BlackShadow
Page 5 of 17 FirstFirst 12345678910111215 ... LastLast
Results 121 to 150 of 495
Thread: FS; Double, Triple (or single) XP-G Host 2200 Lumen
  1. #121
    Oct 2007
    Toronto, Canada
    Default Re: FS; Double, Triple (or single) XP-G Host 2200 Lumen
    Quote Originally Posted by coldass View Post
    My first guess was to double the 7.2V values in the manual. But it seemed to me that 12V V Cut was too high (most of the cells PCB are at 10 or 11V) and 14.4 V might be too low. But your right, in absence of alternatives I think I'll stick to your suggestion.
    Unlike other battery chemistry, when lithium ion batteries are nearly depleted their voltage drops off very quickly. 3V is generally considered a good point to stop discharging at as the difference between 3V and say 2.5V is probably only a matter a few minutes in actual run time, but the potential to damage the battery by over-discharging increases. So if you're using 4 cells, 12V is a good point.
  2. #122
    Oct 2007
    Toronto, Canada
    Matt,
    Any updates for us? Did you get everything back from the anodizer?
    Karl
  3. #123
    Flashaholic* matthewm's Avatar
    Mar 2009
    Sydney, Australia
    Quote Originally Posted by kwarwick View Post
    Matt,
    Karl
    Yes, I packed all the orders yesterday. They will all be sent this morning. I was waiting on a order from cutter.com.au, so I could build a unit up and do final testing!
    They turned out great!
    http://www.candlepowerforums.com/vb/...6&postcount=75
    Form follows Function.
  4. #124
    Dec 2009
    Socal
    My hands are starting to itch.......
  5. #125
    Enlightened coldass's Avatar
    Jan 2008
    Australia
    Quote Originally Posted by matthewm View Post
    Mine arrived!!!
    The body is excellent Matt. Finish and form seem top notch. Great job and thanks.
    I have all my electronics - just waiting on the lens order to come in. I'll do most of my assembly tomorrow regardless.
    Matt - how to you suggest to hold the PCB's. Glue or paste? And the Maxflex - just a blob of silicon?
  6. #126
    Mar 2009
    Sydney, Australia
    Mine arrived!!!
    Yeah I sent yours off yesterday, because you are in Australia
    I am in the process of writing a guide. I will update the build log thread later today.
  7. #127
    Jan 2008
    Australia
    A guide would be of high value. I am largely unskilled when it comes to soldering, electronics and basically all the skills needed to make the perfect build. Your build tips to support your design intent would be a big help.
  8. #128
    Mar 2009
    Sydney, Australia
    Has anyone done the math on run times for 6xXPG R5 at various MaxFlex settings from say a 2.4ah 4x18650. I guess about 2hours at max - am I right (forgive my feeble math ability)?
    Quick and dirty guide done http://www.candlepowerforums.com/vb/...3&postcount=79
    Runtime at 1A (high) and a 2600maH pack, approx 1 hour 45 minutes.
  9. #129
    Mar 2009
    Sydney, Australia
    Is anyone interested in a completely assembled unit? It looks like I have one spare!
  10. #130
    Aug 2008
    Australia
    By fully assembled, are you talking just the housing or led's, driver etc?
    What $$ do you want?
    Cheers,
    Nova
  11. #131
    hi matthewm
    where did you get those cable outlets (used at the back of your housings)?
  12. #132
    Mar 2009
    Sydney, Australia
    Quote Originally Posted by Whitedog1 View Post
    hi matthewm
    http://au.farnell.com/pro-power/1246...6mm/dp/4326325
  13. #133
    Thanks
  14. #134
    Matthew, the light arrived today. t looks fantastic. Just need to order the other bits now and get it built up.
  15. #135
    Dec 2009
    Socal
    Buttrock Re: FS; Double, Triple (or single) XP-G Host 2200 Lumen
    Got mine today. I can't wait to get it assembled
  16. #136
    Mar 2009
    Sydney, Australia
    Quote Originally Posted by baexmeyer View Post
    Quote Originally Posted by dickybeau View Post
    Rough preliminary assembly guide is here. (same links as before)
    I've uploaded it to a couple of places just in-case the links die...
    http://www.filedropper.com/guide
    http://www.filefactory.com/file/b1a9f58/n/guide.pdf
    http://www.mediafire.com/download.php?zztdiojjman
  17. #137
    Matthew, I don't remember if I mentioned this in one of the earlier threads, so please forgive if it's a duplication. I wonder if you could make a battery box designed to fit a commodity battery pack (I'm specifically thinking of the Sony NP-F970 camcorder pack but other possibilities exist), to get rid of some of the DIY issues of this product or a future one? The NP-F970 is a 2s3p (6x18650) 7.4v pack capable of running 35 watt video lights, maybe 1.5x the size of a cigarette pack. There are also smaller 2-cell and 4-cell versions, in case you wanted to save weight or had to use two packs for 14.8v. They are available from a lot of different manufacturers, there are snap-in chargers galore for them, etc. So they'd sidestep the whole issue of having you ship batteries and chargers with the lights.
  18. #138
    Mar 2009
    Sydney, Australia
    Quote Originally Posted by paulr View Post
    Its a good idea, but...
    Most of these batteries have a very specific charger and a unique mounting configuration which add additional layers of complication.
    I cant find the Sony battery charger for under $60, let alone the price of two batteries, do you know of a reliable cheap source for a whole setup?
  19. #139
    Hmm, I suggested the NP-F970 because it's an InfoLithium L series battery and those have been around for a long time and lots of stuff supports them, but maybe they are going out of style as some chargers have been discontinued. Still, they are pretty easy to find:
    http://www.amazon.com/Infolithium-CC.../dp/B001O3I7P2
    $20.87 includes a 2-cell version of that battery.
    Here's another ($16.95 charger only): http://www.adorama.com/Als/ProductPage/PQRTC115.html
    Here's a more expensive but faster one: http://www.bhphotovideo.com/c/produc...a_Fast_30.html
    Note 30 minute charge time is probably for smaller batteries, a big one like an NP-F970 will take a lot longer.
    NP-F970 takes about 12 hours to charge on my camcorder and the 2-cell takes 3-4 hours. So maybe that expensive charger can charge the 970 in a couple hours, shrug.
  20. #140
    Mar 2009
    Sydney, Australia
    How do I mount the battery, while in use by the light?
  21. #141
    The battery has tabs and grooves so that it snaps onto a little track on the back of a camcorder. You could either build something like that into a future version of the light (maybe the battery should be enclosed for water resistance), or use a separate battery box. For the connector you might be able to use the mounting plate from a universal charger.
    This should fit physically, though might have to be hacked electrically:
    http://www.adorama.com/Als/ProductPa...DUCNPF550.html
    The charger it's designed for looks nice too: $40 and charges two batteries simultaneously.
    http://www.adorama.com/Als/ProductPage/ICDDUCUS.html
    Here's another plate that should fit:
    http://www.adorama.com/Als/ProductPage/LRXPA4S.html
    If you really want to get fancy, the battery itself has an internal microprocessor that monitors the charge level so the camcorder can display how much runtime is left. Maybe you can get your light to use that interface.
  22. #142
    hey matthewm,
    did you get my pm i sent yesterday?
  23. #143
    Mar 2009
    Sydney, Australia
    It is still a horrendously expensive configuration compared to a Li-Ion pack and charger
  24. #144
    Mar 2009
    Sydney, Australia
    How did the assembly go?
  25. #145
    I'm not sure we're looking at the same things. Those packs are maybe $30-40 USD (3rd party) or $90 (Sony brand) and the charger is about $20. Comparable unpackaged packs (7.4 volt 6000+ mah) from batteryspace are at least as expensive, and are much less protected and less convenient to deal with, as are the chargers. Maybe I'm missing something since I'm used to charging my USL with a hobby charger and it's ok as recreational flashlight nerd-ism, but way too complicated and dangerous (possibilities of shorting something, setting wrong voltage, etc) for a consumer product. I guess I'm not sure what your end goals are--if you're trying to make modder-style flashaholic gear, that's great; from my flashaholic perspective I'm a big fan of that. If you're trying to sell high-end bike lights (like, say, Lupine) to those not interested in flashaholism per se, it's better to make everything as simple for the end-user as possible.
  26. #146
    Dec 2009
    Socal
    Still waiting on a few parts right now. I will let you know when I am done.
  27. #147
    Mine arrived as well, looks great! Now to plan out my build...
    As one who is quite familiar with the Sony NP-F970 batteries (also used them for years... two camcorders ago) I'd say the form factor is not much better than the other multi-18650 packs. There is no way you could clip that battery to the light and expect it to stay attached during any sort of bike ride. I far prefer the flat 18650 packs. My plan is to build the light as a helmet mount and use the battery pack in my jersey pocket. My favorite battery so far is this one: http://www.batteryspace.com/li-ion18...emaleplug.aspx It is durable and protected from weather so it could make a good frame-mounted battery as well.
  28. #148
    Jan 2008
    Australia
    Quote Originally Posted by Shrigg View Post
    I wouldn't bother with adapting a camcorder pack when you can buy packs like you highlight and for the price.
    I have three similar packs and they are light and reliable. I am very pleased.
  29. #149
    Mar 2009
    Sydney, Australia
    I want to try and gauge if there is any interest in another run of these lights, I have updated the design and reduced the cost to $99 (ex shipping) I would need at least 10 people interested
  30. #150
    Oct 2009
    Santa Monica
    I would definitely like to order one. Say the word and I will paypal... Estimated eta too would be appreciated...
    Thanks,
    gt40
