No real benefits to overdriving XML
jasonck08
Redding, CA
I've done a little bit of testing with the XML, a bench power supply and an Extech HD450 Lux meter.
So far I've concluded that there appear to be no real benefits to driving an XML past 3A even with proper heatsinking for any length of time!
My heatsink is an Intel CPU heatsink with copper core designed for the Q6600 (95W CPU). The XML is Artic Alumina epoxied onto the copper heatsink.
At 3A in my lab room, I measure the ceiling bounce Lux @ 103 right when I turn on the LED. 5 minutes later I came back and the lux meter was reading 101 Lux. About a 2% drop in 5 minutes.
I then let the heatshink cool down for 5 minutes and started test #2:
At 4A in my lab room I measure a ceiling bounce Lux @ 101 when I cranked the LED to 4A, after 5 minutes, Lux had dropped to 91 Lux! A decrease of about 10%! I turned the current down to 3A and the Lux went up to 98 almost instantly!
Moral of the story. There appears to be no point in driving the XML much past 3A.
jasonck08
Redding, CA
Re:NorealbenefitstooverdrivingXML
Written by mvyrmnd on 01-27-2011 11:49 PM GMT
mvyrmnd said:
This is probably why Cree have only specced it to 3A, when it can clearly take more without failure.
The law of diminishing returns is strong with this one...
Written by jasonck08 on 01-28-2011 12:18 AM GMT
jasonck08 said:
The highest lux ratings I got was around 3.2-3.5A But it was only 2-3lux higher than 3A flat. I've already seen several people on these forums makeXML lights with 4-5A drivers. It seems they are using up more power, killing the LED and getting less lumens.
If anybody else has the ability to try to duplicate my scenario, please do so and report here.
Written by Glenn7 on 01-28-2011 01:58 AM GMT
Glenn7 said:
thats interesting thanks for doing that - so even tho the XLM might be more efficient when driven @ 3 amps than an SST50 but over 3 amps the 50 will give you more lumens & the sst50 can be de-domed to give a much better throw as well - so whats the advantage of thexml other than its "new" and everybody has to have one (point:4sevens does a run of xpg S3 and everybody jumped on it for 7 more lumen's which they couldn't see but they could see the extra green tint) yes they are cheaper but you get less as well - to me it looks like a step up from xpg but a step down from the sst or am I missing something?
Written by znomit on 01-28-2011 02:30 AM GMT
It's competing with the MCE and P7 It's competing with the MCE and P7
Written by jasonck08 on 01-28-2011 03:51 AM GMT
The The XML is the most efficient LED on the market. It's about 20% more efficient than an XP-G R5. The SST-50 and SST-90 will provide more lumens if they are driven harder than 3A
Written by Glenn7 on 01-28-2011 04:20 AM GMT
jasonck08 said:
The XML is the most efficient LED on the market. It's about 20% more efficient than an XP-G R5. The SST-50 and SST-90 will provide more lumens if they are driven harder than 3A.
I thought I basically said the same thing? I thought I basically said the same thing?
Dont take this the wrong way, but if you are going to compare efficiency like that then a 5mm led is way more efficent than an xml, it just doesn't put out as much light ether - maybe what I am trying to say is I would rather more lumen's and carry a spare battery or turn the light down a bit for longer run times but have a brighter high.
Written by sn0wBLiND on 01-28-2011 04:43 AM GMT
sn0wBLiND said:
- Lower Vf, stays regulated longer with a single li-ion and an affordable linear driver in flashlight applications
- Smaller package
- Easier to drive, driver selection for 3A range is a lot bigger than 5A range
- Cheaper, more lm/$
- Smaller die
There are a lot of threads pointing out the differences between these two leds.
Written by Glenn7 on 01-28-2011 05:02 AM GMT
Glenn7 said:
I know all this and I agree.
and you are right, IF you are happy with 400-500 lumens OTF @ 3 amps go with the xml - BUT if you want/need more lumen's than that, according to the OP after 3amps there goes your efficiency, so you might as well go sst that was my point - unless OP has 2 dud leds.
Written by boboweb on 01-28-2011 08:11 AM GMT
If you look at the specifications on paper maybe you are right ,but in practice the things are quite different. The XM-L provides more lumens at the same current. Regardless of whether the current is under or over 3 amps . At 4 Amps XM-L is clearly superior to SST-50. At higher current the heating of the SST-50 also becomes too high and reduces the effectiveness. So the total possible lumens into If you look at the specifications on paper maybe you are right ,but in practice the things are quite different. The XM-L provides more lumens at the same current. Regardless of whether the current is under or over 3 amps . At 4 Amps XM-L is clearly superior to SST-50. At higher current the heating of the SST-50 also becomes too high and reduces the effectiveness. So the total possible lumens into Real World are in favor of the XM-L ...
p.s By the way at 3 amps the lumens are much more than 400-500 OTF ...
Written by bigchelis on 01-28-2011 08:42 AM GMT
bigchelis said:
3A sounds about right.
I can only guess what the current at the LED actually is. We can all do paper math to account for cell sag, driver efficiency, ect..., but we can all hope to be around 3A.
In Direct Drive XM-L 6T builds (2 Surefire L1's for now) I get 4A at the tail, but I am sure the Kroll switch and battery (AW 17670) voltage drops quick and my 4A are more like 3A after all variables are accounted for. I don't have a power supply to confirm this, but its good to see these tests.
Thanks,
bigC
Written by doctaq on 01-28-2011 09:34 AM GMT
doctaq said:
i find this kinda hard to beleive that there is absoluteleyno benefit past the exact spec on the datasheet, i wish my ps went beyond 3a
Written by jasonck08 on 01-28-2011 01:52 PM GMT
doctaq said:
i find this kinda hard to beleive that there is absoluteley no benefit past the exact spec on the datasheet, i wish my ps went beyond 3a
I was shocked. I'll try another LED on a new even better heatsink. One designed for a Core i7 930 (130W) CPU. I was shocked. I'll try another LED on a new even better heatsink. One designed for a Core i7 930 (130W) CPU.
Written by palimpsest on 01-28-2011 02:02 PM GMT
palimpsest said:
Overdriving LED is like overclocking CPU...it is nerdery ! :p
Written by superpila on 01-28-2011 02:05 PM GMT
superpila said:
I have modded a Loongsun LX-9012 which came with an SST-50 and a 5A+ Driver, replacing the LED with an XM-L T6. This flashlight is well built and has very good heatsinking. The top 3 levels deliver 5.2, 4.2 and 3 ampere. I haveno tools to measure the actual brightness, but on a subjective ceiling bounce test It seems to me that there's no difference between 5.2 and 4.2, but there's a noticeable difference between 4.2 and 3.
I don't have the camera at hand right now but as soon as I get it back I'll post some beamshots.
Written by bao123 on 01-28-2011 06:42 PM GMT
bao123 said:
Do retest. I find it extremely hard to believe when looking at the Relative Luminous Flux (%) vs Forward Current (mA) curve from their datasheet. Despite the fact that the curve only goes to 3A, it's unreasonable for the curve to suddenly reach a limit or even dip at that point. Your heatsink has a copper slug, right? I estimate it has at least 200g of aluminum and about the same in copper or a specific heat capacity of roughly 250 J/C. It really shouldn't heat up more than 10 degrees after 5 minutes even with minimal convective heat transfer.
Maybe something else is at work here.
Written by mvyrmnd on 01-28-2011 10:41 PM GMT
mvyrmnd said:
This may throw the cat among the pigeons, but check my post (#16)in this thread for some mathematical verification of these claims.
Personally, I see that the XM-L is brighter at 4A than 3A, but that would appear to be the upper limit of its abilities. More current after that just makes more heat.
Techjunkie
in the brightly lit suburbs of NYC (Long Island)
I think I was able to recover everything (pics included) using Tandem's tool and Google cache. Search Google's cache with the syntax:
cache:https://www.candlepowerforums.com/threads/308569&page=4
Change the page# at the end and search again a page at a time.
PAGE 1:
Norealbenefits tooverdrivingXML
Written by jasonck08 on 01-27-2011 11:14 PM GMT
I've done a little bit of testing with theXML, a bench power supply and an Extech HD450 Lux meter.
Re:Norealbenefits tooverdrivingXML
The The XML is the most efficient LED on the market. It's about 20% more efficient than an XP-G R5. The SST-50 and SST-90 will provide more lumens if they are driven harder than 3A.
- Smaller package
- Smaller die
If you look at the specifications on paper maybe you are right ,but in practice the things are quite different. The If you look at the specifications on paper maybe you are right ,but in practice the things are quite different. The XM-L provides more lumens at the same current. Regardless of whether the current is under or over 3 amps . At 4 Amps XM-L is clearly superior to SST-50. At higher current the heating of the SST-50 also becomes too high and reduces the effectiveness. So the total possible lumens into Real World are in favor of the XM-L ...
Thanks,
bigC
I have modded a Loongsun LX-9012 which came with an SST-50 and a 5A+ Driver, replacing the LED with anXM-L T6. This flashlight is well built and has very good heatsinking. The top 3 levels deliver 5.2, 4.2 and 3 ampere. I have no tools to measure the actual brightness, but on a subjective ceiling bounce test It seems to me that there's no difference between 5.2 and 4.2, but there's a noticeable difference between 4.2 and 3.
Written by jasonck08 on 01-28-2011 11:45 PM GMT
mvyrmnd said:
This may throw the cat among the pigeons, but check my post (#16) in this thread for some mathematical verification of these claims.
No offense, but those numbers are completely inaccurate and the numbers past 3A are useless IMO. I've done a second test with a different LED. First one was a T6 2T and 2nd one is a 2D T6. This time I used a much larger heatsink. Results are the same (I'll post them in a few minutes). The XML is brightest at like 3.2 or 3.3A. Any more current and the brightness backs down. If you have proof that an XML at 4A is brighter than at 3A, I'd like to see it. Also, keep in mind that when Cree first announced the XM-L they hinted at a 2A drive current. They bumped up the max current rating shortly before release to 3A, similar to the XP-G increase to 1.5A.
LED current / lumen charts are NEVER linear! There is always a point with a LED where an increase in current yields a decrease in brightness.
Unknown
Written by mvyrmnd on 01-28-2011 11:51 PM GMT
I agree. Now read post 16 as I suggested.
Written by jasonck08 on 01-29-2011 12:12 AM GMT
mvyrmnd said:
I sent the data from PCT to my father, who is an engineer and is far better at maths than me
While that chart looks a little more accurate, it doesn't agree with my current testing conclusion that anything past around 3.3A or so results in a decrease in luminous flux. You said you got sent data from PCT. What data? Please provide more information... While that chart looks a little more accurate, it doesn't agree with my current testing conclusion that anything past around 3.3A or so results in a decrease in luminous flux. You said you got sent data from PCT. What data? Please provide more information...
Written by jasonck08 on 01-29-2011 12:43 AM GMT
A graph to represent my 2nd set of tests.
New LED, new wire 22AWG, larger heatsink (edit: Arctic Alumina thermal compound). Same PSU and Lux meter, but positioned slightly different.
Here is a simple bar graph to display the latest test results.
As you can see initial brightness at 3.5A is a tiny bit brighter than @ 3A, but the actual lux reading at 5M was slightly less than the 3 Amp test @ 5M.
Exact readings taken and used for the graph:
3.0A: 97.3 Lux @ 5M 95.8
3.5A: 99.3 Lux @ 5M 95.7
4.0A: 92.0 Lux @ 5M 87.8
Unknown
Written by mvyrmnd on 01-29-2011 12:57 AM GMT
All of the data points in the graph up to 3A were supplied by Cree from their PCT website. It's linked to in the thread.
The graph is correct, assuming that all other things that can affect luminous flux remain equal. It does not in any way reflect the real output once things like heat are taken into account. Your results are showing the effect of heat on the values in that chart.
Written by csshih on 01-29-2011 01:24 AM GMT
here are my findings.
my experiment used a CPU cooler (Just the heatsink, no fan) - better heatsinking than most lights but indeed Jason is correct.
the chart does not match up with Cree's because they probably have a TEC setup which ensures a 25C Tj.
Written by jasonck08 on 01-29-2011 01:53 AM GMT
Well not all of your graphing was from the Cree PCT website, because their tests don't go past 3A, that's why I questioned your source. I thought you were referring to an individual, not the Cree data sheet tool. Also Craig is correct, the data sheets specify a 25C Tj temp, which is not possible at these drive currents (for any length of time), unless one is using a TEC, water cooling, liquid nitrogen, a compressor or some other bazaar setup. The tests you see in this thread are even overly optimistic for flashlight use. What kind of single Well not all of your graphing was from the Cree PCT website, because their tests don't go past 3A, that's why I questioned your source. I thought you were referring to an individual, not the Cree data sheet tool. Also Craig is correct, the data sheets specify a 25C Tj temp, which is not possible at these drive currents (for any length of time), unless one is using a TEC, water cooling, liquid nitrogen, a compressor or some other bazaar setup. The tests you see in this thread are even overly optimistic for flashlight use. What kind of single XM-L flashlight is going to have a heatsink designed to dissipate 130W of heat!
@ Craig
Very nice tests. And your results are similar results to mine. Yours do show a very very slight increase in output when you increase current past 3A, but its obviously not worth the trade in decreased efficiency. The differences will probably vary from LED batch to LED batch and could even vary depending on how well the LED was mounted on the MPCB, the resistance in the connections on the MPCB to the LED.
My tests were done with 18mm 2D, 2T LED's that were mounted on MPCB's from cutter, and your test LED was from another source.
Written by boboweb on 01-29-2011 02:07 AM GMT
superpila said:
I have modded a Loongsun LX-9012 which came with an SST-50 and a 5A+ Driver, replacing the LED with an XM-L T6. This flashlight is well built and has very good heatsinking. The top 3 levels deliver 5.2, 4.2 and 3 ampere. I have no tools to measure the actual brightness, but on a subjective ceiling bounce test It seems to me that there's no difference between 5.2 and 4.2, but there's a noticeable difference between 4.2 and 3.
superpila check your PMs ;)
Written by mvyrmnd on 01-29-2011 02:15 AM GMT
You seem to say this as though I haven't already pointed out numerous times that my graph was an exercise in mathematics. My graph was a You seem to say this as though I haven't already pointed out numerous times that my graph was an exercise in mathematics. My graph was a theoretical extrapolation of the numbers from the Cree website. The values above 3A were calculated by performing various mathematical functions on the curve that was formed by Cree's data.
I have, once again, pointed out numerous times that these number are only possible if all factors remain equal, which very obviously they can't.
I'm not here to argue with you. Your results are a result of real-world testing, and observation always trumps theory. I was approaching the same result from a different perspective, sans the effect of heat on emitter efficiency.
If you compare my theoretical graph to your measured charts, they're only really different in the final few % at the top of the curve. This is where the output loss due to heat outweighs any extra lumens earned from the increase of current. If anything we should combine out results to get a better indication of the true impact of heat on these emitters.
Written by Walterk on 01-29-2011 04:23 AM GMT
@csshih: Thats a clear graph !
Do you happen to have Lux measurements in that format from that same testrig?
It would give some comparison to other charts like from mvyrmnd in the other thread and Techjunkies beamshots.
Written by ti-force on 01-29-2011 07:21 AM GMT
I always browse through the Homemade and Modified section and see lights that people claim make huge lumen output numbers based on their calculations using the manufacturers datasheets,(some of them are definitelyoverdriving the emitter/s) and every time I think to myself, "Man! I wish this guy would send this light to me for testing, because I know it doesn't make that amount of light OTF, and I'm almost certain it doesn't hold anywhere near that amount for any decent amount of time, but I never say anything to keep the peace, and they never inquire about sending any of these lights to me.
It's almost like they don't really want to know how bad the output drops lol....
Anyway, I've learned that it's best to stay within the recommended specs of these components, but I guess it really boils down to what you really want. I want a light that holds its output pretty well, but the next man may be completely satisfied if his custom light makes 100 more OTF lumens for .5 seconds ;). I've had very good results with these emitters, but I've stayed within spec.
I've modified three different lights with an XM-L T6 flux bin, 2T tint bin emitter. One is a Quark 123-2 at 2.1A drive current, another is a Quark 123-2 Turbo at 2.1A drive current, and the last one is a Maelstrom G5 at 2.8A drive current.
I know this isn't exactly on topic with overdriving these emitters, but I thought these results can be used as a reference in the future for comparison of driving within spec vs driving out of spec. If you don't want my results here please let me know and I'll edit to remove.
My OTF test results taken in my homemade 16" integrating sphere are as follows:
This light is powered by a single AW 17670 protected Li-Ion battery, and it was fully charged for testing.
_______________123-2 Quark, fully charged AW 17670, SB 2.1A driver High Mode_______________
_________________________1 Sec___________585.5__________________________
________________________30 Sec___________562.4__________________________
_________________________1 Min___________552.7__________________________
_________________________2 Min___________549.1__________________________
_________________________3 Min___________545.5__________________________
____________Quark Turbo 123-2, fully charged AW 17670, SB 2.1A driver High Mode_______________
________________________1 Sec_____________613.3_____________________________ _
________________________30 Sec____________585.5______________________________
________________________1 Min_____________578.2_____________________________ _
________________________2 Min_____________572.1_____________________________ _
________________________3 Min_____________566.1_____________________________ _
________________________4 Min_____________564.9_____________________________ _
This light is powered by a single AW 18650, 2600mAh protected Li-Ion battery, and it was fully charged for testing.
_______________Maelstrom G5, fully charged AW 18650, SB 2.8A driver High Mode_______________
________________________1 Sec_____________739.4__________________________
_______________________30 Sec_____________701.8_________________________
________________________1 Min_____________693.3__________________________
________________________2 Min_____________682.4__________________________
________________________3 Min_____________672.7__________________________
Written by recDNA on 01-29-2011 07:51 AM GMT
Those are all great mods and truly impressive numbers. The one that surprises me a little is the G5. That flashlight was built to dissipate heat so I would think it would have a good heat sink? (you tell me)
Nevertheless it still is losing quite a bit of output over 3 minutes. Is there something about the G5 the prevents efficient transmission of heat from the led to the head then to the body?
Written by ti-force on 01-29-2011 09:21 AM GMT
Personally I don't feel that it's losing that much output. I always publish the 1 second output like BigC and MrGman, but I always compare starting at 30 seconds because it's much more consistent. If you will notice, the G5 lost the largest amount of light from 1 sec to 30 sec, after that it's very stable.
Here's a quick comparison of the percentage of the total output from 30 seconds to 3 minutes:
The Quark 123-2 is first- 562.4 at 30 sec down to 545.5 at 3 minutes. This is a loss of 16.9 OTF lumens and a total percentage loss of 3%.
The Quark Turbo 123-2 is next- 585.5 at 30 sec down to 566.1 at the 3 minute mark. This is a loss of 19.4 OTF lumens and a total percentage loss of 3.3%. Very close to the 123-2 non-turbo and the additional output can be chocked up due to the larger reflector of the Turbo model.
The G5 is last, now keep in mind that it's being driven at 2.8A while the other 2 are being driven at only 2.1A. 701.8 at 30 seconds down to 672.7 at 3 minutes. This is a loss of 29.1 lumens and a total percentage loss of only 4.15%. So it's really not losing much more than the other two lights, and it's being driven with roughly 30% increase in drive current vs the other two. Also, for roughly a 30% increase in drive current, the gain is only a 20% increase in OTF lumens over the Turbo model, and some of that is merely from the larger reflector of the G5.
PAGE 2:
Re: No real benefits to overdriving XML
Written by Techjunkie on 01-29-2011 10:09 AM GMT
Your tests are a bit flawed. The epoxy doesn't allow the LED to shed the heat to the heatsink quickly enough, regardless of how big the heatsink is. You could have it epoxied to the Chrysler building and it wouldn't help. Your tests are a bit flawed. The epoxy doesn't allow the LED to shed the heat to the heatsink quickly enough, regardless of how big the heatsink is. You could have it epoxied to the Chrysler building and it wouldn't help.
To test my own 5A builds I ran them for over 20 minutes each. At the end of those runs the XML at 5A were still noticibly brighter than the same setup at 4.2A. I don't have a lux meter, but the side-by-side comparison is obvious to the naked eye and both the 4.2A and the 5A are using the same reflector.
To say that there is no real benefit is misleading. Does efficiency go way down? Sure it does. Does sevice life go way down? I'm sure it probably does. However, if your build is of hotwire mentality where brightness is king and runtime be damned, then there is definitely a benefit to overdriving the XM-L. You just can't use epoxy. Try drilling and tapping some holes into that heatsink and before fastening the star with at least three screws, use good silver thermal grease instead of epoxy. I think your findings will vary.
Glenn7 said:
thats interesting thanks for doing that - so even tho the XLM might be more efficient when driven @ 3 amps than an SST50 but over 3 amps the 50 will give you more lumens & the sst50 can be de-domed to give a much better throw as well - so whats the advantage of the xml other than its "new" and everybody has to have one (point:4sevens does a run of xpg S3 and everybody jumped on it for 7 more lumen's which they couldn't see but they could see the extra green tint) yes they are cheaper but you get less as well - to me it looks like a step up from xpg but a step down from the sst or am I missing something?
I have a top bin 5700K SST-50 that's been de-domed and at every drive current I've tried, in every reflector I've tried, it's brighter than MC-E and P7 but not XM-L. Similarly, at the same drive current in the same reflector, my XM-L builds are all brigher than my SST-50 builds were, which is why I replaced the SST-50 with XM-L in 3 or 4 or my lights. (Most of my XM-L builds were once SST-50). On a side note, de-doming makes the SST-50 easier to focus, but it also comes at the cost of tint change and reduced lumen output. I have a top bin 5700K SST-50 that's been de-domed and at every drive current I've tried, in every reflector I've tried, it's brighter than MC-E and P7 but not XM-L. Similarly, at the same drive current in the same reflector, my XM-L builds are all brigher than my SST-50 builds were, which is why I replaced the SST-50 with XM-L in 3 or 4 or my lights. (Most of my XM-L builds were once SST-50). On a side note, de-doming makes the SST-50 easier to focus, but it also comes at the cost of tint change and reduced lumen output.
Hardly. The output of the XM-L is leaps and bounds higher than either of those emitters. I've tried one for one swaps in the same 53mm MOP reflectors at the same 2.8-3.0A drive currrent and every time there was vast improvement. Hardly. The output of the XM-L is leaps and bounds higher than either of those emitters. I've tried one for one swaps in the same 53mm MOP reflectors at the same 2.8-3.0A drive currrent and every time there was vast improvement.
- Smaller package
- Smaller die
Thank you! Thank you!
Written by jirik_cz on 01-29-2011 11:31 AM GMT
XM-L at 3A has more lumens than SST-50 at 4A (and probably as much as SST-50 at 5A)! At least from the comparison of Olight M31/M3X and Thrunite Catapult with SST-50 and XM-L. XM-L at 3A has more lumens than SST-50 at 4A (and probably as much as SST-50 at 5A)! At least from the comparison of Olight M31/M3X and Thrunite Catapult with SST-50 and XM-L.
Also XM-L throws further than SST-50 in the same reflector.
You can de-dome XM-L as well... You can de-dome XM-L as well...
Written by saabluster on 01-29-2011 02:42 PM GMT
.... The XML is Artic Alumina epoxied onto the copper heatsink.
Congratulations! You have successfully demonstrated how ill-advised it is to use epoxy on these mega-output LEDs. The problem is your setup not the LED. Congratulations! You have successfully demonstrated how ill-advised it is to use epoxy on these mega-output LEDs. The problem is your setup not the LED. ;) Otherwise you are asking me to believe that Cree rated these right up to the bleeding edge? Not a chance. If you are going to do extreme driving it should be soldered directly to a copper heatspreader(not mcpcb) and can then be epoxied down from there.
Written by jasonck08 on 01-29-2011 02:50 PM GMT
Incorrect. My second test was done with Arctic Alumina thermal compound. I'll try Arctic silver next and see if it makes a difference. Incorrect. My second test was done with Arctic Alumina thermal compound. I'll try Arctic silver next and see if it makes a difference.
My second set of tests were done without thermal epoxy. Instead arctic alumina thermal compound was used. Later I'll do some more tests with artic silver see if my results change. My second set of tests were done without thermal epoxy. Instead arctic alumina thermal compound was used. Later I'll do some more tests with artic silver see if my results change.
If you believe that a 5A light is brither than lets see some proof. Send it to someone with either an integrated sphere or a Lux meter.
How did YOU mount your LED?
4A... Maybe but not at 5A. The SST-50 datasheets say about 1250 lumens @ 5A. The XML @ 3A is brighter than 1250 lumens?? 4A... Maybe but not at 5A. The SST-50 datasheets say about 1250 lumens @ 5A. The XML @ 3A is brighter than 1250 lumens??
Written by saabluster on 01-29-2011 03:14 PM GMT
No not incorrect unless you are telling me your own statement is false. No not incorrect unless you are telling me your own statement is false.
My statement was not incorrect just not inclusive enough. Yes indeed your other method is woefully short of the job as well. Just do what I said and solder it. My statement was not incorrect just not inclusive enough. Yes indeed your other method is woefully short of the job as well. Just do what I said and solder it.
Written by csshih on 01-29-2011 03:18 PM GMT
sorry, no, I just placed a box over the emitter to reflect light back onto the luxmeter - I was only looking for relative ratings. sorry, no, I just placed a box over the emitter to reflect light back onto the luxmeter - I was only looking for relative ratings.
but wouldn't it be better to get "real-world" data? I'm pretty sure most run of the mill flashlights dont solder their LEDs to the heatsink. but wouldn't it be better to get "real-world" data? I'm pretty sure most run of the mill flashlights dont solder their LEDs to the heatsink. :)
Written by jasonck08 on 01-29-2011 03:25 PM GMT
First off, I did 2 tests. The first test I specified that I used thermal epoxy. Second test was in post 21. I did not specify that I used arctic alumina thermal compound in that post, but I've edited it now. First off, I did 2 tests. The first test I specified that I used thermal epoxy. Second test was in post 21. I did not specify that I used arctic alumina thermal compound in that post, but I've edited it now.
Secondly, I'd love to solder it. But that's not possible with any soldering iron I have. A heatsink designed to dissipate 130W of heat isn't going to let solder melt and stick with a 40W weller iron. Secondly, I'm not that interested in dealing with bare XML LED's (nor do I have any). 95% of modders and manufacturers only use XML stars, and so far my tests seem to indicate that driving an XML (star mounted) much past 3A is not worth it.
Also, if you soldered directly to the flat copper surface on the CPU heatsink I have, it would short out the LED....
Lastly, if you have the ability to solder an XML to a copper heatsink and do some tests, please be my guest. I'd love to see more results. You may be correct that soldering to a copper heatsink directly will let you push this LED to 4-5A, however that's not very realistic from a general modder / manufacturing standpoint.
Written by saabluster on 01-29-2011 03:44 PM GMT
Secondly, I'd love to solder it. But that's not possible with any soldering iron I have. A heatsink designed to dissipate 130W of heat isn't going to let solder melt and stick with a 40W weller iron. Secondly, I'm not that interested in dealing with bare XML LED's (nor do I have any). 95% of modders only use XML stars, and so far my tests seem to indicate that driving an XML star mounted past 3A is not worth it.
Also, if you soldered directly to a single piece of copper wouldn't that short out the LED?
Soldering the whole thing down would certainly cause a short but that is not what I'm referring to. My preferred thickness of copper is 1/8th" thick. From there there are two basic ways to make it work. Use a piece that looks like an hourglass that pinches enough in the middle so as to only touch the electrically isolated center heat pad. The better way is to machine out the area where the elec. pads are and solder them from below. Soldering the whole thing down would certainly cause a short but that is not what I'm referring to. My preferred thickness of copper is 1/8th" thick. From there there are two basic ways to make it work. Use a piece that looks like an hourglass that pinches enough in the middle so as to only touch the electrically isolated center heat pad. The better way is to machine out the area where the elec. pads are and solder them from below.
You are right that that a soldering iron is not up to the task but I assure you you have what you need. Many folks use their stove top to give the required heat. I prefer either my lab oven(convection) or using a heatgun.
Written by jirik_cz on 01-29-2011 04:45 PM GMT
That is what SST50 datasheet says. But there is not a single flashlight that would achieve at least 800 measured lumens with SST-50. That is what SST50 datasheet says. But there is not a single flashlight that would achieve at least 800 measured lumens with SST-50.
Written by srfreddy on 01-29-2011 06:15 PM GMT
You've lost the game. You've lost the game. :D :sssh:
Seriously, the olight SR-50 puts out 800. Running the XM-L at 5 amps wouldn't get that much.
But who solders a led down IRF's? But who solders a led down IRF's?
Written by srfreddy on 01-29-2011 06:21 PM GMT
Thank you!
I highly doubt the difference in 4.2 and 5 amp drive was noticable. In between ti-forces 2.1 and 2.8 amp xm-l's, the difference in light output was 20%. The human eye is incapable of discerning lower amounts of light difference. I highly doubt the difference in 4.2 and 5 amp drive was noticable. In between ti-forces 2.1 and 2.8 amp xm-l's, the difference in light output was 20%. The human eye is incapable of discerning lower amounts of light difference.
You admitted that a De-dome reduces light output, yet you still compare a dedomed sst-50 to an x-ml. Yes, the XM-L is more efficient than the SST-50 at lower currents, but under a certain threshold, the XP-G becomes even more efficent.
Written by Techjunkie on 01-29-2011 06:27 PM GMT
Be sure to slide the star around a lot, working it back and forth until the compound is spread micro thin, before securing it in place with at least three screws. Pressure is very important. Be sure to slide the star around a lot, working it back and forth until the compound is spread micro thin, before securing it in place with at least three screws. Pressure is very important.
My lights never leave my posession, not unless they've been gifted or sold. It's not that I think people have bad intentions, it's just that I don't trust anyone to treat them with as much care as I do (especially in transit). Besides, you don't need numbers from an instrument if your eyes tell you that one is brighter than another with the same LED, reflector and focus. Light meters are far more delicate than the human eye. For example, your eye is not likely able to tell the difference between the same light putting out 638 Lumen on start up and 619 Lumen three minutes later, but an instrument can. If your eyes tell you that one drive current is visibly brighter than the other (and all other factors the same), then you can be sure that is certainly brighter (by many lux or lumen). My lights never leave my posession, not unless they've been gifted or sold. It's not that I think people have bad intentions, it's just that I don't trust anyone to treat them with as much care as I do (especially in transit). Besides, you don't need numbers from an instrument if your eyes tell you that one is brighter than another with the same LED, reflector and focus. Light meters are far more delicate than the human eye. For example, your eye is not likely able to tell the difference between the same light putting out 638 Lumen on start up and 619 Lumen three minutes later, but an instrument can. If your eyes tell you that one drive current is visibly brighter than the other (and all other factors the same), then you can be sure that is certainly brighter (by many lux or lumen).
I don't have the benefit of my wife's D-SLR to take a side-by-side photo (it is unfortunately away for built-in flash repair by Mack and may be for months), but I can offer the following two photos that were taken minutes apart at the same exact manual camera settings. Both lights use XM-L on star, mounted in same fashion. Both use Mag Rebel reflectors at the same focus. The camera settings were intended to compare these XM-L lights to lights with other emitters, not each other, and so are not stopped down enough to avoid the pattern of the bricks on the target wall being completely washed out. To compare, pay attention to the brightness of the spill on the wall oven on the left and of the ceiling bounce on the ceiling and floor. It is less obvious in these photos than when I view them side by side in person, but obvious nonetheless that the XM-L at 5A is brigher than at 4.2A. I assure you that the difference is all the more exaggerated when comparing to 3A. Unfortunately, i don't have a pic using the same reflector at 3A.
Target brick wall 30ft from camera and flashlights
Exposure 1/80th second, F3.5, ISO 800, WB 5200K
First up, 5A
Second up, 4.2A
Like this: Like this:
1 3/8" T6061 Aluminum bar tuned to press fit into Mag D neck
Ano. removed from D neck
neck and sink greased with silver thermal grease and sink pressed into neck
4 holes drilled and tapped, 4 brass screws secure silver greased star to sink
Written by srfreddy on 01-29-2011 06:41 PM GMT
The spill looks slightly bluer, and that's just about it.
Written by AnAppleSnail on 01-29-2011 06:46 PM GMT
No, it is slightly brighter in the spill, and the overexposed central part is a bit bigger. No way to tell how much brighter the hotspot is on a photo. No, it is slightly brighter in the spill, and the overexposed central part is a bit bigger. No way to tell how much brighter the hotspot is on a photo.
Written by Techjunkie on 01-29-2011 06:52 PM GMT
Actually, I compared all my SST-50 lights with domes in tact to the same lights with XM-L. My statement about the de-doming of an SST-50 was in response to the comment that Glenn7 made about the virtues of the SST-50 when de-domed. Actually, I compared all my SST-50 lights with domes in tact to the same lights with XM-L. My statement about the de-doming of an SST-50 was in response to the comment that Glenn7 made about the virtues of the SST-50 when de-domed.
When I view this page on my monitor, I can barely make out the floor or the stairs in the second photo, but I can see them clearly in the first. Maybe try turning the brightness down on your monitor to see what I'm seeing. When I view this page on my monitor, I can barely make out the floor or the stairs in the second photo, but I can see them clearly in the first. Maybe try turning the brightness down on your monitor to see what I'm seeing.
Written by srfreddy on 01-29-2011 06:57 PM GMT
I don't think so, and its also technically impossible. Me thinks its just your imagination.
Written by mvyrmnd on 01-29-2011 07:02 PM GMT
I can see the difference both on my iPhone and MacBook. The difference is subtle, but it's there. In the second photo you can't see the base of the rack holding the fireplace tools. In both shots the top of the hotspot is level with the speaker on the wall (The top of the hotspot lines up with the center of the large cone), so they're clearly aimed at the same height. I can see the difference both on my iPhone and MacBook. The difference is subtle, but it's there. In the second photo you can't see the base of the rack holding the fireplace tools. In both shots the top of the hotspot is level with the speaker on the wall (The top of the hotspot lines up with the center of the large cone), so they're clearly aimed at the same height.
We're still only talking the difference of a few hundred lumens, at most, but it shows you can still get more out of the XM-L above 3A.
My only XM-L light runs at either 2.8A or 4.2A. I promise you the difference is not only noticeable, but significant. I've only got a photo of it at 4.2A. I'll take a 2.8A shot tonight and post both. (I know we're discussing the 3A limit, but those are the modes it runs at.)
That 95W CPU heatsink you're using? When it's sucking the heat out of your Quad Core chip, it's bolted down with between 40-70lbs clamping force (I don't know the exact Intel specification, but advanced heatsinks that allow you to vary the clamping force all work within those limits). That 95W CPU heatsink you're using? When it's sucking the heat out of your Quad Core chip, it's bolted down with between 40-70lbs clamping force (I don't know the exact Intel specification, but advanced heatsinks that allow you to vary the clamping force all work within those limits).
I imagine that similar clamping force would be required to get the best heat transfer from your LED.
Written by srfreddy on 01-29-2011 07:08 PM GMT
Yeah, actually, the stairs are a bit more visible. But 2.8 vs. 4.2, thats adding 50% drive current. There's definitely gonna be a huge light increase, but its just less efficient (i.e. no benefits to me)
Written by AnAppleSnail on 01-29-2011 07:18 PM GMT
It's 4.2 vs 5, in the most recent post of comparative shots. That's about 20% more current; and to be a perceptible difference must be nearly 20% more light. It's 4.2 vs 5, in the most recent post of comparative shots. That's about 20% more current; and to be a perceptible difference must be nearly 20% more light.
Written by srfreddy on 01-29-2011 07:23 PM GMT
I was talking about mvyrmnd's XM-L.
Written by srfreddy on 01-29-2011 07:24 PM GMT
Few hundred? Or a few tens of lumens? Few hundred? Or a few tens of lumens?
I would imagine that 3 screws could probably put a good 30 pounds of clamping force down.
Written by mvyrmnd on 01-29-2011 07:29 PM GMT
They would, if the OP was using them. They would, if the OP was using them.
At 4.2A the XM-L is clear over 1000 Lumens. 20% of 1000 lumens is? At 4.2A the XM-L is clear over 1000 Lumens. 20% of 1000 lumens is?
Written by jasonck08 on 01-30-2011 12:54 AM GMT
Test # 3. Same setup only difference is Artic Silver was used and heatsink was tapped and screws were screwed down very tight onto the MPCB.
Numbers:
3.0A 92.8 - 5M 91.6
3.5A - 97.4 - 5M - 94.3
4.0A 92.3 - 5M - 90.1
The heatsinking seemed to allow for currents up to 3.5A without the output decreasing. Efficiency obviously isn't so great at this drive current.
Regardless, I don't know how in heck someone could have a better heatsink setup in a flashlight compared to what I've got posted up there. Core i7 930 stock heatsink designed for up to a 130W load. Artic Silver and pressure mounted with 3 brass screws. Sure, direct soldering it to copper might yield a tiny bit better performance, but again thats not practical for most modders and manufacturers.
Written by mvyrmnd on 01-30-2011 01:02 AM GMT
:popcorn:
Written by jasonck08 on 01-30-2011 01:31 AM GMT
In this morphed gif, changing from the 4A to 5A picture, you can see the beam lowers several inches, thus providing more light to the fireplace and stairs. The 5A picture the light is positioned a little closer to the wall also. It does appear maybe slightly brighter, but also maybe has more of a blue tint to the side spill. In this morphed gif, changing from the 4A to 5A picture, you can see the beam lowers several inches, thus providing more light to the fireplace and stairs. The 5A picture the light is positioned a little closer to the wall also. It does appear maybe slightly brighter, but also maybe has more of a blue tint to the side spill.
Also you guys are claiming that your lights are brighter at higher currents and that may be true. However are you considering losses in current reaching the LED due to power consumed by the driver? The LED could be only getting 80-90% of the current.
Secondly, its also possible that your LED's are better performers at higher currents than my LED.
@TechJunkie
What driver are you using? What bin are you using? Color and Flux.
Where were your LED's purchased? I may try to get some from the same source as you, to see if my results are any different.
Just to clarify to everyone, I'm not at all against pushing LED's past their rated current. In fact I was hoping to build a few more XML lights with higher drive currents in the 4-5A range. But so far my personal tests, using the LED's that I have available and heatsinking that far surpasses the performance of anything I could build into a flashlight, its not looking like I'd consider feeding the LED more than 3.5A.
Written by mvyrmnd on 01-30-2011 01:40 AM GMT
Mine is driven by a D2flex. At it's highest setting it's Direct Drive, the tailcap current is 4.2A. Being direct drive, I don't think there'd be much loss. The 2nd highest mode is set for 2.8A.
In this morphed gif, changing from the 4A to 5A picture, you can see the beam lower several inches, thus providing more light to the fireplace and stairs.
Well, there you go. I've got to say, as two separate images, on my small screen, they looked the same. That said, after watching your GIF a few times I'm convinced that the spill, at least, is brighter at 5A. Well, there you go. I've got to say, as two separate images, on my small screen, they looked the same. That said, after watching your GIF a few times I'm convinced that the spill, at least, is brighter at 5A.
Written by Goldigger on 01-30-2011 02:00 AM GMT
Numbers:
3.0A 92.8 - 5M 91.6
Could you possibly re-run this test, but with a desk fan blowing at the heatsink and led setup please?
This would be interesting as my lights are all bike lights, so they get wind cooling when im riding.. :)
Written by fyrstormer on 01-30-2011 02:35 AM GMT
There is something I don't see anyone taking into account here. You know the little gold wires that connect the die to the solder terminals? They're about as thick as a hair, if even that much, and you're dumping multiple amps through them. The SST-50 has a lot more little wires than the XM-L has, which means each wire carries less current. That, in turn, means each wire will heat up less and provide less electrical resistance to the current flowing through it. It's entirely possible the XM-L is limited not by the die or its heatsinking capabilities but by the wires that carry the power to the die.
Written by MikeAusC on 01-30-2011 02:39 AM GMT
In a constant-current drive situation, a bit of extra voltage drop in the wires will not affect LED output, except for increasing dissipation in the package.
Written by boboweb on 01-30-2011 02:41 AM GMT
I advise you not to over-reliance on the specifications of paper !The "paper" is one thing - real life is another I advise you not to over-reliance on the specifications of paper !The "paper" is one thing - real life is another ;)
PAGE 3:
Written by jasonck08 on 01-30-2011 03:50 AM GMT
Exactly my thoughts. As the improved heatsinking had very little impact on the results. Also the heatsink is massive and just laughs at a 10W load. The heatsink is just a couple degrees above room temperature after running it for several minutes. The LED bond wires do have limits. It's also possible that some LED's have bondwires that are just a tiny bit larger allowing higher currents. I really think that heat or junction temp is not whats limiting me, its the size of the bond wires and what happens to them as resistance changes when they get more current and heat up. Exactly my thoughts. As the improved heatsinking had very little impact on the results. Also the heatsink is massive and just laughs at a 10W load. The heatsink is just a couple degrees above room temperature after running it for several minutes. The LED bond wires do have limits. It's also possible that some LED's have bondwires that are just a tiny bit larger allowing higher currents. I really think that heat or junction temp is not whats limiting me, its the size of the bond wires and what happens to them as resistance changes when they get more current and heat up.
Overdriving LED's is similar to overclocking CPU's, you'll find chips in a batch that Intel and AMD sell that can be overclocked 30-40% from their stock clock, while another CPU may struggle to get a 20% increase. With awesome heatsinking my XML's limit is about 3.5A before brightness decreases. Others may have LED's capable of slightly higher.
Written by jirik_cz on 01-30-2011 04:09 AM GMT
I'm talking about I'm talking about real measured lumens. Not manufacturer claims which are often highly inaccurate with SST-50 flashlights.
Written by Walterk on 01-30-2011 06:05 AM GMT
I've had M3 screws in 4-5mm copper and aluminium that didn't hold. I've had M3 screws in 4-5mm copper and aluminium that didn't hold.
Bolt and nuts throughhout the sink would be best but ackward building.
The Cree ring would have helped clamping them down for gleuing.
Has anyone a picture of the underside of a bare XM-L?
Written by Techjunkie on 01-30-2011 10:46 AM GMT
As I said before, these pictures were not meant to show the difference between the two XM-L lights at 4.2 and 5 Amps, but were meant to show a far more obvious difference between XM-L in other reflectors and XM-L vs. other emitters entirely. Bearing that in mind, I think the fact that there is a detectable difference of the additional drive current over 4.2A which is already at the extremely high end demonstrates that the XM-L doesn't top out at 3A. With regard to the tint of the spill, not all emitters have the same tint, even if they are binned the same. My eyes tell me at the extreme edge of the spill which should be the dimmest, the 5A picture is not just "bluer" but is illuminating the handle of that wall oven brigther. As I said before, these pictures were not meant to show the difference between the two XM-L lights at 4.2 and 5 Amps, but were meant to show a far more obvious difference between XM-L in other reflectors and XM-L vs. other emitters entirely. Bearing that in mind, I think the fact that there is a detectable difference of the additional drive current over 4.2A which is already at the extremely high end demonstrates that the XM-L doesn't top out at 3A. With regard to the tint of the spill, not all emitters have the same tint, even if they are binned the same. My eyes tell me at the extreme edge of the spill which should be the dimmest, the 5A picture is not just "bluer" but is illuminating the handle of that wall oven brigther.
I wasn't relying on tailcap measurements for the 5A light. For that, a clamp meter was used clamped around the wire from the driver stack to the LED, ensuring the LED is seeing all 5A. For the 4.2A light, AMC7135 regulators maintain the same amperage across the whole circuit and the low Vf of the emitter and the ample headroom of the battery guarantee regulation across most of the discharge. In this case, the battery had been freshly charged. I wasn't relying on tailcap measurements for the 5A light. For that, a clamp meter was used clamped around the wire from the driver stack to the LED, ensuring the LED is seeing all 5A. For the 4.2A light, AMC7135 regulators maintain the same amperage across the whole circuit and the low Vf of the emitter and the ample headroom of the battery guarantee regulation across most of the discharge. In this case, the battery had been freshly charged.
jasonck08 said:
@TechJunkie
In the 5A light, I'm using two DX 20330 drivers in parallel, output confirmed with a clamp meter around the LED wires. I've described the 4.2A setup above. In these lights, the emitters were T6 bin purchased in the same batch from KD. Tint bin unknown. In the 5A light, I'm using two DX 20330 drivers in parallel, output confirmed with a clamp meter around the LED wires. I've described the 4.2A setup above. In these lights, the emitters were T6 bin purchased in the same batch from KD. Tint bin unknown.
That statement makes perfect sense and is far less provocative than saying that there's That statement makes perfect sense and is far less provocative than saying that there's no benefit to driving an XM-L at over 3 Amps. Weighing the benefit of overdriving an emitter is a matter of personal opinion. Clearly, not everyone would use the same weighting system when designing their own lights. Consider all the effort put forth by members of this forum to design hotdrivers - devices intended to run a bulb within milliwatts of its breaking point. Practical? Surely not. Fun? Hell yeah.
We could debate until the cows come home about "benefits" of overdriving and never reach a conclusion because in the end, the benefit is in the eye of the beholder. But... there is one undeniable statement of truth here, which is that the XM-L can certainly handle much more power than the recommended max spec. By my experience, it takes more abuse than any other high power emitter that's come before it. For me, that makes it the most appealing candidate for driving an LED to the edge - hotwire style - than any other.
Written by fyrstormer on 01-30-2011 01:55 PM GMT
Of course it will affect LED output. The current regulator only "cares" about whether the load at the other end is eating the specified number of amps, not whether those amps are being used to produce light or heat. Those little wires could be glowing hot and the current regulator would be just fine with it -- and with all the light coming off the die, you'd never see the wires even if they did get hot enough to glow. Most likely they aren't, I admit that's an extreme scenario, but if the wires are wasting power producing heat, then that power Of course it will affect LED output. The current regulator only "cares" about whether the load at the other end is eating the specified number of amps, not whether those amps are being used to produce light or heat. Those little wires could be glowing hot and the current regulator would be just fine with it -- and with all the light coming off the die, you'd never see the wires even if they did get hot enough to glow. Most likely they aren't, I admit that's an extreme scenario, but if the wires are wasting power producing heat, then that power isn't going into the die to produce light. And yet, the current readout will still look correct.
Written by MikeAusC on 01-30-2011 03:17 PM GMT
fyrstormer said:
Of course it will affect LED output. .
You're contradicting yourself here. You're contradicting yourself here.
Yes, more power is going into the whole LED, but the die is still drawing the same power, so producing the same output.
We're talking about a constant-CURRENT supply, not a constant-POWER supply scenario.
Written by IMSabbel on 01-30-2011 06:03 PM GMT
fyrstormer said:
Of course it will affect LED output. The current regulator only "cares" about whether the load at the other end is eating the specified number of amps, not whether those amps are being used to produce light or heat. .
Urg. There is a current through the led. Just because the wires have resistance does not mean the electrons just disappear. Every single electron that heats the bonding wires also goes through the LED. Urg. There is a current through the led. Just because the wires have resistance does not mean the electrons just disappear. Every single electron that heats the bonding wires also goes through the LED.
You will get an increase in Vf, but notice that nobody here is talking about how bright the LED is at 5W, its at 5A.
Written by csshih on 01-30-2011 06:23 PM GMT
on a side note, hah. I broke my XM-L while pushing it. (my psu does ~5A max)
odd. I could not visually see any failures. perhaps the bond wires.. oops!
Written by jasonck08 on 01-30-2011 07:23 PM GMT
While on a heatsink? How long did you run it at 5A? While on a heatsink? How long did you run it at 5A?
I'd still like to see some other people with Lux meters chime in about driving an I'd still like to see some other people with Lux meters chime in about driving an XML @ 5A. As my XML LED CLEARLY can not take that kind of abuse even with the awesome heatsinking which is better than the heatsink in your XML Light @ 5A. To think that any XML (star mounted) can be driven at 5A I think is absurd. Mine tops out at 3.5A, Craigs seems to top out at 3.5A also and seems to have fried at 5A. Another thing I would like to see is your light (or a similar one) run for 5-10 minutes. We'll see how much the output drops and if the LED begins to blue or if it outright fails.
Written by Techjunkie on 01-30-2011 08:00 PM GMT
I ran one for 40-45 minutes straight with a quick 10 second stop about 20 minutes in to change the batteries. I ran one for 40-45 minutes straight with a quick 10 second stop about 20 minutes in to change the batteries. No fail. Still visually brighter than the 4.2A one.
Written by mfj197 on 01-31-2011 09:55 AM GMT
As would I. Your As would I. Your real-world testing makes good reading, jasonck08, and would seem to imply an XM-L driven at 4A is less bright than one driven at 3A - at least in terms of lux (measured straight in front of the LED I assume?). Does anyone have an integrating sphere to measure lumens?
Is it possible that at these very high overdriven currents the spatial distribution changes and more light is emitted to the sides, but less straight ahead?
Written by HarryN on 01-31-2011 04:01 PM GMT
Hi, thanks for all of the interesting posts and info in this thread. Thermal droop is alive and well in the LED world, and this info continues to prove it.
It isn't that surprising that the droop effect exists, as it has in every power led I have measured over the past 7 - 8 years. What is surprising, is how few people seem to accept its presence. It is difficult to optimize an LED for every situation, so you see firms like Cree optimizing raw output, while firms like Lumileds tend to optimze output under droop conditions. It is not quite the same thing, but it makes them both competitive in the marketplace, even with interestingly different paper specs.
I think it is entirely reasonable to assume that most people do in fact use stars for their applications, as bare SMT LEDs are certainly more challenging to work with for many (not all) people.
The data partly shows why Lumileds engineers make the comment that their LEDs are very competitive (ok, they say better, as you would expect) under real world conditions.
There is nothing like competition to drive improvement. :)
Written by vestureofblood on 01-31-2011 06:08 PM GMT
Jackson08
Thank you so much for doing these tests and sharing your results with us. I love that you also included a picture of your heat sinking setup. I also like the use of a bar graph to show the results.
I think your tests do give a realistic idea of how these LEDs will perform in MOST flashlight.
I will say that for me soldering to a copper slug has proven to be a worth while venture. So far I have only done one XML that way. I still dont think the increase in LUX at 5 min would be huge in a small light, but with a significantly lower junction temp having the led soldered to a maglite size slug may still have a shot at achieving a beneficial increase.
Thanks again for sharing.
Written by ti-force on 01-31-2011 06:17 PM GMT
I have a homemade integrating sphere that has been calibrated using multiple lights that were measured in a I have a homemade integrating sphere that has been calibrated using multiple lights that were measured in a real ($10,000) lab integrating sphere, and I'd be very interested in doing this test, but at the moment I don't have time to build these lights myself for testing because I'm too busy with other priorities at the moment, and will be for at least the next month. The best way to compare the difference in output between 3A drive current and 4A drive current would be to use one light, and power it with a bench power supply to deliver exact known voltage and current, but unfortunately I don't have a $700 power supply.
I would still be very interested in testing an XM-L light that has been properly built to deliver 3+ amps of current and to dissipate heat well. I'm very interested to know how well it would actually hold its lumen output over a 3 minute span. If anyone is interested in sending me such a light, send me a pm.
Written by srfreddy on 01-31-2011 08:35 PM GMT
The spill looks bluer, and thats all. The XM-L apparently can be driven to all of 3.5 amps with gain. Which is half an amp above spec... whereas an SST-90 can be driven to like 13 amps.... The spill looks bluer, and thats all. The XM-L apparently can be driven to all of 3.5 amps with gain. Which is half an amp above spec... whereas an SST-90 can be driven to like 13 amps....
Written by Techjunkie on 01-31-2011 09:15 PM GMT
I've driven my SST-90 from 9A on up through 13A and while it could handle that current without failing, there was I've driven my SST-90 from 9A on up through 13A and while it could handle that current without failing, there was no appreciable gain in light output, just in heat output. Check my threads on SST-90 burn-in and my videos on YouTube for the history.
On the XM-L photos you insist the spill is bluer and I insist it's brighter. Until I have access to a D-SLR again to prove my case with photos at settings that demonstrate the difference better, we'll just have to agree to disagree.
Written by boboweb on 02-01-2011 01:46 AM GMT
srfreddy please go buy better monitor and stop talking nonsense ! From Techjunkie beamshots is clearly visible that XM-L at 5A is significantly brighter than XM-L at 4A ! Who can`t see it - then he has a problem with vision ...
Written by Led_Blind on 02-01-2011 02:00 AM GMT
My e-peni is the largest..... oh wait.
Its entirely possible the variation in early samples could account for this discrepancy. Personally the drop in efficiency is enough to limit the drive current to 2-3A, i like my lights to run long and cool.
Written by Nos on 02-01-2011 03:26 AM GMT
You simply cant compare those because its not the same LED. And Techjunkie wrote more than once not to compare the beamshots in that way. (post 64) You simply cant compare those because its not the same LED. And Techjunkie wrote more than once not to compare the beamshots in that way. (post 64)
The XM-Ls in this light can be upper or lower T6 selection, or the termal path can be better and on and on and on and on .........remember that.
Its true that the 5A light is brighter than the 4,2A light, but we have no proof that current is related to that.
So far we only have measuremeants from OP. Some other testing is done in the "Taschenlampen-forum", but so far we have to admid that the XM-L is close to the limit at 3,5A.
Here is another XM-L mod. Mode one is 5A mode two is 4A. He said that there is no "visible difference" between those two.
Written by jasonck08 on 02-01-2011 03:32 AM GMT
vestureofblood said:
Jackson08
If you or anyone else has bare XML's and can solder them directly to a copper slug I would love to test it in my lab with my setup. I would be willing to cover return shipping if you or someone else wanted to send me an If you or anyone else has bare XML's and can solder them directly to a copper slug I would love to test it in my lab with my setup. I would be willing to cover return shipping if you or someone else wanted to send me an XML copper mounted to test. I would promise to take good care of it, and not to drive it too hard if I see output dropping.
EagleTac has an XML light that is being released that apparently draws 3.8A (not sure if thats tail cap measured or 3.8A to the LED). If its 3.8A at the tail, then we can assume the LED is getting 3.5A, which falls in line with Craig and my testing that 3.5A is about the max for most XML's.
@ Techjunkie Also, I'm wondering if some of the LED's that DX/KD are selling could be engineering sample LED's with different performance than the mass released LED's. Because you are claiming that your driving it at 5A with decent heatsinking (but nothing amazing). With my 130W Core i7 heatsink, the led firmly screwed down to the copper and a small amount of AS5 between the heatsink, I can't manage more than 3.5A with my XML, without output dropping. Also if you have a spare XML from the same purchase as the other ones you used for mods, I would love to test it. I could buy it from you or borrow it and return it after testing.
Written by palimpsest on 02-01-2011 12:34 PM GMT
The difference could come from the LED batch but it could also depend on how they are mounted and depend on the diameter and thickness of the aluminum star. (?) The difference could come from the LED batch but it could also depend on how they are mounted and depend on the diameter and thickness of the aluminum star. (?)
Written by qwertyydude on 02-01-2011 11:56 PM GMT
My XM-L lights, and I have two that I've custom built identical to each other, are converted Uniquefire X8's, the led's were from the same supposed batch from DX, bought at the same time, they appear to be the same brightness and tint from a ceiling bounce using my DSLR's exposure settings as a brightness gauge. These are direct drive sono driver losses getting in the way, identically setup electrical wise. Now I know I can make a direct comparison between these on a ceiling bounce.
Between 3 and 4 and 5 and 6 amps there is always a difference. The way I controlled the current is letting the battery run down a to certain amount. When I knew it would run on it's own at the current measured I'd then knew it ran direct drive at that current. I could then alternate a ceiling bounce between them and each step I could discern a brightness increase. Now I didn't let these lights heat up but they were running for about 1 minute total for the duration of my informal tests. It's true that between 5 and 6 amps it's barely noticeable but for me up to 6 amps there was increases. I'm sure running these direct drive on my IMR cells probably quickly resulted in a drop in output below the 6 amp level, but my point is that the 3 amp ceiling apparently doesn't involve my led's or maybe I got some special ones. But I did run 8+ amps through one of my led's for 1 minute with no damage to the led so I know it's darn tough and not the delicate led pushed to its bleeding edge just running at its rated capacity, which totally goes against how Cree seems to rate their led's. Maybe you did get a bad one.
Written by ti-force on 02-02-2011 04:39 AM GMT
Well it looks like I'll have to do as I always do...... Do it myself.
After I get moved into my new home I'll build my own XM-L Maglite and test for OTF lumen losses over a predetermined amount of time at different drive levels. I'll start a separate thread for my OTF lumen results :thumbsup:.
Written by jasonck08 on 02-02-2011 09:19 PM GMT
Your extreme current levels of 6-8+A are a little hard to believe considering I instantly fried my first Your extreme current levels of 6-8+A are a little hard to believe considering I instantly fried my first XML a couple weeks ago @ 7-8A. Do you have any DX XML's left? If so I would like to buy or borrow one from you for testing with my lab setup.
Written by qwertyydude on 02-02-2011 10:14 PM GMT
I do have one on a star. I decided to see how long I could run it with an IMR 18650 before it failed. It didn't fail right away but it did start at about 8 amps and leveled off to 6 amps after2 minutes. After 5 the whole flashlight was hot to the touch and the phosphor just started to brown. PM me I'll send you it. But I do believe that you did instaflash yours. There must be some variances in construction I just instaflashed one of my XM-L's at about 7 amps. My other one runs fine at short bursts of 8 amps. It's my last working one and so I don't want it to brown until I get another couple of XM-L's in.
Written by gohhib on 02-03-2011 11:01 AM GMT
I guess it should hold the lumens pretty well if well heat sinked. I swapped a XM-L T6 for my MTE lamp (DX sku 50320). I consider that a pretty good I guess it should hold the lumens pretty well if well heat sinked. I swapped a XM-L T6 for my MTE lamp (DX sku 50320). I consider that a pretty good real life example that has no perfect heat sinking but rather ok heat transfer.
Lamp was driven with an amc7135 board giving about 2.6A at room temperature. The flux dropped in a few minutes and stayed there for the 10min test. I measured a drop of about 0.3EV ie. about 20% drop in lumens. (0.1EV resolution).
I measured it with a photographic ambient light meter that just happened to match the front of the lamp perfectly. That should integrate all the light pretty well.
In a real life situation that is more than ok for me. My main use is for a bicycle light. While moving it'll stay much cooler and the drop stays lower.
Re:Norealbenefits tooverdrivingXML
Written by ti-force on 02-03-2011 11:55 AM GMT
I've already measured OTF lumens of an XM-L T6 flux, 2T tint up to 2.8A in my calibrated integrating sphere. I'm interested in measuring the drop in lumens during a 3-4 minute test with some of these lights that are being driven out of spec (3+A drive current). My guess is that some people would be surprised. I've already measured OTF lumens of an XM-L T6 flux, 2T tint up to 2.8A in my calibrated integrating sphere. I'm interested in measuring the drop in lumens during a 3-4 minute test with some of these lights that are being driven out of spec (3+A drive current). My guess is that some people would be surprised.
Written by jasonck08 on 02-03-2011 02:51 PM GMT
And what were the OTF readings at 1s and @ 3M? And what were the OTF readings at 1s and @ 3M?
Written by ti-force on 02-03-2011 02:57 PM GMT
http://www.candlepowerforums.com/vb/...27#post3668027
Written by Techjunkie on 02-03-2011 08:55 PM GMT
Here are some white wall (egg shell, really) beam shots directly comparingXML at 3.4A, 4.2A, 5.0A from left to right in every photo. I had Mrs. Techjunkie help out with this one by holding two lights while I held the third and my daughter's Fuji FinePix V10 camera. The camera's manual setting doesn't allow a fixed shutter speed, but ISO was forced to 64 and the flash was forced to off. The lights were on while I explained to her what she had to do and why we were doing this as she tried to humor me - you know, by not rolling her eyes at me while enduring this stupid interruption to whatever she does at night while I'm tinkering with flashlights. They remained on during the "shoot" which probably began around T + 3 minutes and ended around T + 5 minutes.
(pardon the water stain in the ceiling over the TV - the leak has been stopped but the sheet rock still needs repair)
I think these quick and dirty shots show an undeniable increase of the 5.0A over the other two, especially the 3.4A.
PAGE 4:
Written by mvyrmnd on 02-03-2011 10:24 PM GMT
Nice photos Teckjunkie :)
If all the lights are in the photo together, the exposure settings are irrelevant.
You can clearly see the difference, although the 3.4A has a much tighter hotspot than the other two. Are the others larger simply because of more light, or different reflectors?
The 3.4 can't keep up with the 4.2, so if it has a tighter beam it shows a great improvement in output.
Written by qwertyydude on 02-03-2011 11:45 PM GMT
Considering one of my led's instaflashed on an IMR and the obvious results I've personally witnessed overdriving the led and getting more light and confirmed by tech junkie I think it may very well be a high power lottery. Either you get an XM-L that is not as efficient at high currents and may even instaflash or you get led's that can run at 5 amps or more, I've witnessed 8+ on mine. I'll be sending jasonck08 my 8 amp superbrute, it has a little brown phosphor but physically still works just fine. I've asked him to test it to it's ultimate destruction so we'll see if my high power lottery theory holds any water.
Written by jasonck08 on 02-04-2011 12:48 AM GMT
If what your posting is real and true (which I'm sure it is) then there is obviously a HUGE difference in XML's performance at over driven currents. Out of the 3 I've tested, they all perform pretty much the same, and provide no increased performance past 3.5A. Secondly, can you measure the vF of the LED at different current levels? The vF on my LED's was VERY low. Measured @ the LED with a fluke DMM. If what your posting is real and true (which I'm sure it is) then there is obviously a HUGE difference in XML's performance at over driven currents. Out of the 3 I've tested, they all perform pretty much the same, and provide no increased performance past 3.5A. Secondly, can you measure the vF of the LED at different current levels? The vF on my LED's was VERY low. Measured @ the LED with a fluke DMM.
1A - 3.000v
2A - 3.103v
3A - 3.147v
4A - 3.177v
5A - 3.218v
The vF will be lower as the LED heats up. These measurements were taken after about 1-2 minutes of running the LED.
Thanks, look forward to testing this LED. Thanks, look forward to testing this LED.
Unknown
Written by mvyrmnd on 02-04-2011 12:51 AM GMT
I think qwertydude might be right on the money. The tint lottery is dead. Long live the power lottery.
Written by MatajumotorS on 02-04-2011 01:27 AM GMT
Its because digital camera has not so wide dynamic range as the human eye has - and the hotspot just makes some kind of "clipping" =] Its because digital camera has not so wide dynamic range as the human eye has - and the hotspot just makes some kind of "clipping" =]
Written by HarryN on 02-04-2011 03:34 AM GMT
Thanks for those nice pictures, and especially thanks to the Mrs. for her help. I can just imagine trying to get my wife to hold some lights for a shot.
There is an interesting visual effect on the middle beam, probably just an illusion, but on my laptop, it looks like the middle current beam has a slight donut forming, that isn't present on the lower or higher current.
Either way, all very usable beams.
Written by fyrstormer on 02-04-2011 09:31 PM GMT
If you "believe" in conservation of energy (and if you don't this conversation is pointless), then energy that gets wasted heating the bond wires must not be emitted as light. That is the basic concept of thermal droop, and it's well-understood. All I'm saying is that the tiny bond wires are likely contributing more to the thermal droop at such high power levels than most people are giving them blame for. As the bond wires heat up, their resistance increases, which not only causes the power supply to ramp-up the voltage to keep the current flow the same, but it also will cause the bond wires to convert even more electrical energy into heat energy than they did before they heated up. If you "believe" in conservation of energy (and if you don't this conversation is pointless), then energy that gets wasted heating the bond wires must not be emitted as light. That is the basic concept of thermal droop, and it's well-understood. All I'm saying is that the tiny bond wires are likely contributing more to the thermal droop at such high power levels than most people are giving them blame for. As the bond wires heat up, their resistance increases, which not only causes the power supply to ramp-up the voltage to keep the current flow the same, but it also will cause the bond wires to convert even more electrical energy into heat energy than they did before they heated up.
Written by hellokitty[hk] on 02-04-2011 10:19 PM GMT
@jasonck08,
How exactly did you mount your LED onto a heatsink using screws?
If that ends up sounding too difficult for me, I'll just epoxy it on.
I'm assuming you wiped with alcohol, then used arctic silver thermal epoxy and that's about it, but I'm interested in making a similar rig with spare stock coolers, so I'd like to confirm.
What thickness is ideal for thermal epoxy?
Thanks for all your efforts in looking into the cree XM-L, this is really good stuff keep it up.
Written by led-it-be on 02-05-2011 08:58 AM GMT
@hellokitty,
Although I'm no expert in the field, I think you might want to use as little epoxy as possible. The purpose of thermal epoxy is to fill tiny surface irregularities between the led (maybe on a pcb) and the heatsink. If there's too much epoxy, heat transferring properties will suffer greatly, so the trick is to use the least possible amount of epoxy necessery to fill the gaps.
I always apply AS on both the star and the heatsink and then pull off the excessive paste using a spare blade of a cutter, until I can almost see the aluminium shining through the thin layer of epoxy. Then I press the star against the heatsink and rotate it a little to get all the air bubbles out that might form between the layers. If possible I use clamps to press the star to the heatsink when letting the epoxy dry.
But I think mounting the mpcb permanently tight with screws is better. For that, you probably would have to drill some holes through your heatsink... you would mount the screws where the holes or the cut out half circles are in your round/star mpcb. And the best would be to have the led on a copper-pcb and then directly soldering it to a copper heatsink. If only there were copper-pcbs available with an xm-l pre mounted!
Other suggestions?
Written by hellokitty[hk] on 02-05-2011 11:40 AM GMT
Least amount of thermal compound sounds good.
Sadly, I don't think I have the means to drill screw holes...I was thinking of a sort of mounting bracket to pinch it in, similar to how you'd actually mount a CPU cooler. I guess epoxy is ok though.
Written by jasonck08 on 02-05-2011 03:11 PM GMT
hellokitty[hk said:
@jasonck08,
I drilled 3 holes, then I used a tap and die set to thread the holes. I wiped the star and copper with isopropyl, then applied a small amount of arctic silver. Then I screwed down the brass screws with some needle nose pliers until everything was nice and tight.
The argument in earlier threads was that thermal epoxy is not good for high heat transfers. My results didn't seem to change too much. I was able to get about 300mA more out of my LED.
If you do end up using epoxy, arctic silver epoxy I think is the best stuff out there. It's about twice as efficient as the alumina epoxy.
One mounting idea I had was to use the same mounting method as that is used to mount a CPU to a motherboard. Just drill 4 holes in a piece of 1/8" plastic or metal or something. Then drill a hole for the LED dome to stick out of. Then pressure mount it it just like you do on a motherboard.
Written by Techjunkie on 02-05-2011 05:07 PM GMT
@jasonck08 It's hard to tell, but from the pic it looks like that's a pretty thick layer of AS5. It should be microscopically thin, or it will work against you. Afterall, it's meant to fill in microscopic air gaps between two flat surfaces, not to separate those surfaces. If you remove the screws and slide the star around on the copper until you feel metal on metal and then reinstall the screws, you might get better results.
Written by hellokitty[hk] on 02-05-2011 05:14 PM GMT
You meanArctic Silver ASTA-7G (2-PC-SET) Premium Silver Thermal Adhesive - OEM right?
Thanks.
Written by jasonck08 on 02-06-2011 05:47 PM GMT
It's actually quite a thin layer of AS5. I've been an avid overclocker, a couple machines ago I took an e4300 1.8Ghz stock to 3.2Ghz stable on Air cooling 24/7 with no issues. The general rule is to use about the amount of AS5 as an uncooked grain of rice. Thats about how much I used for this XML. Most of it squished out towards the front as you can see on the picture. AS5 does have a break in period of about 200hrs before it reaches optimal efficiency. With a CPU that would usually mean temps would drop by maybe 2-3C after that many hours. It's actually quite a thin layer of AS5. I've been an avid overclocker, a couple machines ago I took an e4300 1.8Ghz stock to 3.2Ghz stable on Air cooling 24/7 with no issues. The general rule is to use about the amount of AS5 as an uncooked grain of rice. Thats about how much I used for this XML. Most of it squished out towards the front as you can see on the picture. AS5 does have a break in period of about 200hrs before it reaches optimal efficiency. With a CPU that would usually mean temps would drop by maybe 2-3C after that many hours.
hellokitty[hk said:
Yes, I believe that is the best thermal adhesive / epoxy on the market. Yes, I believe that is the best thermal adhesive / epoxy on the market.
Written by qwertyydude on 02-06-2011 06:07 PM GMT
Since you're an overclocker, here's a little trick I use with arctic silver. It's a very thick paste and getting it in a super thin layer can be difficult. So I put a tiny dot, probably half that grain of rice on my lapped processor, yes I even lapped my cpu processor. And to spread it evenly thin I put a few drops of lighter fluid on the processor and spread the arctic silver with the lighter fluid. Then let the lighter fluid evaporate completely and mount the cooler. This pretty much got rid of that pesky "break in" period. I've noticed cooler running too, I think that "break in" period described by people is people still using too much and the layer thinning due to reduced viscosity during heat cycles and the Arctic Silver creeps into it's final position. The near transparent layer you can achieve with lighter fluid makes for a perfect thermal contact area.
Written by jasonck08 on 02-06-2011 07:42 PM GMT
When you have upwards of 20-30lbs of pressure on a CPU or LED star, its pretty hard NOT to have a thin layer of AS5. The excess thermal compound makes its way out to the edge of the CPU or star.
I've lapped heatsinks many times before, but never a CPU, as that instantly voids the warranty and is not worth the 2-3C for me.
Written by qwertyydude on 02-07-2011 08:15 AM GMT
I've never had to use the warranty on a processor before so I figure I install the processor, set everything up, overclock it to make sure it works, then I remove everything and lap the processor. I figure if you can get everything working right the processor is good and can be lapped. If it fails first you can use the warranty.
Re: No real benefits to overdriving XML
Written by jasonck08 on 02-07-2011 03:10 PM GMT
I've also seen some people remove the heat spreader and directly mount a heatsink, waterblock etc directly to the CPU die. Some older CPU's use to ship that way. You just have to be careful and not apply too much pressure. I've also seen some people remove the heat spreader and directly mount a heatsink, waterblock etc directly to the CPU die. Some older CPU's use to ship that way. You just have to be careful and not apply too much pressure.
Written by IMSabbel on 02-07-2011 05:19 PM GMT
Actually, you can use pressure as much as you want.
(There has never been a socket with higher pressure than the orignal socket A, which used naked dies).
But you have to be REALLY careful about putting the heatsink on. If you roll it over the edge, say goodbye to your die...
Written by Kestrel on 02-07-2011 05:33 PM GMT
This is about the XM-L LED, right? This is about the XM-L LED, right? :rolleyes:
Written by jasonck08 on 02-08-2011 03:16 AM GMT
Yes... Kind of... it's in regards to proper heatsinking. Yes... Kind of... it's in regards to proper heatsinking. ;)
Written by saabluster on 02-21-2011 01:27 AM GMT
Just thought I'd leave a shot of a quick test I did of an XM-L T6. It was soldered directly to copper which was then clamped to a computer heatsink with a little bit of ambient air blowing over the fins. For each data point I waited for it to stabilize before recording.
Of course this is a best case scenario and real world use will not match this when heat-soak sets in. Still for those who really want to push the boundaries and do it right(no mcpcb) there are plenty more lumens to be found past the 3A mark.
Written by jasonck08 on 02-21-2011 02:12 AM GMT
Any pictures of your setup? Where did you get your XM-L's? I still think there may be quite a big difference from one XML to another, considering some people are reporting success driving star mounted XM-L's at 5A, and with my CPU heatsink and star mount setup, I cant get much past 3.5A.
Also, can you report your vF at various currents after 2-3 minutes of running it. This may give us an idea of the Tj.
Written by saabluster on 02-21-2011 02:21 AM GMT
No pictures of the setup. I'd have to do some cleaning before I took pics of that area. :eek: The heatsink isn't even as good as the one you used but air blowing over it makes a big difference. The XM-Ls were from Cutter. I bought one mcpcb to use just to test and see how big a difference it makes. I'll report back with my findings when I can find the time to get it done.
edit: I just noticed you asked about the Vf. I did not track it. It was a quick test just to see the limits of the XM-L.
Written by MikeAusC on 02-21-2011 05:12 AM GMT
Thankyou for publishing some real data on Light vs Current. Thankyou for publishing some real data on Light vs Current.
I was pretty sure Cree wouldn't be making LEDs that became useless beyond their long-life rated current.
Written by HugeOne on 02-21-2011 10:50 AM GMT
Thx for the graph saabluster!
When testing my new flying searchlight I indeed saw more light past 3.3A
That mean it can reach the 20K lumens mark if I crank it to 5A per string :)
ergotelis
Greece/Hellas/Crete
jasonck08, buy a kd xm-l pcb star, reflow the led to this pcb.Redo your test and please post here again your findings, you will see what is the problem in your case as well as in most others. Do not want to say more, as whatever i say i have to prove it with pictures and specific data, but i need another person to help me to take pics while testing. I have spent so many hours with over 40 xm-l from different distributors and different pcbs. Your pcb(and led) is from cutters' right?
ergotelis
Greece/Hellas/Crete
Nice beamshot, but eyes can' t tell always the truth. Can you measure somehow the lumens? So, in accordance with the title of this thread, i guess you found too that THERE IS benefit in overdriving an xm-l as long as you have the right pcb base! :thumbsup:
ma_sha1
CT, USA
It's all about the age old "bottle neck" principle, getting reiterated by the lean six sigma training that goes around these days. Only improving the "bottle necks" will improve a system, regardless it's manufacturing, R&D or DIY. Improving upon non bottle necks is wasted effort & often lead to wrong conclusions.
In this case, the OP's PCB looks like bottle neck, all the copper heatsinking after won't help.
The light was sold to mvyrmnd, he is planning to do a shoot out vs. Techjunkie's 5x MCE mag.
Yes, true in this case but again, after PCB bottle neck is resolved,
there is still be PCB to heat sink heat transfer, heat sinking and heat sink to flashlight body heat transfer steps, either one could become a bottle neck in another test if not planned systematically.
Choke-up any one if the 4 critical steps (3 if led direct solder to heat sink) could lead to a conclusion that overdrive doesn't work, not just PCB. :)
mvyrmnd
Australia
I wonder how they had the XM-L heatsinked. That's a good result if it were on a MCPCB. I wonder if it could be pushed even further if it were soldered directly to a heatsink.
ergotelis
Greece/Hellas/Crete
considering the difference in performance every 500ma i can say that they use a good heatsinking pcb.
I will try a good U2 tested in the copper heatsink when it arrives finally(Dx delivery times...) to see if i can still boost more perfomance out of over 3amp!
onetrickpony
Has anyone ever tried running an led in a very cold environment, like say in a freezer at 20 degrees F?
Obviously, you'd still need to heat sink the thing, because without heat transfer, the die would still overheat, but if the ambient temperature is lower, you'd get much better cooling.
I know this isn't practical for a flashlight, but for raw testing of what the led itself could do, it might be fun.
I'd love to see what an XM-L could be driven to, and also what kind of light it would be putting out. The only way I can think of doing this is to get a styrofoam cooler and cut a hole in the side, then pack it with ice and aim the led out the hole. IF I had the time or money, mostly the money, I'd go do it, but my last XM-L just went in a maglite for my brother in law.
I also don't have a lux meter....
RepProdigious
the Netherlands
Just solder the LED directly on a basic copper core CPU heatsink and put it in a big tray of nice ice cold water and youll have all the cooling you need for any form of testing. To get 2 or 3 liters of water from 2 to 50 celsius you need a heck of a lot of energy..... like 160 Wh (right?) so gives you plenty time and it costs near to nothing.
onetrickpony
That's a good point, I was just thinking having the cold environment around the led might help, but you're right, the air around the top of the led isn't doing anything compared to the heatsink, especially if it's copper bathed in cold water.
It would be cool to see someone do this. I'll attempt to try it when I get another batch of parts/leds in, but like I said I don't have a light meter, so it'll be just current vs data sheet as far as analysis if and when I get around to it.
CKOD
I ran a SSC P7 upto ~15A iirc, under a bath of R-134 from canned air duster, that was quite impressive, kind of hard to get brightness measurements from under a boiling bath however :D
An XM-L on a PCB, bolted to a heat sink, de-domed itself with a bang at around 7-8A doing the same trick, more impressive of a failure, but nowhere near as crazy as that P7 drawing double digit current. I dont think 3 bondwires is enough for crazy current like that, compared to the 8 in the P7, and the 11ty billion in a SST-50m though I havent tried the R-134 trick with an SST-50.
onetrickpony
Thanks, makes me want that guys parts bin....
Judging by the date of the post, I'm guessing that was an XR-E? I'm in a rush so I couldn't read through the whole thing.
It's pretty amazing how tough leds are, when they're properly protected. I have an sst-90 I'm much more confident about driving to 9 amps now, especially because it's mounted to a copper heat sink with aluminum fins and a heat pipe and fan!
saabluster
Garland Tx
It was from my parts bin. Yes it was an XR-E. To my knowledge it is still the highest flux density recorded in the public domain. The LED was mounted on a heatpipe. The thing is is that I really don't think I did a very good job of it so I think there is even more room for improvement without changing the package any.
shao.fu.tzer
P-Town, TX
I've been thinking about incorporating a heatpipe setup into a flashlight... Has anyone heard of such a thing?
Shao
