mefistofele86
I received this flashlights directly from ArmyTek for the review. It was shipped via Fedex courier and took only 4 days to arrive at my house. Faster than dhl for me
-LED Cree XP-G (USA) is driven by 1.5A (R5 with 1C tint)
- Uses 2nd generation of LED drivers
- 3 types of current stabilization are selectable by user: full stabilization (FULL), simple semi-stabilization as for the buck driver (SEMI) and stepped stabilization (STEP).
- The real long duration and the flat runtimes with FULL stabilization for one 18650 Li-Ion battery at each mode against the standard buck drivers.
- The specially calculated long-range reflector intended for LED Cree XP-G (light beam with the angle of 5 degrees for the distances of 200 meters).
- The changeable quantity of modes and maximal tuning of them.
- The voltage supply selection, which allows using the batteries without protection board (PCB).
- Maximal mode without thermal runtime limits.
- The O-rings and threads are greased by Nyogel 760G. The tube 5ml is included.
- The Firefly mode 0.1 lumens with runtime up to 100 days.
- Battery options: 1x18650/2xcr123a/2x16340.
-Lenght 6.1" (155mm), head diameter 1.43" (36,5mm), body 1" (25,4mm), weight 4-23oz (120g).
-Made from T6061-T6 aluminium.
There are several other features that we will see later.
The flashlight arrives in a small cardboard box that immediately shows the colors of the torch: yellow and black. The box includes the torch with clip installed (which I have removed), 2 O-rings,a rubber button, a lanyard, a 5 ml tube of 760G NyoGel and a really well done holster.
The flashlights is longer than the competitors because the head must accommodate a very deep reflector. Despite it's longer than the average, weighs 120g like the M20.
CONSTRUCTION
I begin by saying that the coating of the torch is different from anything i have touched. ArmyTek declares a hardness of 400HV, which is the typical hardness of a good HAIII. Is almost rubbery to the touch, it's not as soft as a rubber, but provides excellent grip. The level of finish is excellent, with no missing dots. The thicknesses are similar to those of M20.
The flashlight consists in three parts: head, body and tailcap.
The bezel is made in stainless steel and the golden color is the result of a titanium coating. This coating is 10 times harder than HAIII. The thickness of steel is less than the M20. The lens is well recessed in the head and the distance between the lens and the end of the bezel is 1 cm. The lens is about 2mm thick (source ArmyTek).
The smooth reflector is very wide and deep. It houses a LED Cree XP-G R5 1C. ArmyTek wanted to use S2 LED but it's difficult to find them with a good tint.
The head is long because of the reflector. The sophisticated design and the particular coating provide good grip despite the lack of knurling. Very good anti-roll design.
The positive pole is flat, there are no springs. I do not have flat-top batteries but I guess they will work without problems.
The threads have triangular section. At the head side they are more numerous to withstand the intense use of the twisty mechanism and they are not anodized because it passes current. At the rear threads are anodized and less numerous. The threads work perfectly and thanks to NyoGel i almost does not feel friction. Double O-rings on both sides. The size of O-rings is correct and not exaggerated like it happens with some flashlights. Threads and O-rings are well greased. The lettering is clear and precise.
On the negative pole there is a spring covered with a metal cap. There aren't holes that allow you to unscrew the metal ring to access the switch. You can access by unscrewing the golden ring of the tailcap.
The tailcap ends with a SS ring with the same titanium coating of the bezel (and clip). The flashlight does not tailstand. The rubber button is relatively hard to operate. There's an hole to use a lanyard. Unscrewing the tailcap of half a turn will prevent accidental activation.
I removed the clip after removing the two O-rings. At this point the space previously occupied by the clip remains empty. I will install a black o-ring.
Without the clip i feel the grip more comfortable. On the body there are four long and deep grooves which increase grip.
The holster provided is of excellent workmanship. It has numerous loops that allow to carry it in vertical and horizontal position.
ELECTRONIC ELEMENTS and little more
The circuit stabilizes the current, this means that the regulation is great with any type of battery, even with a single 18650. This is the only flashlight that lets you choose the type of current stabilization. There are three types of stabilization.
1-FULL: full stabilization with every type of battery.
2-SEMI: partial stabilization.
3-STEP: stepped stabilization.
With the FULL stabilization output remains constant, even at the highest level. With the SEMI stabilization, output will decrease gradually while with the STEP stabilization, output will decrease in steps, ie the output remains constant and decreases occasionally slighty.
If you choose SEMI or STEP stabilization, runtime will be greater, in particular at the highest level you earn about half an hour.
There is a temperature sensor, especially useful for preventing damage to the LED. In the event of overheating it leads the brightness at a lower level (7 lumens).
The heat is disposed of effectively. I used the flashlight for more than 15 minutes at the highest level and most of the flashlight (head and body part) is heated uniformly and moderately.
Predator can memorize the last level used in each line.
Finally, it is protected against reverse polarity, it is an electronic protection.
USER INTERFACE
Thanks to forward switch you can turn momentary on by half-pressing the button. If you have the auto memorizing activated, flashlight will turns on momentary at the memorized level.
Predator has two lines of modes. With tightened head you have access to the first line and with the loosened head you have access to the second line. To change the modes you have to loosen/tighten the head (quarter-turn) in the first line while you have to tighten/loosen in the second line. Predator is fully programmable. In the first line you can change the brightness of each level as you like but special levels are available only in the second line (strobo, sos, Firefly, beacon..).
In the second line of modes you have also access to the general setting menù. There are seven options to customize the flashlight.
Option 1- it allows to program the selected level. You can choose also special levels, ie sos, strobo, beacon and the Firefly mode. Talking about strobo, you can change the frequency from 1 to 50hz. Firefly mode is very usefull at night with its 0.1lm brightness and it has a truly long runtime, about 100days.
Option 2 - it allows you to reset the flashlight. You can choose between two different settings, Military and Outdoor. Military: FULL stabilization, first line 500lm-100lm-7lm second line: 15hz Strobe, Firefly. Outdoor: STEP stabilization, first line 65lm-350lm, second line: 15hz strobe-7lm-Firefly.
Option 3 - it lets you to choose how many levels you want in the first line. You can choose from a minimum of 1 to a maximum of 10 levels of stabilized light.
Option 4 - it lets you to choose how many levels you want in the second line. You can choose from a minimum of 1 to a maximum of 5 levels, including special levels.
Option 5 - it lets you to choose the power supply, or the type of batteries you use. 2XCR123A with a minimum voltage of 0V (complete discharge), this is the voltage selected by default. 1X18650 3.7V with a minimum voltage of 2.8V. 2X16340 3.7V with a minimum voltage of 5.6V. 1X18650 3.2V LiFePO4 with minimum voltage of 2.5V. With this feature you can also use non-protected batteries without any problems.
Option 6 - it allows you to choose the type of stabilization: SEMI-FULL-STEP, FULL stabilization is setted by default.
Option 7 - it allows you to enable or disable the memorizing of last used level for each line.
You can definitely customize the user interface as you prefer.
OUTPUT
Brightness
The LED XP-G R5 is driven at 1.5 Amps, then the brightness is really great. ArmyTek declares 500 led lumens thus here we have about 350 OTF lumens. Ceiling bounce test shows well Predator capabilities.
Tint
ArmyTek originally wanted to mount S2 LEDs but it was discarded as i said before because of the tint. Led R5 1C has a beautiful tint, exactly what one would expect from a Cool White. That is a cool white but it is not vitiated by blue / green / purple colors. I appreciate and agree with the choice of LED R5.
Beam pattern
THROW! The smooth and deep reflector provides an exceptional throw . It clearly outthrows the Olight M20 R2 with smooth reflector, which is credited to about 13,000 lux at 1 meter. The Predator is real Thrower. The spot is small, defined and very intense and it has no hole in the middle. Around the spot there is a very bright corona. Then there is a spill of limited extension but very bright. The beam is characterized by some rings, they are visible on the white wall at close range. There are no dark areas or holes, and when i use the flashlight outdoor the beam is very pleasant. Imperfections are very limited, the beam is much cleaner than the M20 with smooth reflector (LED XR-E).
In particular, i find very usefull the corona around the spot because i can intensely illuminate a wide area at medium distance.
BEAMSHOTS
I decided to compare the Thrower of today (Predator) with a Thrower of yesterday (M20R2 smooth reflector). These flashlights have similar size and both have a good throw if we consider their size. The Predator uses a 2200mah AW18650 while the M20 uses 2xAW16340 (750mah) for best performance. Unfortunately it was raining and I could not do more photos. However the result is pretty good. White balance: daylight.
First set, 12 meters from the wall
Second set, 24 meters from building
Third set, 34 metri from the wall
Throw in particular
Fourth set, 15 meters from the wall
Ceiling bounce test
We have a special guest
CONCLUSION
The ArmyTek Predator is a concentration of power, throw and versatility. All this in a compact size after all. The user interface adapts to everyone needs and offers extreme personalization. The overall quality is excellent.
I particularly liked the perfect regulation with a 18650, few flashlights are capable of this. The price is high but I think it is justified in part by the research work behind this flashlight.
I suggest it to anyone who wants a cannon of light in the pocket, to those who like to customize the interface and to those who really want the most out of XP-G R5.
I don't recommend to lovers of floody lights and to those who always use the torch as a candle.
I promote this flashlight with honors and in my opinion it worths its price (149usd shipped).
This ArmyTek is truly a night Predator.
CONSTRUCTION
USER INTERFACE
OUTPUT
Brightness
Tint
Beam pattern
BEAMSHOTS
Throw in particular
Ceiling bounce test
CONCLUSION
