Ok, I will try my best to specify some design details, however my point is; these remain very loose at this stage as I don't know enough about the LED and battery setup options to decide on a final spec. The electronics side of the project are not the main point of marking, however I feel they need to be right to justify other decisions in the design of the overall torch.
Doh!Nut I think by Cranfield you may mean Hatfield, this is the University of Hertfordshire where I study. But I may have got the wrong end of the stick.
Things I know... I want it to be hand held not canister, as close to or actually buoyancy neutral if possible. Again info on techniques used by you guy for this would be great!
No real restrictions on head size possibly need it to be able to be adjusted by a 5th-95th percentile hand so roughly 150mm max diameter. I want it to be a primary dive light and be able to light up wrecks etc and possibly be used for Photography- so quite a high lumen setup.
Battery, I feel is best to be able to remove and recharged this was the user has the option to replace or upgrade. However, again, this is flexible. If anyone has a good option for external charging with a sealed canister then I'm all ears. I basically want to learn as much as possible then make decisions from there.
Any ideas guys?
Excellent, Details!!! Well some anyway
Class is open boys!
Let's discuss and finalize the goals and let the solution present itself.
The idea is to make sure you have consider the options, not to change you mind...
There is no real right or wrong answer, there is just YOUR answer
In some cases you will discover that the goals are mutually exclusive in a practical sense.
Goals:
- Handheld
- Neutrally Buoyant
- Headsize smaller than a grapefruit
- Rechargable
- Lightup an undefined Wrecks
- Primary Light and Photograghy
- High Lumen output
What about:
- Cost?
- Got an idea on Finished Product retail?
- Reliability?
- Do you want to be able to turn it on of off at will? Or just on when you enter the water and off on exit?
- Durability?
- Do you care if the bulbs are replaced every dive or never in your lifetime?
- Overall Weight?
- Neutrally Buoyant is easy, if the light weighed 20stones we'd need 20stones lift bouy though I don't think this is what you have in mind.
- Depth?
- Rec or Tech?
- Duration?
- 1-3 hours from your previous post as noted is too wide a range for design.
Can you clarify the target market and how you'd like the product to benefit your users?
IE.
- Recreational dives
- typically last are between 45 and 60 minutes not exceeding 40 meters
- It's been my experience that Most boat dives run 2 boat dives before lunch.
- Using this logic we might want a 2 hour burn time, and expect a recharge or battery swap during lunch
- Divers physical condition span 95% of the population: >= 11years old, skinny to fat
- Water conditions
- blue or green
- 100feet visibilty
- Warm >24c
- Cave/Cavern/Deco
- Each dive will be different but you can expect longer and deeper and redundent light sources
- Divers are typically in better physical condition that "rec" divers.
- Water is.... well... it's wet!
Let's start with the form factor: Handheld
Is this set in stone? Please clarify your answer.
Did you consider that typically Canister lights have higher lumen output do to larger power sources? Bouyancy is easier to solve as the canister is attached to the diver and relies on the BCD, Wing or Drysuit for neutral. While there is a cord, heavy powerpacks mean less lead in the weight belt.
Neutrally Bouyant:
We still dealing with handheld?
Headsize:
Is the goal here a small bright compact light? Or the smallest head to get the job done?
Rechargable:
Any desire for off the shelf batteries? D/C/AA/AAA/CR2/CR123 are all nice in a pinch... like I forgot to bring my charger!
Light-up a wreck:
The whole thing or just a section? From what distance? I was diving the HMS Rhone last week, best view was at the safety stop 80 feet above the wreck. Of course the Might-O conning tower is at 100feet depth and you need to get close.
Primary vs Photo:
Look at the threads on Variable Focus. These to goals could be considered mutually exclusive.
Primary lights tend to have a nice hotspot and are useable in great and poor visibility.
Photo lights are wide angle, floody and useless in murky water.
High Lumen output:
Do you have a real requirement here or is this the peter-principle at play?
Do you know the typical output of any dive light?
Do you want to match or exceed some light out there? Which one?
Follow-up discussion to include:
- Total Lumen output
- Build Materials
- Plastics or Metals
- Type of Bulb - LED one of several options
- Batteries - NiMH, LiON etc
- Optics and reflectors
- Methods of water-proofing
In case you hadn't noticed if you were looking for people passonate about dive lights you found them! There are many strong view points and approaches to the techicnal items and as I stated earlier the only correct answeris the one that works for YOU.
I encourage you to understand the WHYs of each choice: positives and negitives, first! Then make educated choices, document and stick with them, moving on to your final solution.
If you know the right questions to ask the process is pretty quick, we'll help you ask them.
