Newcomers, please skip to post #87 on page 3 - Thank you
https://www.candlepowerforums.com/threads/286288&page=3
The following is a lamp I have developed for medical/surgery use. I'm just about finished creating it, but in testing, have realized that it must be about 15% brighter to be as useful as possible.
I cannot increase the package size, and have no idea what else to do to increase brightness. Lenses and machining are all custom work.
I will be eternally grateful to whoever can help me out. I would even go so far as to giving whoever helps me out one of these lights when completed.
Thank you to everyone on this forum and all your infinite wisdoms.
Edit:
Options that have been brought up (more discussion on any is more than welcome):
- TIR lens: might be a solution, but unlikely as these lenses do not provide sharp focus
- Lens coatings: a partial solution
- Having just one proper lens: I'm attempting to produce this
- Using a different LED: SST-50-W or OSRAM: New LED being used is the XRE
- Polish the bore from the LED to the first lens: possible gain, but will likely result in sloppy focus.
- Increasing current to LED: the complete casing cannot be increased in size and cannot get any hotter than it already does at 1amp
- Add heat-sinking fins and such: Do little or nothing due to small size requirement.
What has been established:
- A lot of light is lost with the current focusing strategy.
- For the application, there must be a very sharp delineation between light/dark at the edge of the ~13.5 degree focus beam (hence all the black on the inside)
Best possible solution so far:
Replace the XPG LED for an XRE LED. The XRE may provide less light, but its illuminated field is 90deg rather than the XPG's 125deg. The result should be more light down the center where its needed. Use a highly specific short focal length lens.
Edit:
