Z
z_Thomas Nakaki
Guest
I was thinking about usinga Fenix TK35 mounted to my handlebars. I have not seen any mounts that would fit. Any suggestions?
I was just about to post the same question. I was at a store that stocks some Fenix lights the other day and noticed they had a newer/more robust looking bar mount. It does look bigger than their old one but I couldn't tell if it was big enough for the TK35 as they didn't have one.
Here's that new mount:
http://www.fenixlight.com/viewnproduct.asp?id=71
I was wondering about that... any chance some one out there with a 2 fishblock and TK35 could let us know? Thanks
I use the standard fishblock mounts on my bike and there is enough strap length to fit my tk35 just fine:thumbsup: It holds it relatively stable over road riding and doesnt bounce up and down much.
I make up torch mounts that fit from 22-32mm - whats the diameter?
With the twofish C block, you can just pull the strap through and put in a longer strap.Unfortunately, the Twofish Cyclopblock does not have replaceable straps, at least not easily replaceable. In order to replace them, you would have to cut them off with a knife or scissors, then place new ones in and stitch those on, or sew them on.
