krutzbeuazen
Hello everybody,
I have three Cree XP-G LEDs. They are supposed to be soldered directly onto a slab of copper, I plan to contact them from the tiny "pads" on the top. After removing the protective layer from the top pads, this works.
How do I get rid of the original pads on the bottom? I think I see the connectionpoints where the lower pads are contacted (the "via", how are they called?). I have no idea how to cut them out: Best would be to have parts of the solder pads left for better connection to the heatsink. Using a dremel to rub away the pad around the connection failed.. that stuff is just too little!
Older LEDs had the connections at the corners, which could be chipped off - No luck here I guess?
Help greatly appreciated!
Manuel
Manuel
