Phoenix Electroforms
Page 7 of 8 FirstFirst 12345678 LastLast
Results 181 to 210 of 239
Thread: Xeno E03 (1xAA, 1x14500) - XP-G R5 Neutral White - Review: RUNTIMES, BEAMSHOTS +
  1. #181
    Default Re: Xeno E03 (1xAA, 1x14500) - XP-G R5 Neutral White - Review: RUNTIMES, BEAMSHOTS +
    Quote Originally Posted by MojaveMoon07 View Post
    Thank you
    About how long has each of these two "de-flickerings" taken you (time for tweezers to dissamble plus time for bathing with WD-40) ?
    havent done the 2nd de-flickering yet. seems like the E03 has stopped flickering for now; its flickering and non-flickering behavior is truely to be called 'acting up'. i am too lazy to get myself again all messy and stinky with the WD40 and waste the WD40. where to dispose the WD40 bathing liquid after the bath, what? 20ml or something?? .. if it were water or a simple 1x short spraying, i would do it more often.
    btw, i never take a bath either, at least it doesnt harm the environment and nature if one flushes bathing water apart from the waste of water imho. but bathing WD40 liquid? where to flush it please?? it's like solving one problem (the flickering) and by that creating another problem (where to dispose the excess of the WD40 bathing liquid), again apart from the waste of chemical substance.
    if you do it hush hush and simply dispose the WD40 liquid in your kitchen sink, then you could be done within 5mins (record time). If you take your time, it'll take 10mins.
  2. #182
    can you install spherical lense on e03 ? has anyone tryed it?
  3. #183
    Dec 2005
    I am Kenny Powers
    Quote Originally Posted by nofearek9 View Post
    I haven't heard of that before but it's a good idea!
    aka Fratrick Bateman, Brosama Bin Liftin, Walter Crunkite, Bro Namath, Teddy Broosevelt, and the Tomahawk Crunkmissile.
    (my lights)
  4. #184
    I noticed today that there's a new U2 cool white version of this light up on a certain HK retailer's site. It seems to add hidden flashing modes but I don't see any other changes.
  5. #185
    *edit*
    i found the seller ,the specs of the new U2 are :
    HDE Engine-XENO unique Quiet RSLTM LED driverLinear LED driver, Not PWM mode
    Non-Flickering and Absolutely Noiseless even at Ultra-Low level
    With Ultra-Low output, more than 20 hrs burning time
    · CREE XM-L U2 Max (OTF) 460 Lumens
    Vs the T6 :
    DE2 Engine-XENO unique Quiet RSLTM LED driverLinear LED driver, Not PWM mode
    · CREE XM-L T6 Max (OTF) 430 Lumens
    i gues will make it better thrower.
  6. #186
    Quote Originally Posted by tickled View Post
    It looks like the neutral white (5000K) version has been updated too. Hidden flashing modes and flux bin bumped up by one to T6 (again) from T5.
  7. #187
    Does anyone know if the battery extender tube on the E15 will fit the E03?
    Just wondering what happens when you run 2AA with the E03.
  8. #188
    i guess the same output as the 3v AA primarys.
    anyone can confirm the diference between the leds T6 Vs U2 is just the extra lumens or the U2 is more floud as well?
  9. #189
    So possibly like the E15 then? So the modes might be 1V-2V is 1AA, 2V-3.4V is 2AA, CR123A etc, 3.4V-4.2V is Li-ion etc.
  10. #190
    i dont know if its fit ,but looks like will work fine with 2xAA but why go to the trouble you can get cheap 14500 with charger for $15.
  11. #191
    Flashaholic* jasonck08's Avatar
    Sep 2007
    Redding, CA
    Quote Originally Posted by Mr Floppy View Post
    Yes it will, but the E15 tube is not for sale individually. The E15 is hard anodized level III, includes a diffuser wand, and obviously supports 1AA or 2AA's or 1x 14500. Other than that they are very similar lights and use the same driver.
    It will be about 6-7% brighter on average. The U2 and T6 are both XM-L emitters so they will have exactly the same beam profile. Because it is a slight bit brighter it will have a tiny tiny bit better throw.
  12. #192
    I don't like cheap and Li-ion but the main purpose is that I'd like to get a NW, warm white and the U2. It looks like the U2 will be a E03 so the E15 will have to be either the neutral or the warm.
    Quote Originally Posted by jasonck08 View Post
    Thanks, just have to work out which combination to get. Any benefit with a XP-G over the XM-L in the neutral or the warm?
  13. #193
    Sep 2007
    Redding, CA
    XP-G may throw a little better, but XM-L is going be floodier and more efficient and brighter by ~10-20% or so depending on the drive level and battery type.
  14. #194
    Has anyone got the new version (XM-U2, with new switch and improvements)?
    I would welcome photos of those details (spare switch, ..), thanks
  15. #195
    Here you go - f2.7, 1/100sec exposure for both (no diffuser first, diffuser second) Here you go - f2.7, 1/100sec exposure for both (no diffuser first, diffuser second)
    Personally, I like this diffuser better than most other wand ones. The flat top gives you a very even beam - a lot of the conical ones tend to still produce some centre throw. Although my preferred diffuser is always a thin flat one over the lens.
    Note again the diffuser does not come with the light - it is an optional accessory to be purchased separately.
    Does the diffuser get really hot after extended use?
  16. #196
    Enlightened riccardo.dv's Avatar
    Jul 2011
    Europe
    Default
    No it doesn't, with a 14500 only the light becomes warm
    Tapatalk @Xperia Arc S
    here are only 10 types of people in the world: Those who understand binary, and those who don't
  17. #197
    the new switch is the white
  18. #198
    Thanks for photo.
    Nice white switch, I love white!!
  19. #199
    Dec 2005
    I am Kenny Powers
    thanks for posting that!
    (my lights)
  20. #200
    Grinser2 Re: Xeno E03 (1xAA, 1x14500) - XP-G R5 Neutral White - Review: RUNTIMES, BEAMSHOTS +
    who have the pictures about XENO E03 V3 LED flashlight ?
    I hear that the XENO E03 V3 LED flashlight is very good, and I want to see the pictures about it, some people can take the real pictures of it to me ?
  21. #201
    Dec 2005
    I am Kenny Powers
    Quote Originally Posted by maybehope30 View Post
    it's the exact same
    (my lights)
  22. #202
    I just bought one of these Xeno E03 v3's with XM-U2 along with these 1450 batteries: http://dx.com/p/trustfire-protected-...=39062&u=26124
    and this charger: http://dx.com/p/trustfire-tr-001-mul...=26124&u=12594
    My question is am I safe using those batteries and that charger? Someone earlier in the thread mentioned something about hearing bad things about ****fire batteries which got me concerned. I don't want this light blowing up in my hands when I have it on high. To my understanding ultrafire batteries are not very good but the trustfire ones are, even though they are cheap. But want to be sure. Please advise! Thanks!
  23. #203
    i have the same compination ,just dont let the batteries charging without you be near ,when the light goes green remove the batteries. when you will need better batteries try AW ,will work fine with this charger again when led goes green you have to remove them.
  24. #204
    What do you mean by this? What does AW mean?
  25. #205
    Enlightened Tyler___Durden's Avatar
    Sep 2012
    London, UK
    Please use your imaginations to fill in the blank space below
    with some batteries!!!
    Duracell or Eveready or Energiser
    __ _ _ _ _ _ _ _ _ _ _ _ _ _ __ _ __ __ _ _ _ _ _ _ _ _ _ _ _ __ _ _
    See Rule #3 Do not Hot Link images. Please host on an image site, Imageshack or similar and repost – Thanks Norm
    I see you have removed a link to an image used to accompany a message and suggested that I use imageshack or another image hosting site. If I copied the image as you suggested that would be an copyright infringment, whereas the way I have done it is totally legal. I appreciate that some companies do not permit linking images - however if that is the case it is trivial for them to put their images in a protected directory or use other means to prevent this happening. In the case of candlepowerforums.com, this hardly a high volume site and linking images will not cause probems for any website these days - perhaps bandwidth was an issue in the early days of the internet even though Tim Berners-Lee specifically envisioned the www to work that way. Indeed good HTML5 web design today specifically encourages all sorts of cross site content sharing. Oh, AW is a battery brand.
  26. #206
    if in the future you will going to buy a better brand of 14500 batteries ,prefer the AW brand.
  27. #207
    Oh ok, I thought the trustfire's were supposed to be decent batteries.
    One other question with regards to this new cool white u2 version. Will that put out about 500 actual lumens on high with a 14500?
  28. #208
    are not bad batteries but there are lot of fakes copies in the market.
    the specs of the led for sure its better,compared them with the eye u2 looks a bit brighter.
  29. #209
    Ok I just went back and looked at the chart again, and it looks like he got 510 lumens from the nuetral white one?? Is that right?? And that's with the xm-L model before the upgrades and the nuetral white is not as bright as the cw. So that would make the new and improved Cw u2 like 600 lumens? That can't be right...
  30. #210
    when i measured the stock driver of the xeno e03 was about 2,4 Amps so from the specs of the led yes its possible,but of course the small flashlight will get hot.
