EZAA + XM-L
dandism
San Jose, CA
I know, another XM-L mod, but how can you get tired of lumens? :devil:
So this started out as a Nitecore EZAA with the XP-E R2. I was lucky to find that the came off with little force making it a good candidate for an emmiter upgrade. I had a few XM-L's on small boards that I got from Craig at www.illuminationsupply.com that had the perfect dimensions for the EZAA so I just had to do it.
I started out by drilling out the hole in the reflector as the XM-L is significantly wider than the XP-E. I then ground down the base of the reflector so that the XM-L can peek through it. Then it was just a matter of unsoldering the XP-E, removing it, epoxying the XM-L and soldering the wires.
The beam pattern now shows a nice large hotspot which I find more usefull for edc purposes. The spill is also noticeably brighter. I love it! :rock:
megabit
Hi
How do you unscrew the head? Clockwise or counterclockwise? Do you use lot of force? Was it glued?
thanks in advance
dandism
San Jose, CA
Hi
thanks in advance
They are regular threads. I was just lucky that mine didn't take much effort to loosen, perhaps because it was a hot day?
