Last night I completed a project using one of those Radioshack 3C flashlights, where I used the battery tube from another one to make 6C's, using a U4UW 5 watt star, and driving it direct, and using a 30mm optic. The heat sink is from Elekrolumens, as well as some round aluminum pieces that were about the exact diameter of the tube. I had to use those because the bulb holder is higher than the frame of the flashlight, and I wanted the heat to be transferred to the body. Works too. I turned it on for a short while and the body did get some warm. Anyway, this thing is very bright. The flood of this set up is excellent. The W2W 5 watt LED in my Maglite set up [similar to the great Space Needle II] does have a brighter hot spot, but this has a much bigger spot and much better spill.
If I can get some digital picture taken, I'll do so. /ubbthreads/images/graemlins/thumbsup.gif
