minorearth
hi folks,
in wintertime i often go for a afterwork running trip instead of a bicycle tour so i need a headlamp which is absolutley compfortable to wear on top of my head and that i can also use in my bike. weight was although a point. after building some bicycle lights in the past, some experiences i've made in heat treatment and anodizing i can look at. heat treatment is in my opinion a important point if your light should work well for a long time.
in the past i often use led drivers from taskled and im really satisfied with these driver. in my lamp i used a maxflex driver with 14,8v lipo accu. i used a 7 x xpg r5 led circuit from led tech in germany with a kathod polymer optic.
i've tested the lamp a few time and i can say everything works absolutly well.
so enough words, here the pictures.
cheers christian
cheers christian
