[ QUOTE ]
Stefan said:
The writeups for the Rayovac sound promising. Keep in mind though that to use the 15 minute charger you MUST use the batteries that come with it, as they are the only ones so far that are designed for that system. I'm guessing that any other battery will probably be a BAD idea!
[/ QUOTE ]
YES!! The Rayovac charger is meant soley for the "15 minute charge" cells. Using any other type of cell would be very bad. I thought Rayovac was going to use some physical means to lock out other types of cells from being able to use the charger, but not having seen them I don't know how they would accomplish that.
I posted about these NiMH cells a while back. Each cell has a mechanical switch in it. As the cell reaches full charge, gasses begin to form causing the internal cell pressure to begin rising. This increased internal cell pressure pushes on a diaphragm which then opens a switch inside the cell - disconnecting it from the charger. The charge senses the disconnect and cuts off the current to that cell so that when the pressure drops as the gasses recombine, the cell will not start chrging again.
Actually this is an ideal way to sense full charge on a given cell, but time will tell if this implementation is reliable. (Like what might happen after a year and a few hundred charge cycles, if the switch should fail. Perhaps the charger has a high temp safety cutoff? Also, can the switch handle the kinds of current we here might suck out of the cell /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif without damage?).
