SCEMan
Any suggestions on getting RediLast 2900 mAh 18650s to work with the EagleTac M3C4 battery carrier? Although the RediLast 18650s are not flat tops, the button area is just large enough that it rests on the raised plastic ring and misses touching the battery carrier + contact point.
No way a magnet or other metal shim will fit as the batts are a tight press fit as it is. This is a bummer as I bought these batts especially for this light...
