Elijah
I'm building a larger headlamp for caving and having trouble figuring out a good driver to use. I need a fairly wide range of currents for my purposes. I want a high setting that can light up the world for large passages and deep pits, but would only be used for <1min at a time. I want a medium setting for moving around the cave, and I want a really low setting for tight passages and any time I'm stopped. First let me spec the build so you know more what I am looking for. I am leaving some flexibility in my design to allow for different driver possibilities.
Going to power it using 18650's in 1S2P, 2S1P, or 3S1P configuration depending on what voltage I need.
Looking at powering 2, 3, or 4 neutral white XM-L's in series (prefer 4, but could do as few as 2 if constrained by driver options).
Want 3 modes across a huge range (~3000mA, ~700ma, ~100ma) oo:
Probably use a magnetic switch.
The smaller the better, but anything ~1"^2 should fit in my housing.
Don't think PWM would be a good option in this case for a number of reasons.
And of course better efficiency is always appreciated.
I'm willing to drop some decent money (~$30) on a good driver or do the work to hack/build one that suites my needs. I'm not good at electrical design, but I'm good with a digital soldering iron, so if someone could help me design something, I should be able to build it (or be willing to pay for one you build for me). I have seen some hacked Deal Extreme designs posted, so thinking something along those lines might be the way to go. Don't care if it's boost or buck, but efficiency (and lack of heat production) would be great. Could 2 drivers hooked together do what I'm asking? Any ideas would be greatly appreciated.
Thanks, Eli
Thanks, Eli
