prof student
- Joined
- Nov 14, 2007
- Messages
- 373
Ok, well at least mine does.
So, here is the issue. BEFORE any one goes "oh, they are so cheap, just buy a new one", that isn't the issue here!
I have an old mini maglite incan. The other day it just suddenly stopped working. Put in new batteries, nothing. Put in a new light bulb, nothing. Then I thought maybe the nitize tailcap crapped out on me. Put the original tailcap on there, stillllll nothing.
Took the same batteries and light bulb in another mini mag, and viola. It worked.
The plastic casing where the light bulb goes in (in the older mini mag), was loose, but it always has been. But I think I made it looser when I took it apart to try to get the older batteries out. There is some corrosion or is it dried up battery acid perhaps in the middle of the tube. I didn't see any at the top though. The metal that makes contact from the plastic parts to the battery looks ok. Not shiny, but not oxidized.
Now, what do you think is wrong that it died on me?
What could possible be done to make work again?
Should I have not taken apart the plastic parts?
Thanks.
Thanks.
