First of I want to say that I Love this charger. Has saved me numerous times when I am out, and there is no power source. However the included retractable cable seems weak. Overtime it starts to wear out and, does not deliver enough power anymore and simply stops working. I had to replace the cable twice already.
I am using this to charge my blackberry bold 9700, and the included micro USB cable that came with my bold 9700 does not work with this charger even though the mobile charger has a USB PORT. When I try to use the blackberry microUSB cable. I get a error that says not enough power coming from usb to charge this device, make sure you connect to a USB port that can provide sufficient power yet the charger is in idle as if nothing is plugged in.
The weird thing is why does the retractable cable included with the charger charges my blackberry bold 9700 fine, but complains when using the blackberry micro USB cable???. I just don't get it???. By the way I had to get the micro USB adapter for the retractable cable in order to charge my phone.
Problem with this cable that it is too weak I don't think it is meant to carry power constantly, and wears out overtime. Feels like the retractable cable was meant for audio, similar to those Sony headphones type cable. Like I said I don't want to replace the retractable cable AGAIN. Would rather use the blackberry microUSB cable instead, except it does not work with this charger!!.
Manufacture says that you can use the usb cable that came with the device, bypassing the use of the retractable cable that came included with the charger. So what gives???
Any solutions??. Thanks
http://www.amazon.com/Tekkeon-TekCha...2sr=8-1-spell
