ThruNite
Results 1 to 11 of 11
Thread: Looking for good driver for Triple CREE XML T6
    Default Looking for good driver for Triple CREE XML T6
    Hello
    I want to make Triple CREE XML T6 Auxiliary Lights for my Truck.
    I am looking for good driver for Triple CREE XML T6 for 12v-18V input.
    I have already 3Up lense, light casing Kit and CREE XML T6 Led's
    Dec 2006
    New Jersey, USA
    Default Re: Looking for good driver for Triple CREE XML T6
    H6Flex or H6CC are very good drivers but for automotive application you will need power supply filter before them (this will apply for all drivers not designed specificaly for automotive application).
    Quote Originally Posted by arek98 View Post
    Thank you
    any other driver ? as these are very expensive
    Unenlightened
    Mar 2010
    What is a power supply filter or what does it do? Why would it be needed in an automotive application?
    Quote Originally Posted by JDadam View Post
    I want to use these lights for off road Driving.
    I am running a night saffari Travel agency we need good lighting system with long backup.
    Hid or halogen are not good for us due to short back up
    Flashaholic* Mattaus's Avatar
    Mar 2011
    Brisbane, Australia
    Hi,
    These work up to 12V at 3A and only cost $10.
    Or this works up to 18V at 3A and only cost $5.
    I've got no experience with either though I have 2 of the second ones on the way as we speak. Bit annoyed I didn't find the LCK ones first though as their mode selection is much better (none of this strobe crap).
    Does anybody maybe found some similar driver to this ? but maybe cheaper
    i need 6 pcs.
    Tnx 1
    Unenlightened
    Feb 2013
    I need driver for single Cree XML T6. It's 3.6V, 3A. I would like to power it on 12V adapter. Can someone reccomend me something like step down converter...? It's for my LCD projector project. This is my first time i use Cree XML T6 diode so I'm not that familiar how to do it.
    Thank you!
    Flashaholic* Changchung's Avatar
    Oct 2005
    Where the night is too short...
    Quote Originally Posted by Mattaus View Post
    Hi,
    Those drivers are for a single Led, what about to use a DC/DC converter? I have the same issue, I am building a light for 6 xml and 6 xpg I am thinking in connect three in serie, four groups.
    Some DC/DC converters had adjustable voltage output, but my doubt is about the currents, most of this had a max of 3amps.
    Very cheap in ebay...
    I have as well a DC/DC that had three adjustments, current, volts and fill. BTW, I dont know hot to adjust the fill funtion...
    Would this last be a good option???
    Sent from my phone with camera with flash and internet on it...
    Zebralight Spark Princeton Inova Petzl Maglite Bushnell 4 XM-L MagMod and a lot of Cree XM-L Lights Nitecore i4 Intellicharger Intl-outdoor 3400 Panasonic 3100 Bare and protected Samsung 3000 Sanyo 2600
    Please, respect the planet, dont kill animals...
    Unenlightened
    Feb 2013
    semelab makes a great semiconductor voltage regulator that would work great on the front end of the driver. I am also looking at the taskled drivers, yeah they are expensive but the work great. I would like it if I could find a single mode driver in the cheap ones. It is irritating to cycle through the modes to get back where you want.
    Mar 2011
    Slovenia
    For automotive applications use drivers that can handle voltage spikes up to 80V or even 120V, or they wont last long. Hyperbuck and hyperboost are the ones you should look at for such applications.
