Olight - R50
Results 1 to 6 of 6
Thread: Review of / Measurements on WF-139
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Review of / Measurements on WF-139
    Charger UltraFire WF-139
    This charger has been around a long time and in many versions. One of the first version had a very bad reputation, but the current versions is better. The version I test here is from AW. The charger is a two channel charger that can fit up to two 18650 batteries. The four terminals at the sides are not connected.
    The charger has a connector for the mains lead and is sold with different mains leads depending on country. The mains supply can be from 100 to 240 VAC and 50 to 60 Hz. It can also be connected to a 12 volt source, i.e. a car.
    There is two leds, they are red when charging with a occasional green flash. At all other times they are green. This means that the led will be green if a battery with to low voltage is placed in the charger!
    The charger can handle up to 68 mm long batteries, this does not include all brands of protected 18650 batteries (See my 18650 LiIon comparison for length of different brands).
    Measurements
    The charger uses a 150uA trickle charge for batteries below 2.25 volt.
    Between 2.25 volt and 4.2 volt a constant current of 350 to 400 mA is used to charge.
    When the battery goes above 4.2 volt the current is turned off (below 2uA current).
    The charger will not restart charging before the battery has been removed, the voltage has been below 2.25 volt or the power has been cycled.
    When charger is disconnected from power, but with a battery in, it will draw 140uA from the battery.
    With two batteries the charging current is slightly reduced (less than 10% reduction).
    In the first example the protection in the battery is activated, because the voltage gets above 4.25 volt. This stops the charge. When the battery is removed, the voltage will drop and the protection will turn off again. The charge time is about 5½ hour.
    Again a 18650 battery, this time the protection does not trip and the charge turns off the regular way. The charge time is about 6½ hour.
    With a 16340 battery the charger is much faster, especially with this old battery with reduced capacity. In this chart it is also easy to see that the charger goes above 4.2 volt, but when the charging is turned off, the battery is exactly at 4.2 volt.
    How did the charge manage to turn off at 4.2 volt without current? This can be seen in this graph, each 1.5 second the charger turns the current off for 0.05 second and then it can measure the voltage without current. Note: This graph has noise reduction applied!
    There might be a reason for measuring the voltage this way. In the above graph I have measured with noise reduction, here is the same lines without any noise reduction (but a different time scale). The current generator in the charger is generating a lot of electric noise, making it difficult to get exact measurements when it is on.
    Conclusion
    The charger does not follow the recommended charge procedure for LiIon batteries, but it does charge to 4.2 volt and then turns off. It takes a long time to charge 18650 batteries, but 16340 and 14500 are charged fast.
    I believe that it is a useable charger.
    Notes
    To test if the charger is this version or the old version a DMM is required: Measure the voltage between the + and - charging terminals without a battery mounted, if it is around 5 volt, it is the new version (The old version is above 10 volt).
    Another version of the WF-139 has 0 volt between + and - terminals without battery and will charge with up to 1.2 ampere, it has the same markings as any other WF-139 charger. Due to higher current this version cannot be recommended for 18350, 16340 and 14500 cells.
    Here is an explanation on how I did the above charge curves: How do I test a charger
    Default Re: Review of / Measurements on WF-139
    Thanks for the review.Looks like the newer version will not overcharge the battery, and cause damage, right ?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by grayhighh View Post
    I have not seen any problems with overcharged batteries.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Flashaholic Teobaldo's Avatar
    Apr 2010
    Santiago de Chile
    Thanks for the review and the effort by delivering us this valuable information.
    In Battery Junction they say:
    The power output of this charger is incorrect for the protected 3V 750 & 900mah RCR123A cells that we carry. We specifically do not recommend using this charger for those cells. Only use this charger with 3.6 & 3.7V cells.
    I have seen some videos in Youtube where they are charged this type of batteries. Then, ¿which RCR123 yes they can be charged in it? I have 6 RCR123A Tenergy 900 mAh and need a second charger for backup purpose... or it is better to buy another Tenergy charger? (I have a Shekor charger too and works fine with the Tenergy RCR123A and 18650).
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Teobaldo View Post
    They are correct, you can not use the WF-139 for 3.2 volt cells.
    There are usual sold 3 types of RCR123 cells:
    1. 3.2 volt native cells (LiFePO4), need a 3.2 volt charger.
    2. 3.7 volt native cells (LiCoO2 or LiMn), need a 3.7 volt charger (i.e. WF-139).
    3. 3.2 volt regulated cells with LiCoO2 chemistry, need a special charger for a regulated cell.
    It looks like the Tenergy 900mAh is the 3) type.
    Mixing charges and batteries:
    Using a charger for 1) on 2) or 3) will not fill the batteries up.
    Using a charger for 2) on 1) will damage the battery.
    Using a charger for 2) on 3) will not fill the battery up.
    Using a charger for 3) on 1) or 2) will damage the battery.
    Apr 2010
    Santiago de Chile
    Thanks for the complete answer, HKJ.
    Grrr... Not to have known before buying it. I sought information, but apparently was not sufficient. It does not it matter, at least serves me for the 18650 batteries. I believe that I will entrust another Tenergy charger.
    Thanks again. This it is a marvelous place to obtain information of these themes.
