MadMax & BadBoy Runtime Graphs (fixed pics)
shankus
Mojave, CA
The question of MadMax/BadBoy runtimes comes up often, so here are all the graphs I could find, posted here in one place.
The black & white paper graphs were all runs by Roy, and are not an indication of relative brilliance of a certain light compared to another, but rather a test of the runtime of the sandwich until it falls out of regulation.
Roy's definition of runtime is when the light reaches 50% of initial brilliance. I believe this is a fine criteria for measurement. (All of Roy's tests are run with a solar cell & a data logging multimeter.)
The color graphs were run by the Sandwich Shoppe, and appeared on their first website. They are an indication of relative brilliance. (Notice the vertical scale is in foot candles.)
Notice how the NiMH & lithium cells tend to discharge with a flatter curve than alkalines do. Using NiMH in a MadMax seems to perform in a more "regulated" manner.
MadMax:
MadMax w/alkalines
(Everactive alkaline cells):
MadMax w/lithiums
(Energizer e² lithium cells):
MadMax Cyan w/alkalines
MadMax Adjustable w/alkalines
MadMax+ Q3 w/alkalines
(Energizer alkaline cells):
MadMax+ Q3 w/lithiums
M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³M³
MadMax+ w/ONE AA CELL:
MadMax+ Q3 in a Rothrandir mini-mini-Mag or M³ (M cubed) w/lithium
(Energizer e² lithium):
BadBoy:
BadBoy Yellow w/NiMH
(Nexcel 1700 mAh NiMH cells):
BadBoy NiMH vs. alkaline cell comparison
(Kirkland alkaline cells vs. Kodak NiMH cells):
MadMax vs. BadBoy comparisons:
MadMax vs. Badboy with a variety of cells:
MadMax vs. BadBoy
(Both w/Kodak 1600 mAh NiMH cells):
Downboys:
Mini-Mag Incandescent (for comparison to the sandwiches):
Mini-Mag & standard incandescent bulb w/alkalines
*EDIT* - Moved pics to LogicNerd's server. They look MUCH better, and should be working most of the time now.
StoneDog
Suwanee, GA
Re: MadMax & BadBoy Runtime Graphs
Am I reading this right? Did the MM+ Q3 (on Lithiums)really run 2 hours and 50 minutes before dropping out? And then what happened after that - it looks like it jumps again?
Jon
dat2zip
Bay Area
I'm pretty sure the Badboy graph timescale is 2X. I think I goofed on that one. I think the runtime is 120 minutes and not 240. Just wanted to clear that in case someone thinks the Badboy will run 240 minutes on regular batteries. While this may be true for the latest NiMH batteries, it is not true for regular Alkalines. Also, the bump near the end is me changing the light meter scale.
Thanks for putting all the plots together in one place. This is nice.
Wayne
shankus
Mojave, CA
[ QUOTE ]
[/ QUOTE ]
Yes, that is what Roy recorded.
I don't know why the graph jumps like that, though.
StoneDog
Suwanee, GA
Wow... I think I need to track down a MM+ Q3... /ubbthreads/images/graemlins/ooo.gif
Jon
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
What you're seeing on the MM+Q is the remains of the previous chart. The plot wraps around and if you stop the plot early, then you get the apparent huge step in the plot. The software does not erase the previous graph when it starts a new graph. Sorry for the confusion.
Y2Kirk1028
Brooklyn, NY
Those graphs are very useful thanks to everyone who was involved.
Question: Based on the same setup in these tests, what would be the projected runtime of BB and MM on C, and D cells?
this_is_nascar
Gloucester, New Jersey
OK, I'm still confused, even after reading this. I want to power one of these sandwiches with 1 x AA cell, with that ability to drive it with 2 and 3 x AA cells as well. The 1 x AA cell configuration will be the primary setup.
That being said, which sandwich am I better off with?
Roy
Granbury, Tx USA
look here for a discussion of using a MadMax+ in a chopped minimag.
shankus
Mojave, CA
[ QUOTE ]
[/ QUOTE ]
I don't think you can run the MadMax from 3 cells. If I remember correctly, the max Vin is ~3.1V.
*EDIT* I was wrong, look at the info here:
MadMax board
It seems that the Vin max is 5V, or limited by the Vf of the luxeon.
The bare board specs say 5V. The complete sandwich specs says 3.1V, or limitied by the Vf of the luxeon.
Perhaps Wayne could clear this up. *EDIT*
dat2zip
Bay Area
Madmax is a boost converter. Vin should always be less than the Vf of the LED. So, if you had an LED with a Vf of 5V, you could run it up to 5V. A typical 1W Luxeon is around 3-4V.
Wayne
Bullzeyebill
CA
So, with MM or MM+, if you have an R2H with a vf under 3 volts you would be better off running two NiMh's than two alkalines starting at 3.2 volts or two lithiums starting at 3.4? So that vin is lower than vf of led?
Bill
StoneDog
Suwanee, GA
Has anyone done a similar graph using a MM or MM+ and a single 123?
Jon
Roy
Granbury, Tx USA
Stone Dog....see my previous posting above.
BentHeadTX
A very strange dark place
Bullz,
I run a R2H in a 2D Mag with two D cell alkalines, it runs very bright and suffering no damage. I think under load, the voltage sags a tenth or two and the R2H is rated at 3.03 to 3.27 volts. I don't think there will be a problem.
StoneDog
Suwanee, GA
Roy,
I'm not seeing it. Don't those graphs represent runtimes on L91 AA Lithiums?
Jon
StoneDog
Suwanee, GA
OK, OK, so the short answer is "No, nobody has done a run time analysis of an MM+ on a single CR123"...
I'll dig back into the woodwork now. /ubbthreads/images/graemlins/smile.gif
Jon
Roy
Granbury, Tx USA
If someone will send me a 1x123 light with a MadMax+, I'll be more than happy to do a runtime plot on it! /ubbthreads/images/graemlins/grinser2.gif
