Foxfury Scout
Results 1 to 24 of 24
Thread: Car xenon kit: analog or digital ballast?
    Default Car xenon kit: analog or digital ballast?
    Hi everybody from Italy.
    I am a really ignorant in electronics.
    I would know, how can I distinguish an analog xenon ballast from a digital one?
    Thanks in advance for your replies.
    Jul 2009
    Northern VA, USA
    Default Re: Car xenon kit: analog or digital ballast?
    Ballasti digitali sono molto piu piccoli, ma anche sono piu sensitivo ai danni electrici.
    Sep 2008
    Belgium
    Quote Originally Posted by fyrstormer View Post
    Lemme see if I can get this right :
    Digital ballasts are smaller, but also more sensitive to electric currents...
    (mind you, I don't speak Italian and can't be arsed to Google Translate )
    Flashaholic* XeRay's Avatar
    Feb 2006
    Ogden, Utah
    Quote Originally Posted by cyberc View Post
    Just because it is Digital does not mean it is better. Digital of itself is NOT better. It is the complete product that makes it better or not.
    Some digital ballasts are better than most Analog ballasts. Many Analog ballasts are better than some digital ballasts.
    Digital is NOT a "silver bullet" for ballasts as many sellers claim.
    Mar 2009
    pittsburgh, pa
    Xenithxenons.com... lol they have a great warranty
    Is it true that digital ones need less than 10A while analag ones need 20A to start up?
    Feb 2006
    Ogden, Utah
    That is not a direct correlation. Its all in the ballast design, not if it is digital or not.
    Is this digital?
    Which elements influence the consumption of amperes?
    Quote Originally Posted by XeRay View Post
    Me, customer, How can I choose a ballast with a low absorption to ignite?
    Feb 2006
    Ogden, Utah
    That is not enough info to answer your question. Cant see the control circuits.
    Where re these control circuits? Back? Here an other photo:
    Flashaholic zelda's Avatar
    Aug 2005
    Zurich, Switzerland
    In a Hella OEM Ballast is much more electronics, the cpu is a Motoral 68000.
    Such cpu was used in a old mac computers
    I read, it tooks around 10 years for develompent, to make the ballast handy for a car.
    When switch your car hid on, the ballast goes each time thru around 20 steps. Such as controlling, is the bulb hot?, reverse polarity on bulb, switching down to lower voltage etc.
    zelda
    Feb 2006
    Ogden, Utah
    We cant see much on those photos, we need to see the back side.
    Jul 2009
    Northern VA, USA
    Quote Originally Posted by dodge_911 View Post
    Electrical damage, but yes.
    I barely speak Italian myself. It's a shame how I've let myself slip in the, oh, 12 years since I last needed to use it.
    Feb 2006
    Ogden, Utah
    That is a "bare bones" ballast I would not use it as something to emulate, I cant even be confident I see the control circuit section in the photos.
    Excuse me, I dont undertstand.
    Summarizing: it could be a digital ballast but you are not sure?
    Thanks.
    Feb 2006
    Ogden, Utah
    Thanks.
    Cannot be sure.
    Flashaholic* divine's Avatar
    Sep 2007
    Virginia
    Hopefully I word this so google translate works well.
    I believe that you don't mean Xenon, because Xenon does not need a ballast.
    With HID, it is most often a Magnetic or Electronic ballast.
    With a low powered lamp like you would see in a car, a magnetic ballast is uncommon. A magnetic ballast will not perform as well. A magnetic ballast will use more power, it will start up slower, it will restart slower.
    I have not seen enough to tell them apart. If I had to guess I would say the one you are showing is electronic because the transformer is smaller than the full power of the lamp and it is using a lot of electronics and a transistor in the final stage (the output).
    "For every good deed, there is an equal an opposite bad deed."
    Thanks to everybody.
    Feb 2006
    Ogden, Utah
    That IS an electronic ballast, NOT magnetic. He is wondering if it has digital or analog controls.
    Xenon short arc do use and need a ballast.
    Xenon filled incandescent bulbs do not need a ballast.
    How can I measure the amps consumption of a ballast?
    Using a multimeter? What kind of multimeter?
    I dont know how to realize the electric connection for this purpose.
    Can anybody post a picture or a little scheme?
    Excuse me for my ignorance. Analog or digital controls of what? Of the voltage?
    Feb 2006
    Ogden, Utah
    When someone calls a ballast Digital or Analog, it is the output controls which they are speaking about.
    These circuits control the initial DC voltage to start the bulb and the AC voltage and current during the rest of the operation.
    Ok. A digital ballast controls the voltage through what? Through a microprocessor? On the contrary, an analog one through what?
