357mag1
I've had 3 ROP 3854-H bulbs go bad with less than an hour use on each. One during break in using a 6.4 volt source, one while being used with a 6.4 volt source and one that has been running on two Li-Ions just died. It worked fine last night when I put it up but didn't even blink this morning. This is the second one that died and the filament looks fine it appears the open is somewhere in the base.
Is this a common occurrence with these bulbs?
I use my ROP Lows (3854-L) versions a lot more and they are still running strong. All of the Lows are running off two 26650 IMR batteries.
