FourSevens
Page 1 of 3 123 LastLast
Results 1 to 30 of 90
Thread: 17,000 lumens of incan domination! Mag 6D 64656/64657 *Beamshots added*
    Flashaholic* mrartillery's Avatar
    Mar 2007
    north carolina
    Default 17,000 lumens of incan domination! Mag 6D 64656/64657 *Beamshots added*
    Well I finally got my 6 D complete after a couple months of compiling parts. Man was it ever worth the wait! Words honestly cannot describe this thing at night and the pictures don't really do it justice, but I thought I would share my fun with everyone else. The 64656 and 64657 compare pretty close in way of brightness as far as I could tell, although i prefer the 64656, the light is just a little whiter at 28v, however the 12.5 amps pull it down rather quickly.
    The shear size of this thing is just massive with the FM3-X installed, here's how it compares to my 2D 5761.
    Isn't it lovely!
    The FM3-X and the rocker switch mod to handle the amperage!
    The 7 IMR 26500's used to power up this beast
    I had a little left over space in between the tail spring and the batteries and needed something to add some pressure to the batteries so they could make good contact. So I had an old tailcap from a MiniMag lying around and it fit perfectly in the spring, so I ground the ano off and presto, I had a plug to add pressure to the batteries!
    Looking down the throat of the beast!
    To put things into perspective, here is the Osram 64656 up next to everyone's favorite, the infamous 1185.
    Mar 2007
    north carolina
    Default Re: 17,000 lumens of incan domination! Mag 6D 64656/64657
    Based on Lux's testing the 64656 puts out around 17,000 bulb lumens when over driven to 28v. It truly is a sight to behold, it makes my 64458 look like a toy! Sorry for the quality of a couple of the shots, the light heats up really quick, only 15-20 seconds bursts due to the fact it gets to hot to hold! I was trying to hurry and the get the pictures taken before I went into meltdown.
    So here's the control shot of my barn.
    And the barn all lite up BTW the barn is at about 50 yards away
    Didn't see the need to do a control shot of my front yard, it'd just be another black picture so here you go. (Beam was pointing more toward the ground in this pic)
    I adjusted slightly the beam direction more toward the power pole, oh and the power pole is about 200 yards away. Notice how it lights up the trees beyond the pole which is roughly another 20-30 yards. (again sorry for the shakiness)
    +1 beamshots ,preferably in an open area :-)
    Woooaaaah!!!
    Default Re: 17,000 lumens of incan domination! Mag 6D 64656/64657 *Beamshots added*
    That's glorious!
    But do you really think that the IMR26500s will hold 4V per cell at 12.5A draw?
    When I did a discharge test, the IMR26500s held just over 4V at 3.6A draw (I was testing for 1185 performance) for multiple minutes.
    Also interesting that seven IMR26500s was too short and you needed a spring spacer. I would have thought that the fit would have been just about perfect, with the nominally ~1cm shorter length relieving the typically high tail spring pressure in the stock Mags.
    Nice beast..Can you make an estimation of it's total cost?
    Mar 2007
    north carolina
    Quote Originally Posted by Justin Case View Post
    That's glorious!
    Oh no, I know that they drain down rather quickly under that kind of load, either way its 10,000 bulb lumens by design, so the figure at 28v is purely theatrical, but none the less incredible.
    Quote Originally Posted by daf3m View Post
    About $350
    Jun 2009
    Sacramento, California
    This needs to go into that "The Big Lights" thread!
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    Explains what’s been light the sky up at night
    Lucas Jackson, "Here, Captain"
    Maliciously destroying municipal property while under the influence, What was that?
    "Cutting the heads off parking meters, Captain."
    Flashaholic* rayman's Avatar
    May 2008
    Germany
    That's a real great example of your Rocker switch mod .
    rayman
    My Lights (current EDC: Foursevens Mini MkII Titanium)
    Enlightened garilla's Avatar
    Jan 2009
    miserable state of NJ, actually it is only the politics I can't stand
    Now this light really needs 300+ yards to stretch it's legs to see what it is capable of !!! Love to see some distance shots, Wow gets hot in 15-20 secs thats cranking out the lumens. You need a water cooled jacket surrounding it like they used on machine gun barrels!
    Quote Originally Posted by garilla View Post
    Nothing left to say..!!!
    Flashaholic* ninemm's Avatar
    Mar 2010
    Pennsylvania, USA
    Very impressive! Congrats!
    Administrator Kestrel's Avatar
    Oct 2007
    Willamette Valley, OR
    Quote Originally Posted by mrartillery View Post
    I liked the above pics particularly.
    Dec 2009
    Bay Area, CA
    Don't incans just make you feel all warm inside? Or in this case blazing hot on the outside?
    What a wonderful way to make use of your awesome switch mod.
    Fiend got into light re-hab. Getting out for now
    I just remembered where I saw that build before.
    Holy-shnikes! thats AWESOME!!! Nice work!
    Aug 2004
    Sydney, Australia
    SOLID build- thanks for the pics!!
    Kind Regards
    David
    Flashaholic* Kevin1322's Avatar
    Mar 2009
    Phoenix, Arizona
    I can't really even comprehend how bright that must be. I was looking foreward to getting my new mag back modded with an SST-90, but now... Absolutely incredible!
    Sometimes we don't get what we pray for. Sometimes we get much more.
    Enlightened A380's Avatar
    Feb 2009
    CATALONIA (Spain)
    This is really a WOW flashlight!!
    Did you use a sofstart or just a kiu socket ad direct drive?
    Quote Originally Posted by Kevin1322 View Post
    On the bright side(no pun intended), you probably get triple the runtime with your puny nightlight.
    Dec 2009
    Bay Area, CA
    Quote Originally Posted by A380 View Post
    Check the link in the OP's sig line for switch mod.
    Mar 2007
    north carolina
    Yeah it's most definitely a sight to behold, hands down the brightest thing I've ever seen for its size. Lol, don't give up on your light, I own several wow lights, (this being the baddest, of course) but I own many practical lights for example, my ROP's, 1185, 1111 etc. This is just a light to show off to your buddies.
    Quote Originally Posted by Noctis View Post
    LMAO, oh so true!
    Thanks everyone for your nice comments, I'm glad you enjoy it!
    i guess this is an irrelevant question, but does it set things on fire?
    Quote Originally Posted by wechnivag View Post
    Considering "The Torch" from Wicked Lasers will set things on fire with a mere 4100 lumens, there's really no question that it will burn things up.
    The real question is, from how far away can it light things on fire?
    May 2005
    10,000 Lakes MN USA
    Very nice powerhouse!!
    Flashaholic* don.gwapo's Avatar
    Feb 2010
    My avatar!
    Whoa, that would be the brightest light i've ever seen. Thanks for sharing.
    Pick the pooch!
    Flashaholic* ^Gurthang's Avatar
    Jul 2009
    Maine, deep in the Darkness of the North
    Nice torch [can't really call it JUST a light].
    How 'bout some beamshots lighting up passing airliners??
    ^G When I reply, threads die....
    Impressive flashlight. The bulb that you are using is so much larger and the filient much higher than the 1185 bulb. How does that work out with your FM 3" Head as far as beam pattern?
    Mar 2007
    north carolina
    Im going to try to make this happen! I have a large field behind my house thats around that distance, so one night I may take it out for another spin.
    Lol, that is a good question. I stood in front of it and felt heat at almost ten feet away, not of course enough to light something on fire, but you could feel it.
    Quote Originally Posted by ^Gurthang View Post
    Is that legal?
    Quote Originally Posted by Bob96 View Post
    On white wall testing, or ceiling bounce test the hotspot is profound, not as much as a axial filament bulb, but none the less is still pretty nice. The shadows of the filament are somewhat noticeable on a white wall, although this is totally unnoticeable when outside. Oh, and might I add, the ceiling bounce test from this thing is insane, it absolutely destroys your night vision after you turn it off, but its worth it!
