[ QUOTE ]
batterystation said:
That is pretty common for deal SLA or gel cells. They read good voltage but due to lack of good plate surface area cannot produce any usable current.
[/ QUOTE ]
This is why when you want to determine how good a lead acid battery is you 'drop test' it.
This involves applying a heavy load and measuring for volts drop.
On large batteries, this heavy load can be the equivalent of a 1/4 ohm (or less) resistor, and the currents involved will be substantial.
(Thus should be carried out wearing a full face shield, arm length rubber gauntlets, wellington boots and a rubber apron, as if the battery goes BANG! you get showered with hot sulphuric acid) /ubbthreads/images/graemlins/ooo.gif
