RofisLight
Results 1 to 9 of 9
Thread: How to destroy your very first LED retrofit bulb
    Mar 2010
    Moncton, NB Canada
    Default How to destroy your very first LED retrofit bulb
    The following are step by step instructions for destroying the very first LED retrofit bulb you purchase.
    1) Buy the Sylvania Ultra LED A19 bulb from Home Hardware in Canada. Make sure you pay $49.99.
    2) Wait until your living room contains at least 7 people - two of these persons should be under the age of 8.
    3) Casually ask a few people if they would like to see a LED bulb in action.
    4) Without waiting for an answer - unscrew the current incandescent bulb from the most expensive table lamp in the room.
    5) Ask your wife if the lamp is one of those tri-light dimmable ones because the LED bulb package states(small text inside of the package) this product is not compatible with dimmers). Oh yes, there is a hard to read graph on the back of the package that says the bulb is not "fully dimmable".
    6) Wait until your wife responds with an emphatic "NO". At this point do not question whether her reply refers to the lamp itself or its incandescent bulb you are now holding in your hand.
    7) Insert LED bulb into lamp.
    8) Proudly turn on lamp.
    9) Wait for the smoke to clear and the ringing in your ears to subside before you apologize for invoking the son of God's name in vain. Explain to the children you were praying to God for protection.
    10) Unplug the lamp. Remove the LED bulb.
    That's it. Ten easy steps to destroying your first LED bulb.
    Notes:
    Yes, I am a moron and this is a true story.
    Yes, I know enough about LED's and dimmers to know there was a chance this might not end well. But the LED bulb's packaging only stated "not compatible" and "not fully dimmable" and my wife did state the lamp was not dimmable(she meant the bulb in my hand was not a tri-state bulb). Isn't "not fully dimmable" the same as "works with dimmer but just not perfectly?".
    In the end, the lamp's electrical contacts are damaged and the LED bulb is dead with a 1/4 inch hole in the metal base. I have pictures but as a new member I cannot embed an image from my computer.
    But - I had purchased two of the bulbs. I found an old lamp and retreated to my library. Within 30 seconds I had LED light flooding a good square foot or two of my room. Actually it was 30.5 seconds as there was a half second delay before the bulb reached full output.
    Eight watts - 350 lumens. 43.75 lumens per watt. I do not know the exact LER value of this bulb's ouput but I think it would be safe to say the bulb has less than 20% wall plug efficiency.
    I have ordered a case of the Home Depot's Ecosmart LED Bulbs. Since these are dimmable I hope to avoid the pyrotechnics of the Sylvania product. Additionally, I have ordered three of RedBird's 30 watt LED outdoor fixtures for evaluation.
    I post this in hopes of protecting the next moron/poor soul who purchases their very first LED bulb.
    Stephen Lebans
    Flashaholic* csshih's Avatar
    Sep 2008
    San Jose, CA
    Default Re: How to destroy your very first LED retrofit bulb
    you can place images on the forum.. just upload to a remote site, then enclose in IMG tags.
    yikes! wonder what exploded in there!
    Flashaholic* Linger's Avatar
    Feb 2009
    Kingston ON
    Thanks for sharing the story. Someone could even put 'Tri-state/dimmable lamps destroy Led bulbs' in their sig to spread the word.
    I'm very glad you took that first blow-up on the chin, quickly finding a safe alternative and running back to carry on showing off...er, I mean continue with the new LED bulb demonstration.
    Best,
    Installing Quantum Tunneling Composite (QTC) into M@glite Solitare
    Sep 2008
    Shropshire, England
    Nice post, sorry to smile at your misfortune but it was well worded. I bet the kids remember it for a while tho! Let's just hope they don't try and repeat it with the other one you bought!
    Shrug Re: How to destroy your very first LED retrofit bulb
    Is the bulb socket a touch dimmer?
    Because the reason is an older style tri state uses and extra ring on the bottom of the socket and should work as a regular socket with no dimming if a normal (non 3way) bulb is inserted.
    BTW i would contact sylvania on this matter, bet they will send you another one to avoid any type of legal matters concerning the note on the bulb.
    Mar 2010
    Moncton, NB Canada
    Quote Originally Posted by coreyhudson2 View Post
    No, you as you turn the knob the lamp's brightness increases to 100% in three steps.
    I finally got around to taking some photos of the damaged bulb.
    And here is a shot of the second bulb. Please do not stare directly at the light.
    Stephen Lebans
    It looks like the contact for the Lo filament in the socket shorted to the screw shell on the lamp base.
    Flashaholic* LEDninja's Avatar
    Jun 2005
    Hamilton Canada
    I am a little confused.
    By DIMMIBLE I assume you meant triac dimmers - usually a big knob on the wall marked 0-100%.
    From your description I get a feeling you put a single level bulb into a 3 level socket such as used by a 50/75/100 W bulb.
    Does the lamp require special 3 level bulbs or can it dim using standard 60 W bulbs?
    Can you show us a picture of the base of a bulb that works (dims properly) in that lamp?
    Mar 2010
    Moncton, NB Canada
    Quote Originally Posted by LEDninja View Post
    When you get to my age you will become totally confused.
    I used Lutron Maestro and Skylark dimmers throughout my house.
    Exactly!
    Stephen Lebans
