ArmyTek
Page 1 of 3 123 LastLast
Results 1 to 30 of 61
Thread: Blame the Battery ....
    Flashaholic* old4570's Avatar
    Feb 2009
    Melbourne - Australia
    Default Blame the Battery ....
    Well as the heading suggests , seems a lot of folks blame the battery when something goes wrong ...
    Lets get one thing straight right away - Li-ion's have the potential to be DANGEROUS ! This is a fact no one should underestimate ...
    A lack of knowledge or due care can result in potential disaster ...
    Buying cheap cells has its risks , quality control , discharge capability , and even internal capacity ..
    These things may not be an issue in single cell lights ... In fact all you may suffer is diminished output and shorter run time , possibly even longer run time [ BRC3000 ] .
    And in no way does it mean that buying expensive cells is safe , lets get that straight as well , what you hopefully are buying is better quality control and more closely matched cells in terms of performance ...
    Single cells lights will always be safer than multi cell lights , its just a Li-ion fact ..
    The more cells you run , the greater the risk , especially in series ..
    Most of the incidents involve multi battery set ups , is from what I would consider a lack of due care on the users part ..
    So lets for a moment look at what U the multi battery user should be looking for ...
    To start with , OFF THE CHARGER !
    Dont , ever , pull the batteries off the charger , measure voltage and then throw them in a light .. It takes 30 minutes to 60 minutes for the battery to stabilize .. Fresh of the charger it might give a reading of 4.2v after 30 minutes it could be 4.19v or 4.18v and after on hour it could be down to 4.15v .. It depends on the quality of the individual cell .. Fresh readings can give you a false battery state , you need to establish the quality of each cell you use ... Are you doing this ?
    Next , discharge capability .. The higher performance the light [ the more current it draws ] the more important it becomes to match the discharge of the cells . Are you matching the discharge capability of your cells ?
    Cell capacity , again can vary some what , more possibly with cheap cells . Imagine if you will one cell has 2400mA capacity while the other may go 2550mA ,
    What can happen : When you dont match the cells or use due care ...
    Of the charger .. You think there fully charged , but one cell sags to 4.15v and the other does not .. Its not a huge variable , and under low current applications may be nothing worth worrying about ..
    Next Discharge capability , one battery [ lets say the one that goes 4.15v after a bit of sag after charging ] has less discharge capability , whilst the other has very good discharge capability ...
    Lets say you light draws 1.5A @ 8.4v for 12.6W [ SSC P7 for arguments sake ] What we may find is that the not so good cell gets stressed much worse than the good cell , and over a short time degrades even more ..
    To the point that the two cells are dangerously out of balance . And lets not forget the real capacity of each cell , if its out , it will contribute to an out of balance state ...
    Seems a lot of incident occur with new lights , and the operators dont test anything , and assume too much ..
    Mixing used with new cells also seems to be an issue ..
    How many actually own a multimeter ?
    Im sorry , blaming the battery ? Sure you need a scape goat , I can understand that , its the way of the modern world , no one seems to want to take responsibility for there own actions ...
    You should
    If you use Li-ion in a multi battery set up , BUY A MULTI METER , if you dont , then dont dare post here how the batteries failed you and vented ..
    Let the batteries sit for a least one hour after charging , and then test them for voltage state ...
    If you run a really high performance light , go to the trouble of matching the batteries for current delivery ...
    Before charging the batteries [ after use ] test voltage state , take note of the position of the battery , you want them to be as close as possible after use .. You dont want to see one battery @ 3v and the other at 3.5v ..
    Are you testing after use ?
    For single battery users , the only real issue is , shorts , over discharge , and making sure you have your charging method sorted out , monitor the charger if its does not terminate on completion ...
    If you fail to do your part , the batteries may fail you , dramatically and possibly dangerously ...
    If you dont own a Multi meter , you Blind to whats going on , blind people dont see anything ..
    Dont go to the trouble of matching cells , again , you have no clue to whats going on ..
    Dont test , and test more , how do you know whats happening ?
    Seems a lot of folks are prepared to pull the pin on a hand grenade and put it in there pants ..
    Yeah , must be the battery !
    When I hear this stuff , it makes me think of the idiots cleaning there guns and shooting a family member , because they didnt know the gun was loaded .
    Li-ion has the potential to be DANGEROUS !
    And people have the capacity to be even more dangerous ..
    So the only question remaining to be answered , are you a safe Li-ion user , or a Dangerous one ...
    I havent covered everything , but hopefully enough !
    Be safe everyone ...
    Flashaholic* lctorana's Avatar
    Jun 2007
    Melbourne, Australia
    Default Re: Blame the Battery ....
    Great post. Well thought out.
    Flashaholic* don.gwapo's Avatar
    Feb 2010
    My avatar!
    Thanks. Learned something from you. So i'm a little bit on the safe side coz all my lights are single cell.
    Pick the pooch!
    Flashaholic* LEDAdd1ct's Avatar
    Jul 2007
    Hudson Valley
    What you say is true, and though not cause for alarm, is cause for thought, especially folks not familiar with multi li-ion setups. I am having a light made with 2x26650, in series. This has the potential to be dangerous, since they are unprotected and, as noted, in series. However, I do own a multimeter, I will own a good charger, and I will test the cells to see how closely matched they are.
    Like most things in life, this is a balance, with the responsibility on the user split between the physical and the mental:
    Physical
    1) Did you buy quality cells?
    2) Did you buy a quality charger that terminates properly?
    3) Do you own a quality multimeter?
    Mental
    1) Are you aware of the proper care and feeding of said cells?
    2) Do you know how to operate your multimeter?
    3) Are you familiar with the terms commonly used with these cells?
    4) Do you know who some of the electrical "experts" on CPF are to seek assistance from, or, do you have someone in your family/house/peer group knowledgeable in same?
    5) Are you prepared to measure your cells, especially in high drain, multi-cell configurations, for close voltages?
    6) Are you aware of the current drain of the particular light you intend to use said cells in, and, the equations necessary to calculate, for a given set of cells with a given capacity, what an appropriate amount of runtime is?
    I believe that to paint the [potentially] dire consequences as entirely the fault of the goods or entirely the fault of the user is constructing a false dilemma, when, in fact, the responsibility is shared between the two. Unsafe materials and/or oversight in materials handling are both dangerous.
    That said, this is a fine hobby, and there are many beautiful lights with li-ion cells and li-ion cells in series. However, each user must be prepared to undertake the responsibility in obtaining the proper goods and learning/maintaining the proper behaviors to use them safely. Good behaviors over time become good habits, and it is a measure of both the material [goods] and immaterial [behaviors] that is required for safe operation in the li-ion realm.
    Most important of all, there is nothing shameful in asking for help. Every member of this board had a "1" in the top right corner of their posts at one point in time. If you are new to these cells, this chemistry, or this hobby, read the many well-written articles already posted by members, search, and if you are at all uncertain, ask!
    Feb 2009
    Was I trying to scare people , a little !
    At the very least , to respect the Li-ion's power .
    To possibly impress upon them the higher standards needed when taking greater risks . And I think multi battery use has proven itself , some what risky , and in need of some care .
    Anyone can drive a car at 10MPH , it takes great skill to drive one at 200MPH
    Flashaholic* TooManyGizmos's Avatar
    Jan 2006
    Died Nov. 2015
    YEP ....... that pretty much sums it up .
    ( Learn how to pack that parachute properly ..... BEFORE you take the LEAP !)
    ~ "She" says ...... I have ... TooManyGizmos ~
    Flashaholic* mrartillery's Avatar
    Mar 2007
    north carolina
    Very nice thread! Li-ions are very under estimated, hopefully a lot of people will read your post.
    Nov 2005
    CT
    Old4570, that was an excellent post, and demonstrated most of the key points. Only thing I would add is to say "Generally, buying cheap cells has higher risks..."
    Again, thanks very much for this post!
    Jul 2009
    Tennessee
    Which of these risks remain when using Lithium Manganese chemistry cells?
    --flatline
    Flashaholic* Battery Guy's Avatar
    Apr 2010
    Portland, Oregon
    Quote Originally Posted by flatline View Post
    --flatline
    Lithium Manganese Oxide (aka LMO, spinel, manganese) cannot be overcharged. Unlike all other lithium-ion cathodes (except LiFePO4), the LMO cathode is completely exhausted of lithium ions at the top of charge. Charging to higher voltages may damage the electrolyte and hurt performance, but it will not result in an unstable, unsafe cell.
    In comparison, you have only removed about half of the lithium ions from an LiCoO2 cathode at 4.2V. If you charge to higher voltages, you will continue to remove lithium and put charge into the cell. So overcharging an LCO cell to higher voltages puts more stored energy (more Watt-hours) into it, and it also makes the cell more thermally unstable. Picture old, sweaty TNT and you will have the right idea.
    This is one of the big safety advantages of both LMO and LiFePO4 lithium-ion cells.
    However, what everyone must remember about ALL lithium-ion batteries is that they use a combustible electrolyte. The combustion energy of the electrolyte is actually equivalent to the stored electrical energy of the battery. Basically, all bets are off if you ignite that electrolyte, no matter what type of lithium-ion cell you have.
    Cheers,
    Battery Guy
    Friends don't let friends use alkaline batteries.
    Apr 2010
    Portland, Oregon
    I don't know much about most things, but when it comes to batteries I feel that I am relatively up-to-speed with what is going on.
    When it comes to lithium-ion, I would say that I am at the top of my game. I have been working professionally in this field for over a decade, in research, manufacturing, safety and application development.
    So, when I say that I don't feel ready to use lithium-ion cells in my own personal flashlight modifications, I hope that some of you take this to heart.
    When I do start using lithium-ions in my flashlight mods (and that may be relatively soon), I will only use cells from known, top tier cell manufacturers. Since cells from these manufacturers tend to be hard to come by, I will likely harvest cells from a power tool or laptop packs. I will NOT use protected cells. I will either charge the cells individually outside of the flashlight or build a custom pack with balancing leads and use a balancing charger.
    For what its worth.
    Cheers,
    Battery Guy
    Sydney, Australia
    Congrats on a well written post old4570.
    People should not be scared of lithium-ion cells, but have a healthy respect for them, much the same as one would have a healthy respect for venomous snakes. If you treat them properly, they PROBABLY won't harm you.
    This is a great resource for newer members, or people just starting out with lithium-ions. Before I began using Li-ions, I read and reread every warning, MSDS, care and handling sheet, explosion story and general battery rant I could find. A sound knowledge of chemistry and materials science helped too.
    I think in addition to the "threads of interest" in the battery sub-forum, there should be a collection of safety threads. This would be a valuable resource for any user of li-ion cells.
    Edit: While I was writing this, battery guy made his post above, I must say that the more you know about li-ion cells, the more reluctant you would be to put them inside a pressure vessel. As for unprotected li-ions, I find too many people think that because their cells are "protected" they won't fail. They run the cells down until the protection kicks in, slap it in the charger, dump it back in the light hot off the charger. This is plain unsafe, and bad practise. These suckers aren't your garden variety Ni-MH cells, where the worst that can normally happen is a bit of "sticky goop" (electrolyte) coming out.
    A piece of advice for all people using li-ions in lights: Measure the overall current draw from the battery on each mode you use. KNOW how long your light can theoretically last on your cell's capacity, and then take 10-20% off that, for a safety margin.
    I'd rather carry a spare 18650 battery or two individually cling-wrapped in a keep2go tube or similar, than risk killing my battery from overdischarge, or worse, a vent situation from mis-handling. If in doubt, swap out the battery. Always take the most cautious path, not the easiest.
    I am only using AW protected 18650's , and panasonic cr123's, I have a ZTS-MBT1 tester. I have tested all lights with the CR123's. and on the ZTS tester they are all running at the same percentage, I have not yet tested the 18650's,that are in lights now. If I have one light, that is operating off one 18650, At what percentage on the ZTS tester, 80% , 60% ,40%, 20%, should I recharge that 18650? If I am running 2 -18650's in another light, should these 18650,s-- AW protected,,Be always running at the same percentage ??? like is one at 80% and one at 60% bad? I am guessing yes here. -And may I ask at what percentage would you throw away The CR123 batteries?----- And how often do you guys check the batteries you are running in your lights? I know it sounds like I am asking a lot But I am trying to learn MORE. What is the difference between the ZBT tester and the Multi Meter? do I need that too?
    Sydney, Australia
    Jacknife, I recommend you get a digital multimeter to test voltages as well as your ZTS tester. The Multimeter will allow you to match the cell voltages closely, as having two 18650 cells in series with different voltages could be catastrophic. Running Li-ion cells, or even regular lithium CR123 cells at different states of charge (eg 80% and 60% reading on the ZTS) and different voltage (3.7V and 4.13V) will greatly increase the chance of one of the cells reverse charging, venting, and possibly damaging the light and you.
    It is not recommended to drain Li-ion cells below 3.0V for longevity, Below 2.7V will begin to damage the cell.
    I advise you read the articles on:
    http://www.batteryuniversity.com/index.htm
    They are full of great advice, and explanations of the innards of your cells.
    Stay safe,
    Alex
    Battery University ,,pretty cool. Which Multi Meter should I get --one from ZBT?? Suggestions??
    Sydney, Australia
    There are many threads on CPF about cheap multimeters:
    http://www.candlepowerforums.com/vb/showthread.php?t=188177
    http://www.candlepowerforums.com/vb/...d.php?t=283653
    From these, in the US it seems Radio Shack, Harbour Freight and Sears seem to have reasonable quality Multimeters.
    I have an ancient analogue Voltmeter, and a rather old parameters multimeter, both of which are still very accurate (within 0.01V tested with a known 5.0V source) and some newer budget multimeters from Dick Smith Electronics here in Australia. They are probably the same ones you could buy at harbour freight in the US.
    Nov 2005
    CT
    Quote Originally Posted by jacknife View Post
    Thanks for asking about this. You are exactly the kind of member that we want to reach and help you avoid problems. We all started where you are.
    As ASheep answered so well, the digital multimeter (DMM) should be seen as a standard required item if you use Lithium batteries (primary or secondary-rechargeable). I also have and use a ZTS tester, but I use it for Alkaline and NiMH cells.
    There is a great guideline here to see where you are with Lithium Ion cells:
    4.2 volts 100%
    4.1 about 90%
    4.0 about 80%
    3.9 about 60%
    3.8 about 40%
    3.7 about 20%
    3.6 empty
    Most protection circuits prevent charging above 4.25V, and discharging below 2.5V. When a cell is empty, it has a sharp spike downward, so even if it quickly goes to a cell damaging low voltage of 2.5V before the protection PCB breaks the circuit, the cell will rebound back up above 3.1V very quickly if it is healthy, and avoid harming it. One of the best threads on the subject was from one of the truly Great Past Members of CPF, Newbie, here.
    If you are using two Li-Ion cells together, I try to make sure they are within 0.05 to 0.10 Volt of each other (i.e. 4.12 & 4.18V are close enough; 4.0V & 4.2V are too imbalanced to use together.)
    Your other question was seeking guidance on CR123A (primary Surefire type cells) voltages. First, make sure you bought cells from USA manufacturers. Since these are never charged, they are going to start at around 3.25V and only go down.
    When they get down to 2.7 to 2.8V range they are nearly empty, some have drained them to 2.5V. There is less concern about draining them if being used in a single cell light. In multi-cell lights mainly look for voltage imbalance between the cells. A pair with 2.8V & 2.91V would concern me less than a pair of 3.1V and 2.99V, because there is more energy in the latter pair.
    Here is something I find curious and cannot explain.
    I have various used Surefire CR123A cells. If I check the voltage with two of them having 05-2015 dates on their side, my Fluke 189 DMM gives a reading of 3.05 Volts. Putting those cells on my ZTS (MBT-1) CR123 + terminal, it reports 10% remaining.
    I have two other SF cells with 05-2018 dates, that measure 2.91V, but on the ZTS, they report 40% remaining. Neither pair have been recently used. I suspect it must have to do with the dates, but the resting voltage becomes confusing.
    Nov 2005
    CT
    Quote Originally Posted by Battery Guy View Post
    For what its worth.
    Cheers,
    Battery Guy
    BG, first make sure you read that thread by Newbie. You especially will appreciate it. You remind me of him.
    Could you share your thoughts/concerns on not using protected cells? There is a reinforced idea (whether right or wrong) of the PCB providing a layer of insurance, but it is hard to test if all of its components are working properly. There are also more known incidents here of primary Lithium cell problems than secondary, which lulls us into perhaps feeling more secure using them than we should.
    Thanks.
    Flashaholic* jasonck08's Avatar
    Sep 2007
    Redding, CA
    Quote Originally Posted by LuxLuthor View Post
    4.2 volts 100%
    4.1 about 90%
    4.0 about 80%
    3.9 about 60%
    3.8 about 40%
    3.7 about 20%
    3.6 empty
    Really depends on the cell itself, these figures are quite off for some cells, such as a 3.6v nominal Samsung 2200mAh cell I tested recently. Here were my capacity results from this cell:
    4.20v - 100%
    4.08v - 90%
    3.96v - 80%
    3.84v - 70%
    3.74v - 60%
    3.66v - 50%
    3.61 - 40%
    3.55 - 30%
    3.51 - 20%
    3.47 - 10%
    3.31 - 0%
    These are resting voltages taken after discharging the cell 10% of its actual capacity and then measuring the resting voltage after 10 minutes.
    Nov 2005
    CT
    Quote Originally Posted by jasonck08 View Post
    4.20v - 100%
    4.08v - 90%
    3.96v - 80%
    3.84v - 70%
    3.74v - 60%
    3.66v - 50%
    3.61 - 40%
    3.55 - 30%
    3.51 - 20%
    3.47 - 10%
    3.31 - 0%
    I agree there is variation among most cell brands, further complicated by variation in models of a particular brand, and then between cell batches of the same brand model, age of cells, and degrees of use/abuse over time, but are nonetheless useful guidelines often posted by knowledgeable members, such as Silverfox.
    Jul 2009
    Tennessee
    So does that mean that the only quality cells available are 18650s? Or do top tier cell manufacturers also make RCR123s?
    The reason I'm asking is that I finally broke down and bought a 1xCR123 light (HDS high-CRI clicky) and 2 protected AW RCR123s. Is it your recommendation to just suck it up and use primary CR123 cells instead of rechargeable cells?
    --flatline
    Jul 2007
    Hudson Valley
    For the HDS, you can purchase the 17670 tube, and use AW cells. :-)
    Apr 2010
    Portland, Oregon
    This is true, and the values that Lux gave should only be used as a general guide.
    A long, long time ago (pre-2000), nearly all lithium-ion cells were made with essentially the same type of carbon for the negative electrode and LiCoO2 as the positive electrode. Today, there are different varieties of carbon and different metal oxides used, and these may shift the OCV at a given state of charge by 100 mV or more. There are even some commercially available lithium-ion cells that require charging to 4.3 V in order to be at 100% SOC.
    So there is no OCV vs SOC curve that works for all lithium-ion cells. Even cells that use LiCoO2 can be quite different because of differences in the type of carbon used and the anode:cathode balance. And to make things even more complicated, as a lithium-ion cell ages, the anode:cathode balance shifts and the OCV vs SOC relationship will also change.
    So the best thing to do is exactly what you did: make your own curves for your own cells. There is no substitute for that.
    Just remember that the amount of time that you let the cell rest will also affect the results. You might be surprised in the difference if you repeated your test, but let the cells rest for 2 hours instead of 10 minutes.
    Cheers,
    BG
    Jul 2009
    Tennessee
    Quote Originally Posted by LEDAdd1ct View Post
    If BatteryGuy doesn't trust the quality of AW cells, I don't see how his recommendation would be different between AW 17670 and AW RCR123 cells.
    --flatline
    Flashaholic* Fusion_m8's Avatar
    Dec 2005
    Melbourne, Australia.
    Thanks Matt, a.k.a Battery Legend!
    Before we can become old and wise, first we have to be young and foolish.
    When I die, I want to be like grandpa, peaceful and asleep. Unlike his passengers, screaming and yelling...
    Apr 2010
    Portland, Oregon
    --flatline
    I never said that I don't trust the quality of AW cells. In fact, my experience with AW leads me to believe that he is fully aware of the quality issues among various cell manufacturers and sources his product very carefully. I would say that AW is an exception to the rule.
    Cheers,
    BG
    Apr 2010
    Portland, Oregon
    The larger, more established cell companies tend not to mess around with the goofy cell sizes that have low sales volumes. Therefore, you will usually only see 18650s, 26650s and 18500s available for purchase or harvesting from OEM battery packs.
    Of all of the top tier manufacturers, Sanyo seems to have the largest variety of cell sizes, and they do make a RCR123 (also called an LC16340). You can find them forsale on Battery Universe here.
    Cheers,
    Battery Guy
    Jul 2009
    Tennessee
    Cheers,
    BG
    I apologize for putting words in your mouth. I didn't remember seeing AW in your list of trusted manufacturers earlier (either in this thread or another) and just assumed that you didn't trust AW.
    But I'm glad to hear your opinion of AW since I've got 2 AW RCR123 (16350?) cells on their way for my new light.
    --flatline
    Is there any Risk in testing Batteries, The ZTS tests under load, And I thought I read somewhere that you have to be careful testing with A multi tester, Is there risks testing batteries with any of these??
    Flashaholic* 45/70's Avatar
    Oct 2005
    Rural Ohio
    Just a few quick comments. Regarding why AW's cells are preferred by many on these forums over other Chinese cells, it has a lot to do with experience. Some of us that have used both AW's and the others over the past 5-6 years, like myself, have seen a marked difference. AW's cells nearly always have more consistency from cell to cell than the other brands, which is critical for series applications. This doesn't mean that you will never get a bad cell from AW, but I never have. This is something I can't say about cells from other distributors, such as xxxxxFire. Also, new cells from AW nearly always have better voltage retention than the others. This is a sign that the cells that AW provides are newer. Keep in mind that unlike NiCd/NiMH cells, all forms of Li-Ion cells start to degrade significantly, from the day they are manufactured, whether they are used or not.
    Another factor that those fairly new to using Li-Ion cells may not be aware of, is that just because a new cell performs well, doesn't mean that it will perform as well 10, 20, or 50 cycles later. In my experience, AW's cells outperform other distributor's in the long run. They retain usable capacity for more cycles, and retain their consistancy from cell to cell, far better than any of the others. That doesn't mean that you won't come across a good sample from the other distributors once in a while, but this very inconsistency is a problem. You can never be as sure, what you're going to get.
    As I have mentioned in other threads over the years, I don't know how it is, that AW manages to provide better cells, but I suspect that he has a close relationship with one or more of the 3(?) Chinese Li-Ion cell manufacturers. This possibly allows him to get "first pick" among the surplus cells manufacturer's offer. This no doubt would cost him more, and the additional cost would obviously have to be reflected in the price of his cells.
    As for determining the estimated capacity of LiCo Li-Ion cells by measuring the OC voltage of the cell, the various charts/tables that are commonly used, were never intended to be an absolute means of estimating capacity. Also, years ago, when most all Li-Ion cells on these forums were LiCo, it was understood even then, that voltage readings below 3.80 Volts were not as accurate, due to differences in the actual composition of cells from different manufacturer's. Jason's findings seem to reflect this.
    Dave
