-E LEDs have 4 white dies, but every die on the RGB MC-E is a different color, Red, green, blue, and your choice of cool or warm white.
The light doesn't ever light up all the dies at once due to heat concerns. Only 1 die will be lit at any time: the standard white output is achieved by tightening the bezel. Loosening the bezel will give you one of the color modes, and a quick tap at the tailcap changes modes. The light will memorize what brightness you set the white mode on, and it will memorize what brightness you set the color mode on. The mode memory is for all of the colors at once, not individual (I hope that made sense, it's a bit hard to explain)
The Quark RGB is pretty much a standard Quark body, all the important circuitry is in the head, which is compatible on other quark bodies.Fit and finish are excellent, knurling and anodizing is perfect on my sample. The only annoyance I have is on the engraving of the light. The lasering is not as well done as some of the other lights I've handled.
Onto the output: the light is a pure flooder, but there are artifacts in the beam due to the emitter itself. The dome of the emitter is large and offset when taken from one die's perspective, and this causes the odd beam within a beam and artifact nearer the center. Otherwise, the output is superb. Pure monochromatic light isn't really commonly seen in flashlights as it is rather limiting, but with the color MC-E LED, the primary colors can be seen separately from one LED.
While this light is very fun to play with (quoting a standard TV commercials -- It provides hours and hours of endless fun!!) ,it also comes with a relatively hefty price tag -- 100USD.
The question I'm posing to the community: Is the light actually useful, or a gimmick? What do you use the color modes for?
Thank you for reading!
- Battery Type: 2 CR123A
- Moonlight: 0.4 lm, 650 hours, 1 ma (All lumen outputs OTF)
- Low: 2.8 lm, 130 hours, 10 ma
- Med: 15.0 lm, 25 hours, 50 ma
- High: 58.4 lm, 7.5 hours, 250 ma
- Turbo: 150 lm, 2 hours, 700 ma
- SOS: 22.5 hours,Strobe: 4 hours, Beacon: 20 hours
Onward, shall we?
Size Comparisons:
White Wall Shots:
Outdoor Beamshots:
lots of fun here.
Impressions
