Re: Why Tigerlight 8
Hello Ray,
I have no idea why you would want an 8" TigerLight, other than it is a very durable bright light that is fun to use because of the long lasting lamp and the rechargeable batteries. I have the full sized ones and use them all of the time.
Issues involve consistency with lamps, the position of the switch, and the charging time. I have not found those issues a concern, but your mileage may vary.
I get a little over 65 minutes on a full charged battery. The NiMh batteries have a reasonably flat discharge curve, so when the light goes dim, it drops off fast. I was concerned with the hour run time and the long charge time, so I got two of them. Two hours of bright light is just right for my uses.
The most fragile part of my light is the replacement UCL lens on one of them. The plastic lens will not break when dropped on the bezel, but the UCL lens may. I must warn you that a run time test with the UCL lens is OK, but the stock lens will start to melt during the test.
I believe it will hold it's own against the Ultra Stinger, but the M6 will over power it. You will still be able to see the hot spot of the TigerLight in the M6 beam, but the M6 puts out more light. It is best used as a medium range light.
Good luck in your decision.
Tom
