MountainVoyageur
- Joined
- May 10, 2010
- Messages
- 55
I am new to this forum, and I realize the tone of this post is a bit different – it is more functionally oriented than technically. I hope that is no problem. I am more interested in suitable light for my needs, and less interested in specs like lumens or emitter/bin per se.
I am looking for the best light to use ultralight backpacking on trips ranging from day hikes to weekend backpacks, to 2-4 week expeditions. Also on canoe trips that last 2-4 weeks. The criteria that occur to me are:
To illustrate what I have been thinking, here are the lights that (based only on reading/thinking) seem best suited:
Thanks,
[FONT="]--MV[/FONT]
1) As light weight as possible, while still meeting the requirements. Also, compact – size matters – those UL backpacks do not have a lot of excess cubic inches.
2) Efficient – long battery run times so I do not need to carry a lot of spare batteries – whether for a weekend or for a month. Spares are OK for a month, but let's minimize them. Efficiency also reduces the likelihood of having to change batteries in the dark if I get caught out hiking after sunset. I am not wedded to XP-G, but am impressed with its increased efficiency.
3) Flexible positioning – primarily on my head (headlamp or clip to hat visor). I would also like to be able to mount it to chest (sternum strap or pocket) or waist (for night hiking).
4) Multiple light levels, suitable for in camp, on trails, on rough terrain, and reaching out.
5) In camp –Common wisdom is a lumen or so. I do not know about the need for, or the wisdom of, a "moonlight" level. For in the tent and moving about the campsite. As far as I can see, throw is not important,unless it is needed to get enough light to see to do a task. Floodiness is important – I do not want to have to point my head at each different thing I need to see.
6) On good trails – common wisdom says about 15-20 lumens works well for that. Enough throw so you can see far enough ahead to be comfortable maintaining normal hiking speed. Enough spill so that you can see all you need to, including the trail, and are not just walking in a light-tunnel with obscure things moving by in your peripheral vision.
7) On rough terrain – common wisdom says about 40-50 lumens. For coming down off the mountain and getting back to the trail, or for cross-country travel. More distance/throw to see well ahead where to go, but still enough spill to know where to put your feet.
8) High power – the more lumens and throw the better. For finding the next blaze or cairn. For lighting up wildlife at a distance. I have even read that these high power lights can (at least sometimes) cause a bear to have second thoughts.
9) Rugged – I'll be careful, but it will get bumped round. Water resistance is good (think canoeing or heavy rain) – IPX8 is common and plenty good enough.
10) As far as I can see, the various flashing modes that seem so common are not important to me. I could conceivably see using beacon (to mark camp and return to it) or strobe (when in a canoe and there are power boats around), but such use would be rare and but their absence is far from a deal-breaker.
I am new to the more technical aspects of flashlights, and trying to sort it all out. I have been looking around, reading on line (including a lot of CPF), and looking at vendor specs. Little practical checking anything out, though.2) Efficient – long battery run times so I do not need to carry a lot of spare batteries – whether for a weekend or for a month. Spares are OK for a month, but let's minimize them. Efficiency also reduces the likelihood of having to change batteries in the dark if I get caught out hiking after sunset. I am not wedded to XP-G, but am impressed with its increased efficiency.
1) First choice – Zebralight H31 – very flexible choice of light outputs, and good efficiency. I understand the H31 is a lot less floody than previous Zebralights – it seems as if its beam may be a good compromise for this use. I hope the solid aluminum body will be a better heat sink, and that using a16340 will be less of an issue than with the iTP A1.
Notes:a. Note: I am also strongly considering the H31W, for its neutral-white tint. Since that uses an XP-E, it should be a bit more throw-y than the H31, and definitely more than the previous Zebralights. Any comments on how this trades off against the brighter H31 would be welcome.
2) Second choice – iTP A1 EOS – also good efficiency (though not as good as the Zebralight). Decent choice of light outputs, though much less flexible than the Zebralight. Use 16340 cautiously – heats up on high power.
1) I would think these days that a regulated 1xCR123 light with 200+ OTF lumens is a reasonable expectation. 2xCR123 has some advantages, but they are not always needed, and it is heavier. A good compromise may be to get a 1xCR123 and carry a couple extra spare batteries when needed.
2) How far ahead would I expect to be able to see with the above lights in the various modes? I wonder whether the lights mentioned above reach out enough and, if not, whether the answer is a better choice or carrying a separate light to reach out.
Any comments? Any suggestions of lights that would do better? Any comments on criteria I should be looking for?2) How far ahead would I expect to be able to see with the above lights in the various modes? I wonder whether the lights mentioned above reach out enough and, if not, whether the answer is a better choice or carrying a separate light to reach out.
Thanks,
[FONT="]--MV[/FONT]
